First post, by Law212
Hi all, I was using this great program that would copy downloaded floppy disk images to disk. It was super easy to use and worked like a charm but I formatted my laptop and cant remember the name of the software. I think it had a penguin for an icon? Anyone know of it or a good program that does this?
Reply 1 of 10, by Shagittarius
Law212 wrote on 2023-04-20, 17:20:
I generally use WinImage.
Reply 2 of 10, by Zup
Wasn't Winimage the one that replaced boot sectors?
I'm selling some stuff!
Reply 3 of 10, by Law212
Shagittarius wrote on 2023-04-20, 17:37:
Thanks, I ll try that .
Reply 4 of 10, by debs3759
Zup wrote on 2023-04-20, 17:50:
Any good imaging software copies all data, including the boot sector. It's part of the disc. They might give a choice not to, but by default I fail to see why they wouldn't.
Reply 5 of 10, by TheMobRules
WinImage does write its own stuff into the boot sector, so the image you get is not 100% exact. Not sure if you can disable this "feature" as I haven't used it in a long time.
I highly recommend M. Brutman's DskImage. It's a very simple tool, but you can use it even on an 8088 and will produce a raw image without any unnecessary fluff.
Reply 6 of 10, by Jo22
TheMobRules wrote on 2023-04-20, 21:16:
I heard about this a couple of time and I'm all ears, however, whenever I tried to confirm that, I failed.
The floppy image created by WinImage and a Freeware floppy imager was the same each time.
How is it possible to force this "feature" to occur?
Edit: Could it be that WinImage changes the boot sector if you create a blank image in WinImage?
Ie, when selecting 1,44 MB diskette format, then use drag&drop to insert files?
That would make sense, that there's a custom boot sector. In the DOS days, quite a few diskettes had displayed a
custom boot text if being booted from (disk was accidentally left in A: drive during boot).
Reply 7 of 10, by maxtherabbit
http://www.chrysocome.net/rawwrite
penguin icon
Reply 8 of 10, by Law212
maxtherabbit wrote on 2023-04-20, 22:02:
http://www.chrysocome.net/rawwrite ^ penguin icon […]
penguin icon
Thats the one! Thanks! I tried WinWrite and it doesnt work. So thanks!
Reply 9 of 10, by Law212
Law212 wrote on 2023-04-21, 13:46:
penguin icon
It worked right away just as I remember. Thanks again!
Reply 10 of 10, by maxtherabbit
You're welcome, glad to hear it
