First post, by bdtbr
Hi All,
This post is only for show you the Genius Sound Maker 16IE ISA slot sound card, as there is not much information about it on the internet. You can comment of course.
This one is manufactured in april of 1996.
Regards,
Bdtbr
    1.74 MiB
    1.86 MiB
    1.77 MiB
    390.92 KiB
    480.19 KiB
Reply 1 of 7, by zwrr
There are no jumper instructions, which is really bad.
486DLC-40, 386-VC-H, 32MB, GD5429, ES1868F
486DX4-100EW, VI15G, 32MB, ARK1000VL, ES1868F
5x86-120GP, HIPPO-15, 32MB, Riva128, ES1868F
Pentium MMX-233, T2P4, 128MB, TNT2, SB16
Tualatin-1.4G, 694X, 512MB, G400, Voodoo2, SB AWE32
Reply 2 of 7, by Pierre32
zwrr wrote on 2023-04-21, 03:04:
Irritating but common. Looks like this is probably them: https://stason.org/TULARC/pc/sound-cards-mult … BSOUND-503.html
With thanks to this thread: Re: ESS 1688F sound card
bdtbr wrote on 2023-04-20, 17:40:
Hi All,
Does your box have any other contents (disks, manual)? Always nice to get that stuff along with box photos up onto archive.org.
Reply 3 of 7, by bloodem
The ES1688 (the non-PNP version - same as the OP's) is one of my favorite sound cards. Excellent compatibility and sound quality!
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 4 of 7, by badmojo
That's a nice card - the best AudioDrive I personally came across back in my ESS testing days:
Re: ESS AudioDrive (ES1868) - a surprisingly good ISA sound card
It's made by Labway, who seem to have done quite a few quality low-cost cards with various chipsets.
Reply 5 of 7, by bdtbr
Yes, I still have the box, but unfortunately I threw out the manual and the floppy somewhere about 2005-2010. The content of the floppy was the ESS VxD driver for Win3.1 and Win9x, and the AudioDrive software. I purchased this card in 1996. This card was my only ISA soundcard, followed by a PCI Sound Blaster. It was part of a 2x86 12mhz, 40MB HDD, 1MB RAM + TVGA, later with a 4x Sony CD-ROM drive. 😀 Now I plan to install this card into my retro PII 400Mhz config for Win98SE.
    726.26 KiB
Reply 6 of 7, by analog_programmer
Yesterday I got this as a free gift with videocard from an ebay seller. The floppy disk with the drivers is original and in perfectly readable condition.
111.79 KiB
The card had a problem with shorted traces on its back in a place with protective solder mask rubbed off due to someone's unsuccessful attempt to tin them. Some solder wick and a tiny drop of fresh green UV light curing solder mask - pretty easy repair and now the soundcard works again as expected.
There are some jumpers to configure IRQ, DMA, I/O address, but is there possibility to bypass its own Philips TDA1517 amplifier (its pretty "lo-fi" sounding to me) like on some newer ES1868/9 based cards?
P.S. Here it is image file from original floppy disk with drivers:
SMI16IEV2.zip
989.87 KiB
44 downloads
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
