First post, by Saidian
So I'm planning on picking up a Biostar G31D-M7 but I can't seem to find SATA Drivers to slipstream for when I make a custom install with nLite.
Is there a generic driver or pack I can download instead?
Got the bug again for making an XP machine and I think I must've forgotten all my knowledge on making custom installations, would be much appreciated if I could have a refresher.
Reply 1 of 8, by zyga64
This board is based on G31 + ICH7 chipset. ICH7 doesn't support ACPI so, you don't need specific driver for SATA.
https://www.intel.com/content/www/us/en/suppo … chnologies.html
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 2 of 8, by Saidian
So am I good to install without using a driver or are you saying I can use any other motherboards driver?
Reply 3 of 8, by LSS10999
Saidian wrote on 2023-04-14, 06:07:
If your SATA is in IDE mode then you don't need to use any driver.
If you're using RAID or AHCI then you'll need to install a driver for the chipset you're using (any driver supporting ICH7 will do).
Reply 4 of 8, by zyga64
Although there are ICH7 variants that support AHCI/RAID, this motherboard looks extremely truncated (only 2 physical SATA ports).
So I suspect that the basic ICH7 variant (82801GB) was used - which doesn't support AHCI nor RAID.
https://en.wikipedia.org/wiki/List_of_Intel_c … Series_chipsets
Reply 5 of 8, by Saidian
Sounding like I should probably look for another motherboard then? I found the Biostar up for sale for £10 and it included a cpu, cooler and 4gb of DDR2 and I liked the sound of that deal.
But if I'm going to be limited to IDE speeds maybe I should spend a bit more for a board that can properly do SATA. Unless it wouldn't matter either way?
Reply 6 of 8, by LSS10999
Saidian wrote on 2023-04-14, 07:00:
SATA operates at the speed it's capable of even in IDE mode. In your chipset's case (SATA2), you could reach up to 300MB/s sequential.
I'm wondering what kind of disk you're using. If you're using mechanical hard disks you're unlikely to notice any difference, as standard hard disks usually peak at around 100MB/s sequential. High sequential r/w speeds are only relevant for SSDs.
Reply 7 of 8, by Saidian
Fair enough then I'll continue with my current plan 😀
I'm fine with normal HDD speeds so it's all good. Cheers for the assistance!
Reply 8 of 8, by zyga64
Sata II speed (300 MiB /s) will be in perfectly fine.
It's ICH7 (which is used in 99% motherboards with Intel 945, G31 even G41 chipsets) just lacks additional features like AHCI / RAID.
Consider better board only if you need those features or more than two SATA devices.
