Using DOSBox on a new iMac
Reply 20 of 52, by wd
Rank DOSBox Author
DOSBox Author
maybe create a new one (see the, well, readme).
Reply 21 of 52, by InstantWare
You might want to create the file DOSBox Preferences yourself.
Use the app TextEdit for it, which you will find in /Applications. Save the file in pure text format, not as .rtf.
Add the sections that you need, e.g. those as outlined in my previous post. Once you are ready with it, copy it to your users preferences, which you can find at:
/Users/yourusername/Library/Preferences.
Restart DOSBox.
Best regards
Rolf
Reply 22 of 52, by hsegal
WD - Where can I find or see the README file that you are referring to? Could you point me to it or copy it to an email and send it to me? My email is: hsegal@usa.net
Rolf - I proceed to set up a plain text file called DOSBox Preferences (with no extension) and put it in the correct Preferences folder, but nothing but it does not seem to load when I restart dosBox. Does the file title need an extension like .bat to work, like the old fashioned autoexec.bat of 20 years ago?
Thanks,
Hal
Reply 23 of 52, by wd
Rank DOSBox Author
DOSBox Author
Which exact package did you download?
Reply 24 of 52, by InstantWare
Does the autexec section start with:
[autoexec]
No, there is no file extension necessary.
Best regards
Rolf
Reply 26 of 52, by wd
Rank DOSBox Author
DOSBox Author
The current official MacOS X download misses the Readme file.
Bad.
Reply 27 of 52, by hsegal
Did it! Success! I finally got the autoload feature running. The trick was to keep the machine from automatically adding an extension to the preferences file. Thanks to everyone, who steered me to the answers. I really appreciate it.
This is minor, but would be nice:
I'd like to put CTRL-F9 (the kill dosBox command) at the end of the preferences file so that when I close my application in the window, it automatically shuts the doxBox. Does anyone know if there is a way to do this? In other words, is there a key sequence that could be put IN THE FILE that triggers CTRL-F9?
Hal
Reply 28 of 52, by IIGS_User
Hal
If you run DOSBox from the Terminal, add -exit to the end of the command line. Otherwise, put the command 'exit' to the end of the AUTOEXEC section.
Klimawandel.
Reply 29 of 52, by Qbix
Rank DOSBox Author
DOSBox Author
read the readme and be supprised about the options 😉
there are multiple ways of doing this. all of them share the word "exit" though.
Good luck
Water flows down the stream
Reply 30 of 52, by hsegal
The exit command works PERFECTLY. Thanks for that!
Okay, my last task before I'm done with this setup is to get the phone dialer to work with my contact manager. I purchased the Apple USB Modem and Apple tech support walked me through testing it, so we know it works for standard Apple applications. Now the question is: how to get the modem to dial from a program running in dosBox?
Could anyone offer me any suggestions on this?
Hal
Reply 31 of 52, by InstantWare
Hal,
Directserial (modem) support is deactivated in the current distribution of DOSBox for Mac OS X.
I compiled for my own use a DOSBox with activated directserial support, and I reported success in the forum:
Dial-In Connection with the internal Modem using DOSBox @ OS X
Do you think, you will be able to compile DOSBox from source yourself at your machine?
Best regards
Rolf
Reply 32 of 52, by hsegal
Rolf,
I'm really glad to hear that a solution is POSSIBLE. But, I'm afraid that I have no idea how to do a compile. I looked at the posts from the link you provided and it is WAY over my head. Would there be a way for me to download and install your improved version the same way I downloaded and installed the original version? If not, I'm sure I could follow step-by-step instructions, but preparing those instructions would probably be very time-consuming for you. I hope there is some way...
Hal
Reply 33 of 52, by InstantWare
Hal,
"Compiling from source" sounds more difficult than it is.
Providing a stand alone binary package would mean a lot of work for me, because, I need to prepare an .app-package which includes all the dependent libraries.
Possibly we can meet in the middle. If you would be able to install Apples Developer Tools which should be part of the software package of your new iMac AND the necessary libraries by the way of MacPorts - http://www.macports.org/, then I could send to you the DOSBox executable
Please let me know, if this makes sense to you, then I will send the instructions.
Best regards
Rolf
Reply 34 of 52, by hsegal
Rolf,
I'd be willing to give that a try.
Separately, could you give me your email address so that I could ask you a private question?
Hal
Reply 35 of 52, by InstantWare
For sending private mesages to somebodey, you might want to push the pm button at the lower left corner of somebodies message text box.
Here comes the first set of instractions for preparing your iMac.
  • 1. locate the Apple Developer Tools CD or DVD, possibly it is nowadays called Xcode Tools
    2. install the Xcode Tools on your iMac by double clicking onto the installer package and following the guidelines in the various message boxes
    3. download and install the MacPorts OSS package management system
    http://svn.macports.org/repository/macports/d … -1.5.0-10.4.dmg
    4. open the Terminal. You'll find it in /Applications/Utilities
    5. let MacPorts manage the installation of the necessary Open Source Software packages. Enter the respective commands in the Terminal window:
    autotools (takes 20-30 min)
    sudo port install automake
    libSDL
    sudo port install libsdl
    libSDL_Net
    sudo port install libsdl_net
    libSDL_Sound
    sudo port install libsdl_sound
    libPNG
    sudo port install libpng
Now your iMac should be ready to run my custom binary. However, you are also almost there, for compiling the binary from source by yourself.
Let me know your decision, whether you want my binary or the remaining set of instructions for making DOSBox by yourself.
Best regards
Rolf
Reply 36 of 52, by darkgamorck
0.72 will be out sooner rather than later and direct serial for OS X will be part of it. I've actually been helping to beta test beta/rc builds for the OS X version. You may just want to wait a few days.
Reply 37 of 52, by IIGS_User
Great News! 🤑
Klimawandel.
Reply 38 of 52, by IIGS_User
How to use the directserial connection in MacOS X?
When I try the unix grammar
Serial1=directserial realport:ttyS01
the Terminal replies with
Serial1:Serial Port "/dev/ttyS01" could not be opened.
The specified port does not exist.
What values do I have to enter next to "realport:"?
Klimawandel.
Reply 39 of 52, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Try ttyS1 ?
1+1=10
