First post, by Pickelhaube808
New to the 3dfx club here and I was wondering why games that would previously run fine (albeit slow with my nvidia card) now output a frame or two and then lock up the computer.
I tried different nVidia and 3dfx drivers (both official and unofficial) and the issue persists. Is this just because I have two 3d cards in the same system? Should I just replace it with a 2D card so there is no fighting between the two?
3D programs that still work fine:
-Unreal (Glide)
-Half Life (MiniGL)
-Bryce3d (???)
-3D Moving Maker
3D programs now lock up:
-JFK Reloaded (D3D or OpenGL)
-POSTAL 2(?)
-Various other 3D programs that seem to be OpenGL (like MidiJam)
Relevant Specs:
-Windows 2000 SP4
-PIII 850MHz (100FSB)
-768MB SDRAM
-nVIDIA RIVA TNT2 M64
-PowerColor Voodoo2 EvilKing II (soon to be a second for SLi)
-ATI 3D-Rage Pro (disabled onboard video, should I uninstall it completely?)
-FastVoodoo2 4.0 XP Gold Edition
-nVidia 45.23 WHQL Drivers (WIN2K/XP)
I tried searching around about this before but didn't really come up with anything. If you have any ideas or there are already existing threads that have solved this, please let me know.
Complete Specs:
AIDA32 Report
--------[ AIDA32 (c) 1995-2002 Unlimited Possibilities ]----------------------------------------------------------------
Version AIDA32 v3.02
Author fiery@aida32.hu
Homepage http://www.aida32.hu
Report Type Report Wizard
Computer Pickel-PC
Generator Pickel
Operating System Microsoft Windows 2000 Professional 5.0.2195 (Win2k Retail)
Date 2006-04-30
Time 17:00
--------[ Summary ]-----------------------------------------------------------------------------------------------------
Computer:
OS Service Pack Service Pack 4
Computer Name Pickel-PC
User Name Pickel
Logon Domain Pickel-PC
Motherboard:
CPU Type Intel Pentium IIIE, 850 MHz (8.5 x 100)
Motherboard Name Unknown
Motherboard Chipset Intel Natoma 82440BX/ZX
System Memory 768 MB (SDRAM)
BIOS Type Phoenix (08/04/99)
Communication Port Communications Port (COM1)
Communication Port Communications Port (COM2)
Communication Port ECP Printer Port (LPT1)
Display:
Video Adapter NVIDIA RIVA TNT2 Model 64/Model 64 Pro (16 MB)
3D Accelerator 3Dfx Voodoo2
3D Accelerator ATI 3D-Rage Pro
3D Accelerator nVIDIA RIVA TNT2 M64
Monitor Samsung SyncMaster 900SL
Multimedia:
Audio Adapter Creative Labs SB Live! Value (CT4780) Sound Card
Audio Adapter Crystal PnP Audio System CODEC
Audio Adapter Crystal PnP Audio System Control Registers
Audio Adapter Crystal PnP Audio System MPU-401
Audio Adapter Rockwell Master Riptide Audio Device
Storage:
Floppy Drive Floppy disk drive
Disk Drive Maxtor 6E020L0
Disk Drive ST36811A
Optical Drive COMBO IDE5232CO
Optical Drive LG CD-ROM CRD-8400B (40x CD-ROM)
Partitions:
C: (NTFS) 6142 MB (238 MB free)
D: (NTFS) 19877 MB (12411 MB free)
Input:
Keyboard HID Keyboard Device
Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse HID-compliant mouse
Mouse PS/2 Compatible Mouse
Network:
Network Adapter 3Com 3C918 Integrated Fast Ethernet Controller (3C905B-TX Compatible) (192.168.137.237)
Peripherals:
USB Device USB Composite Device
USB Device USB Human Interface Device
Problems & Suggestions:
Problem Disk free space is only 4% on drive C:.
--------[ DMI ]---------------------------------------------------------------------------------------------------------
[ BIOS ]
BIOS Properties:
Vendor Dell Computer Corporation
Version A07
Release Date 08/04/99
Size 256 KB
Boot Devices Floppy Disk, Hard Disk, CD-ROM, ATAPI ZIP, LS-120
Capabilities Flash BIOS, Shadow BIOS, Selectable Boot, EDD
Supported Standards DMI, APM, ACPI, ESCD, PnP
Expansion Capabilities ISA, PCI, AGP
[ System ]
System Properties:
Manufacturer Dell Computer Corporation
Product OptiPlex GX1 800MTbr+
Universal Unique ID 44454C4C-00821033-804680C0-4F454448
Wake-Up Type Power Switch
[ Chassis ]
Chassis Properties:
Serial Number 3FEDH
Chassis Type Mini Tower
[ Processors / Processor #1 ]
Processor Properties:
Manufacturer Intel
External Clock 100 MHz
Maximum Clock 800 MHz
Current Clock 800 MHz
Type Central Processor
Voltage 3.3 V
Status Enabled
Upgrade Slot 1
Socket Designation Microprocessor
[ Caches / Cache #1 ]
Cache Properties:
Type Internal
Status Enabled
Operational Mode Varies with Memory Address
Maximum Size 32 KB
Installed Size 32 KB
Error Correction Single-bit ECC
[ Caches / Cache #2 ]
Cache Properties:
Type Internal
Status Enabled
Associativity 4-way Set-Associative
Maximum Size 512 KB
Installed Size 512 KB
Supported SRAM Type Synchronous, Pipeline Burst
Current SRAM Type Synchronous, Pipeline Burst
[ Memory Devices / DIMM_A ]
Memory Device Properties:
Form Factor DIMM
Type DRAM
Type Detail Synchronous
Size 256 MB
Total Width 64-bit
Data Width 64-bit
Device Locator DIMM_A
[ Memory Devices / DIMM_B ]
Form Factor DIMM
Type DRAM
Size 256 MB
Total Width 64-bit
Data Width 64-bit
Device Locator DIMM_B
[ Memory Devices / DIMM_C ]
Form Factor DIMM
Type DRAM
Size 256 MB
Total Width 64-bit
Data Width 64-bit
Device Locator DIMM_C
[ System Slots / PCI1 ]
System Slot Properties:
Slot Designation PCI1
Type PCI
Usage In Use
Data Bus Width 32-bit
Length Long
[ System Slots / PCI2 ]
Slot Designation PCI2
Type PCI
Usage In Use
Length Long
[ System Slots / PCI3 ]
Slot Designation PCI3
Type PCI
Usage Empty
Length Long
[ System Slots / PCI4 ]
Slot Designation PCI4
Type PCI
Usage Empty
Length Long
[ System Slots / PCI5 ]
Slot Designation PCI5
Type PCI
Usage Empty
Length Long
[ System Slots / ISA1 ]
Slot Designation ISA1
Type ISA
Data Bus Width 16-bit
Length Long
[ System Slots / ISA2 ]
Slot Designation ISA2
Type ISA
Length Long
[ System Slots / ISA3 ]
Slot Designation ISA3
Type ISA
Length Long
[ System Slots / ISA4 ]
Slot Designation ISA4
Type ISA
Length Long
[ Port Connectors / PARALLEL ]
Port Connector Properties:
Port Type Parallel Port PS/2
Internal Reference Designator PARALLEL
Internal Connector Type None
External Connector Type DB-25 pin female
[ Port Connectors / SERIAL1 ]
Port Type Serial Port 16550A Compatible
Internal Reference Designator SERIAL1
External Connector Type DB-9 pin male
[ Port Connectors / MOUSE ]
Port Type Mouse Port
Internal Reference Designator MOUSE
External Connector Type Mini-DIN
[ Port Connectors / KYBD ]
Port Type Keyboard Port
Internal Reference Designator KYBD
External Connector Type PS/2
[ Port Connectors / USB ]
Port Type USB
Internal Reference Designator USB
External Connector Type USB
[ Port Connectors / SERIAL2 ]
Internal Reference Designator SERIAL2
[ Port Connectors / MONITOR ]
Port Type Video Port
Internal Reference Designator MONITOR
External Connector Type DB-15 pin female
[ Port Connectors / ENET ]
Port Type Network Port
Internal Reference Designator ENET
External Connector Type RJ-45
[ Port Connectors / MIC ]
Port Type Audio Port
Internal Reference Designator MIC
External Connector Type Mini-jack (headphones)
[ Port Connectors / LINE-OUT ]
Internal Reference Designator LINE-OUT
[ Port Connectors / LINE-IN ]
Internal Reference Designator LINE-IN
[ On-Board Devices / Crystal 4236b Audio ]
On-Board Device Properties:
Description Crystal 4236b Audio
Type Video
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU Properties:
CPU Alias Coppermine, CuMine, A80526
Original Clock 850 MHz
L1 Code Cache 16 KB
L1 Data Cache 16 KB
L2 Cache 256 KB (On-Die, ATC, Full-Speed)
CPU Physical Info:
Package Type 370 Pin FC-PGA
Package Size 4.95 cm x 4.95 cm
Transistors 28.1 million
Process Technology 6M, 0.18 um, CMOS
Die Size 105 mm2
Core Voltage 1.6 - 1.75 V
I/O Voltage 3.3 V
Typical Power 11 - 18 W (depending on clock speed)
Maximum Power 16 - 26.9 W (depending on clock speed)
CPU Manufacturer:
Company Name Intel Corporation
Product Information http://www.intel.com/products/browse/processor.htm
CPU Utilization:
CPU #1 0 %
--------[ CPUID ]-------------------------------------------------------------------------------------------------------
CPUID Properties:
CPUID Manufacturer GenuineIntel
CPUID Revision 0686h
IA Brand ID 02h (Intel Pentium III)
Platform ID 05h (Socket 370)
IA CPU Serial Number 0000-0686-0000-802D-E76E-C222
MSR 00000017 3250-0000-0000-0000
MSR 0000002A 0000-0000-CD88-0000
MSR 0000011E 0000-0000-0074-27E1
Instruction Set:
AMD 3DNow! Not Supported
AMD 3DNow! Professional Not Supported
AMD Enhanced 3DNow! Not Supported
AMD Extended MMX Not Supported
AMD x86-64 Not Supported
Cyrix Extended MMX Not Supported
IA-64 Not Supported
IA MMX Supported
IA SSE Supported
IA SSE 2 Not Supported
CLFLUSH Instruction Not Supported
CMPXCHG8B Instruction Supported
Conditional Move Instruction Supported
CPUID Features:
36-bit Page Size Extension Supported
Automatic Clock Control Not Supported
Debug Trace Store Not Supported
Debugging Extension Supported
Fast Save & Restore Supported
Fast System Call Not Supported
Hyper-Threading Technology Not Supported
Local APIC On Chip Not Supported
Machine-Check Architecture Supported
Machine-Check Exception Supported
Memory Type Range Registers Supported
Model Specific Registers Supported
Page Attribute Table Supported
Page Global Extension Supported
Physical Address Extension Supported
Processor Duty Cycle Control Not Supported
Processor Serial Number Supported
Self-Snoop Not Supported
Time Stamp Counter Supported
Virtual Mode Extension Supported
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Motherboard Properties:
Motherboard ID Unknown
Front Side Bus Properties:
Bus Type Intel GTL+
Bus Width 64-bit
Real Clock 100 MHz
Effective Clock 100 MHz
Bandwidth 800 MB/s
Memory Bus Properties:
Bus Width 64-bit
Real Clock 100 MHz
Bandwidth 800 MB/s
--------[ Memory ]------------------------------------------------------------------------------------------------------
Physical Memory:
Total 767 MB
Used 195 MB
Free 572 MB
Utilization 25 %
Swap Space:
Total 1875 MB
Used 170 MB
Free 1705 MB
Utilization 9 %
Virtual Memory:
Total 2047 MB
Used 106 MB
Free 1941 MB
Utilization 5 %
--------[ SPD ]---------------------------------------------------------------------------------------------------------
[ 256 MB PC100 SDRAM ]
Memory Module Properties:
Module Size 256 MB (2 rows, 4 banks)
Module Type Unbuffered
Memory Type SDRAM
Memory Speed PC100 (100 MHz)
Module Width 64 bit
Module Voltage LVTTL
Error Detection Method None
Refresh Rate Normal (15.625 us), Self-Refresh
Highest CAS Latency 3.0 (10.0 ns @ 100 MHz)
2nd Highest CAS Latency 2.0 (10.0 ns @ 100 MHz)
Memory Module Features:
Early RAS# Precharge Not Supported
Auto-Precharge Supported
Precharge All Supported
Write1/Read Burst Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Not Supported
Redundant Row Address Not Supported
Memory Type SDRAM
Module Width 64 bit
Memory Type SDRAM
Module Width 64 bit
--------[ Chipset ]-----------------------------------------------------------------------------------------------------
Chipset Properties:
Memory Slots:
DRAM Slot #1 256 MB (SDRAM)
DRAM Slot #2 256 MB (SDRAM)
DRAM Slot #3 256 MB (SDRAM)
AGP Properties:
AGP Version 1.00
AGP Status Enabled
AGP Aperture Size 64 MB
Supported AGP Speeds 1x, 2x
Current AGP Speed 2x
Fast-Write Not Supported
Side Band Addressing Supported, Enabled
Chipset Manufacturer:
Product Information http://www.intel.com/products/browse/chipsets.htm
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type Phoenix
System BIOS Date 08/04/99
Video BIOS Date Unknown
BIOS Manufacturer:
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
Suggestion System BIOS is more than 2 years old. Update it if necessary.
--------[ Operating System ]--------------------------------------------------------------------------------------------
Operating System Properties:
OS Name Microsoft Windows 2000 Professional
OS Code Name Cairo
OS Language English (United States)
OS Kernel Type Uniprocessor Free
OS Version 5.0.2195 (Win2k Retail)
OS Installation Date 28-Apr-06
OS Root C:\WINNT
License Information:
Registered Owner Pickel
Registered Organization
Licensed Processors 2
Product ID 51873-000-0000025-00516
Product Key RBDC9-VTRC8-D7972-J97JY-PRVMG
Current Session:
User Name Pickel
UpTime 2282 sec (0 days, 0 hours, 38 min, 2 sec)
Components Version:
Common Controls 5.81
Internet Explorer 6.0.2800.1106 (IE 6 SP1)
Outlook Express 6.0.2800.1106
DirectX 4.09.00.0902 (DirectX 9)
ASPI None
ODBC 3.520.6307.0
Operating System Features:
Debug Version No
DBCS Version No
Security Present No
Network Present Yes
Remote Session No
Safe Mode No
Slow Processor No
--------[ Processes ]---------------------------------------------------------------------------------------------------
aida32.bin C:\Program Files\AIDA32\aida32.bin 11176 KB 11728 KB
CTHELPER.EXE C:\WINNT\system32\CTHELPER.EXE 4228 KB 1164 KB
Explorer.EXE C:\WINNT\Explorer.EXE 3096 KB 3404 KB
hidserv.exe C:\WINNT\system32\hidserv.exe 1824 KB 444 KB
inetinfo.exe C:\WINNT\system32\inetsrv\inetinfo.exe 9560 KB 5724 KB
internat.exe C:\WINNT\system32\internat.exe 1944 KB 436 KB
lsass.exe C:\WINNT\system32\lsass.exe 1236 KB 2228 KB
mqsvc.exe C:\WINNT\system32\mqsvc.exe 5572 KB 1816 KB
msdtc.exe C:\WINNT\System32\msdtc.exe 5976 KB 1896 KB
MSTask.exe C:\WINNT\system32\MSTask.exe 3720 KB 1076 KB
nvsvc32.exe C:\WINNT\system32\nvsvc32.exe 1660 KB 388 KB
PANTONE(R) colorist.exe C:\Program Files\Pantone Inc\PANTONE(R) colorist\PANTONE(R) colorist.exe KB 3148,K1164 KB
PhotoshopElementsDeviceConnect.exe D:\Program Files\Adobe\Photoshop Elements 3.0\PhotoshopElementsDeviceConnect.exe 2296 KB 612 KB
PhotoshopElementsFileAgent.exe D:\Program Files\Adobe\Photoshop Elements 3.0\PhotoshopElementsFileAgent.exe 2844 KB 704 KB
RefreshLock.exe C:\Program Files\RefreshLock\RefreshLock.exe 3044 KB 1280 KB
regsvc.exe C:\WINNT\system32\regsvc.exe 1356 KB 376 KB
RivaTuner.exe C:\Program Files\RivaTuner v2.0 RC 16\RivaTuner.exe 4580 KB 1880 KB
RUNDLL32.EXE C:\WINNT\system32\RUNDLL32.EXE 1964 KB 1564 KB
sdstat.exe C:\Program Files\SmartDisk\FlashPath\sdstat.exe 1776 KB 464 KB
services.exe C:\WINNT\system32\services.exe 6584 KB 3932 KB
smss.exe C:\WINNT\System32\smss.exe 420 KB 1084 KB
snmp.exe C:\WINNT\System32\snmp.exe 4296 KB 1580 KB
spoolsv.exe C:\WINNT\system32\spoolsv.exe 5288 KB 2688 KB
svchost.exe C:\WINNT\system32\svchost.exe 4508 KB 1476 KB
svchost.exe C:\WINNT\System32\svchost.exe 8708 KB 4016 KB
svchost.exe C:\WINNT\system32\svchost.exe 8532 KB 5096 KB
tcpsvcs.exe C:\WINNT\System32\tcpsvcs.exe 3280 KB 1044 KB
winlogon.exe C:\WINNT\system32\winlogon.exe 4232 KB 7060 KB
WinMgmt.exe C:\WINNT\System32\WBEM\WinMgmt.exe 664 KB 1120 KB
--------[ System Drivers ]----------------------------------------------------------------------------------------------
Abiosdsk Abiosdsk Kernel Driver Stopped
abp480n5 abp480n5 Kernel Driver Stopped
ACPI Microsoft ACPI Driver Kernel Driver Running
ACPIEC ACPIEC Kernel Driver Stopped
adpu160m adpu160m Kernel Driver Stopped
AFD AFD Networking Support Environment Kernel Driver Running
agp440 Intel AGP Bus Filter Kernel Driver Running
Aha154x Aha154x Kernel Driver Stopped
aic116x aic116x Kernel Driver Stopped
aic78u2 aic78u2 Kernel Driver Stopped
aic78xx aic78xx Kernel Driver Stopped
ami0nt ami0nt Kernel Driver Stopped
amsint amsint Kernel Driver Stopped
asc asc Kernel Driver Stopped
asc3350p asc3350p Kernel Driver Stopped
asc3550 asc3550 Kernel Driver Stopped
ASCTRM ASCTRM Kernel Driver Running
AsyncMac RAS Asynchronous Media Driver Kernel Driver Stopped
atapi Standard IDE/ESDI Hard Disk Controller Kernel Driver Running
Atdisk Atdisk Kernel Driver Stopped
atirage3 atirage3 Kernel Driver Stopped
Atmarpc ATM ARP Client Protocol Kernel Driver Stopped
audstub Audio Stub Driver Kernel Driver Running
Beep Beep Kernel Driver Running
BusLogic BusLogic Kernel Driver Stopped
CCDECODE Closed Caption Decoder Kernel Driver Stopped
cd20xrnt cd20xrnt Kernel Driver Stopped
Cdaudio Cdaudio Kernel Driver Stopped
Cdfs Cdfs File System Driver Running
Cdrom CD-ROM Driver Kernel Driver Running
Changer Changer Kernel Driver Stopped
Cpqarray Cpqarray Kernel Driver Stopped
cpqarry2 cpqarry2 Kernel Driver Stopped
cpqfcalm cpqfcalm Kernel Driver Stopped
cpqfws2e cpqfws2e Kernel Driver Stopped
crtaud Conexant Riptide WDM Audio Driver Kernel Driver Running
ctac32k Creative AC3 Software Decoder Kernel Driver Running
ctaud2k Creative Audio Driver (WDM) Kernel Driver Running
ctljystk Game Port for Creative SB Live! Kernel Driver Running
ctprxy2k Creative Proxy Driver Kernel Driver Running
ctsfm2k Creative SoundFont Management Device Driver Kernel Driver Running
cvspydr2 ColorVision Spyder 2 Kernel Driver Stopped
cwbmidi_device Crystal WDM MPU-401 UART Driver Kernel Driver Running
cwbwdm_device Crystal WDM Audio Codec Driver Kernel Driver Running
dac960nt dac960nt Kernel Driver Stopped
deckzpsx deckzpsx Kernel Driver Stopped
Disk Disk Driver Kernel Driver Running
Diskperf Diskperf Kernel Driver Running
dmboot dmboot Kernel Driver Stopped
dmio Logical Disk Manager Driver Kernel Driver Running
dmload dmload Kernel Driver Running
DMusic Microsoft DirectMusic SW Synth (WDM) Kernel Driver Stopped
EFS EFS File System Driver Running
EL90BC 3Com EtherLink XL B/C Adapter Driver Kernel Driver Running
emu10k Creative SB Live! Basic (WDM) Kernel Driver Stopped
emupia E-mu Plug-in Architecture Driver Kernel Driver Running
Fastfat Fastfat File System Driver Running
Fd16_700 Fd16_700 Kernel Driver Stopped
Fdc Floppy Disk Controller Driver Kernel Driver Running
Fips Fips Kernel Driver Running
fireport fireport Kernel Driver Stopped
FlashNT FlashNT Kernel Driver Running
flashpnt flashpnt Kernel Driver Stopped
Flpydisk Floppy Disk Driver Kernel Driver Running
FltMgr FltMgr File System Driver Running
Ftdisk Volume Manager Driver Kernel Driver Running
FUTUREX FUTUREX Kernel Driver Running
fxgpio Voodoo2 PCI Port I/O Kernel Driver Running
fxptl Voodoo2 Memory Mapper Kernel Driver Running
gameenum Conexant Riptide Joystick Driver Kernel Driver Running
Gpc Generic Packet Classifier Kernel Driver Running
ha10kx2k Creative Hardware Abstract Layer Driver Kernel Driver Running
hidusb Microsoft HID Class Driver Kernel Driver Running
i8042prt i8042 Keyboard and PS/2 Mouse Port Driver Kernel Driver Running
ini910u ini910u Kernel Driver Stopped
IntelIde IntelIde Kernel Driver Running
IpFilterDriver IP Traffic Filter Driver Kernel Driver Stopped
IpInIp IP in IP Tunnel Driver Kernel Driver Stopped
IpNat IP Network Address Translator Kernel Driver Stopped
IPSEC IPSEC driver Kernel Driver Running
ipsraidn ipsraidn Kernel Driver Stopped
IRENUM IR Enumerator Service Kernel Driver Stopped
isapnp PnP ISA/EISA Bus Driver Kernel Driver Running
Kbdclass Keyboard Class Driver Kernel Driver Running
kbdhid Keyboard HID Driver Kernel Driver Running
kmixer Microsoft Kernel Wave Audio Mixer Kernel Driver Stopped
KSecDD KSecDD Kernel Driver Running
lbrtfdc lbrtfdc Kernel Driver Stopped
lp6nds35 lp6nds35 Kernel Driver Stopped
mnmdd mnmdd Kernel Driver Running
Modem Modem Kernel Driver Stopped
Mouclass Mouse Class Driver Kernel Driver Running
mouhid Mouse HID Driver Kernel Driver Running
MountMgr MountMgr Kernel Driver Running
MPE BDA MPE Filter Kernel Driver Stopped
MQAC MSMQ access control Kernel Driver Running
mraid35x mraid35x Kernel Driver Stopped
MRxSmb MRxSmb File System Driver Running
Msfs Msfs File System Driver Running
MSKSSRV Microsoft Streaming Service Proxy Kernel Driver Stopped
MSPCLOCK Microsoft Streaming Clock Proxy Kernel Driver Stopped
MSPQM Microsoft Streaming Quality Manager Proxy Kernel Driver Stopped
MSTEE Microsoft Streaming Tee/Sink-to-Sink Converter Kernel Driver Stopped
Mup Mup File System Driver Running
NABTSFEC NABTS/FEC VBI Codec Kernel Driver Stopped
Ncrc710 Ncrc710 Kernel Driver Stopped
NDIS NDIS System Driver Kernel Driver Running
NdisTapi Remote Access NDIS TAPI Driver Kernel Driver Running
Ndisuio NDIS Usermode I/O Protocol Kernel Driver Stopped
NdisWan Remote Access NDIS WAN Driver Kernel Driver Running
NDProxy NDIS Proxy Kernel Driver Running
NetBIOS NetBIOS Interface File System Driver Running
NetBT NetBios over Tcpip Kernel Driver Running
NetDetect NetDetect Kernel Driver Stopped
Npfs Npfs File System Driver Running
Ntfs Ntfs File System Driver Running
Ntremap Voodoo2 Board Remapper Kernel Driver Running
Null Null Kernel Driver Running
nv nv Kernel Driver Running
nv4 nv4 Kernel Driver Stopped
NwlnkFlt IPX Traffic Filter Driver Kernel Driver Stopped
NwlnkFwd IPX Traffic Forwarder Driver Kernel Driver Stopped
ossrv Creative OS Services Driver Kernel Driver Running
Parallel Parallel class driver Kernel Driver Running
Parport Parallel port driver Kernel Driver Running
PartMgr PartMgr Kernel Driver Running
ParVdm ParVdm Kernel Driver Running
PCI PCI Bus Driver Kernel Driver Running
PCIDump PCIDump Kernel Driver Stopped
PCIIde PCIIde Kernel Driver Stopped
Pcmcia Pcmcia Kernel Driver Stopped
PfModNT PfModNT Kernel Driver Running
PptpMiniport WAN Miniport (PPTP) Kernel Driver Running
Ptilink Direct Parallel Link Driver Kernel Driver Running
PxHelp20 PxHelp20 Kernel Driver Running
ql1080 ql1080 Kernel Driver Stopped
Ql10wnt Ql10wnt Kernel Driver Stopped
ql1240 ql1240 Kernel Driver Stopped
ql2100 ql2100 Kernel Driver Stopped
RasAcd Remote Access Auto Connection Driver Kernel Driver Running
Rasl2tp WAN Miniport (L2TP) Kernel Driver Running
Raspti Direct Parallel Kernel Driver Running
RCA Microsoft Streaming Network Raw Channel Access Kernel Driver Stopped
Rdbss Rdbss File System Driver Running
redbook Digital CD Audio Playback Filter Driver Kernel Driver Stopped
RivaTuner32 RivaTuner32 Kernel Driver Running
rpfun Conexant Riptide Dummy Driver Kernel Driver Running
rthwcls Conexant Riptide Bus / Firmware Downloader Kernel Driver Running
Sdselect Sdselect Kernel Driver Running
Secdrv Secdrv Kernel Driver Stopped
serenum Serenum Filter Driver Kernel Driver Running
Serial Serial port driver Kernel Driver Running
Sfloppy Sfloppy Kernel Driver Stopped
sglfb sglfb Kernel Driver Stopped
Simbad Simbad Kernel Driver Stopped
SLIP BDA Slip De-Framer Kernel Driver Stopped
Sparrow Sparrow Kernel Driver Stopped
Srv Srv File System Driver Running
streamip BDA IPSink Kernel Driver Stopped
swenum Software Bus Driver Kernel Driver Running
swmidi Microsoft Software Synthesizer Kernel Driver Stopped
sym_hi sym_hi Kernel Driver Stopped
symc810 symc810 Kernel Driver Stopped
symc8xx symc8xx Kernel Driver Stopped
sysaudio Microsoft System Audio Device Kernel Driver Running
Tcpip TCP/IP Protocol Driver Kernel Driver Running
tga tga Kernel Driver Stopped
Udfs Udfs File System Driver Running
uhcd Microsoft USB Universal Host Controller Driver Kernel Driver Running
ultra66 ultra66 Kernel Driver Stopped
Update Microcode Update Driver Kernel Driver Running
usbhub Microsoft USB Standard Hub Driver Kernel Driver Running
VgaSave VgaSave Kernel Driver Running
Wanarp Remote Access IP ARP Driver Kernel Driver Running
wdmaud Microsoft WDM Virtual Wave Driver Kernel Driver Running
WSTCODEC World Standard Teletext Codec Kernel Driver Stopped
--------[ Windows Video ]-----------------------------------------------------------------------------------------------
[ NVIDIA RIVA TNT2 Model 64/Model 64 Pro ]
Video Adapter Properties:
Device Description NVIDIA RIVA TNT2 Model 64/Model 64 Pro
Adapter String RIVA TNT2 Model 64/Model 64 Pro
BIOS String Version 2.05.17.01.00
Chip Type RIVA TNT2 Model 64/Model 64 Pro
DAC Type Integrated RAMDAC
Installed Drivers nv4_disp
Memory Size 16 MB
Video Adapter Manufacturer:
Company Name NVIDIA Corporation
Product Information http://www.nvidia.com/view.asp?PAGE=products
Driver Download http://www.nvidia.com/view.asp?PAGE=drivers
--------[ PCI / AGP Video ]---------------------------------------------------------------------------------------------
ATI 3D-Rage Pro Video Adapter
nVIDIA RIVA TNT2 M64 Video Adapter
3Dfx Voodoo2 3D Accelerator
ATI 3D-Rage Pro 3D Accelerator
nVIDIA RIVA TNT2 M64 3D Accelerator
3Dfx Voodoo2 3D Accelerator Multimedia Video
--------[ GPU ]---------------------------------------------------------------------------------------------------------
Graphics Processor Properties:
Video Adapter nVIDIA RIVA TNT2 M64
GPU Code Name NV5M64
PCI Device 10DE / 002D
Process Technology 0.25u
Bus Type PCI
Memory Size 16 MB
GPU Clock 180 MHz
RAMDAC Clock 300 MHz
Pixel Pipelines 2
TMU Per Pipeline 1
Vertex Shaders Not Supported
Pixel Shaders Not Supported
Pixel Fillrate 360 MPixel/s
Texel Fillrate 360 MTexel/s
Bus Type SDR
Bus Width 64-bit
Real Clock 200 MHz
Effective Clock 200 MHz
Bandwidth 1600 MB/s
nVIDIA Registers:
nv-100000 00000023
nv-100200 00701114
nv-10020C 896DDF9D
nv-101000 80009FC3
nv-680500 0001B007
nv-680504 00000E01
--------[ Monitor ]-----------------------------------------------------------------------------------------------------
[ Samsung SyncMaster 900SL ]
Monitor Properties:
Monitor Name Samsung SyncMaster 900SL
Monitor ID SAM4DB9
Model S/M 900SL
Manufacture Date Week 2 / 2000
Serial Number H3NN100881
Max. Visible Display Size 36 cm x 27 cm (17.7")
Picture Aspect Ratio 4:3
Horizontal Frequency 30 - 96 kHz
Vertical Frequency 50 - 160 Hz
Maximum Resolution 1600 x 1200
Gamma 2.28
DPMS Mode Support Standby, Suspend, Active-Off
Supported Video Modes:
640 x 480 160 Hz
800 x 600 150 Hz
1024 x 768 115 Hz
1152 x 864 105 Hz
1280 x 1024 85 Hz
1600 x 1200 75 Hz
Monitor Manufacturer:
Company Name Samsung Electronics Co., Ltd.
Product Information http://www.samsungelectronics.com/monitor
Driver Download http://www.samsungelectronics.com/monitor/support/downloads
--------[ Desktop ]-----------------------------------------------------------------------------------------------------
Desktop Properties:
Device Technology Raster Display
Resolution 800 x 600
Color Depth 16-bit
Color Planes 1
Font Resolution 96 dpi
Pixel Width / Height 36 / 36
Pixel Diagonal 51
Vertical Refresh Rate 144 Hz
Desktop Wallpaper C:\WINNT\Wallpapers\TREEISLE.bmp
Desktop Effects:
Combo-Box Animation Enabled
Drop Shadow Effect Disabled
Flat Menu Effect Disabled
Font Smoothing Disabled
Full Window Dragging Enabled
Gradient Window Title Bars Enabled
Hide Menu Access Keys Enabled
Hot Tracking Effect Enabled
Icon Title Wrapping Enabled
List-Box Smooth Scrolling Enabled
Menu Animation Enabled
Menu Fade Effect Enabled
Minimize/Restore Animation Enabled
Mouse Cursor Shadow Enabled
Selection Fade Effect Enabled
ShowSounds Accessibility Feature Disabled
ToolTip Animation Enabled
ToolTip Fade Effect Enabled
Windows Plus! Extension Disabled
Problem Some applications may run better in 32-bit color mode.
--------[ Multi-Monitor ]-----------------------------------------------------------------------------------------------
\\.\DISPLAY1 Yes (0,0) (800,600)
--------[ Windows Audio ]-----------------------------------------------------------------------------------------------
midi-in.0 0001 0067 Crystal MPU-401
midi-in.1 0001 0067 SB Live! MIDI Port [DCC0]
midi-in.2 0001 0067 Riptide MPU401
midi-out.0 0001 0066 Crystal FM Synthesizer
midi-out.1 0001 0066 Microsoft GS Wavetable SW Synth
midi-out.2 0001 0066 Crystal MPU-401
midi-out.3 0001 0066 SB Live! Sw Synth [DCC0]
midi-out.4 0001 0066 SB Live! Synth A [DCC0]
midi-out.5 0001 0066 SB Live! Synth B [DCC0]
midi-out.6 0001 0066 SB Live! MIDI Port [DCC0]
midi-out.7 0001 0066 Riptide MPU401
mixer.0 0001 0068 Crystal WDM Audio
mixer.1 0001 0068 SB Live! Audio [DCC0]
mixer.2 0001 0068 Conexant Audio
wave-in.0 0001 0065 Crystal WDM Audio
wave-in.1 0001 0065 SB Live! Audio [DCC0]
wave-in.2 0001 0065 Conexant Audio
wave-out.0 0001 0064 Crystal WDM Audio
wave-out.1 0001 0064 SB Live! Audio [DCC0]
wave-out.2 0001 0064 Conexant Audio
--------[ PCI / PnP Audio ]---------------------------------------------------------------------------------------------
Creative Labs SB Live! Value (CT4780) Sound Card PCI
Rockwell Master Riptide Audio Device PCI
Crystal PnP Audio System CODEC PnP
Crystal PnP Audio System Control Registers PnP
Crystal PnP Audio System MPU-401 PnP
--------[ ACM ]---------------------------------------------------------------------------------------------------------
[ DSP Group TrueSpeech(TM) Software CODEC ]
ACM Driver Properties:
Driver Description DSP Group TrueSpeech(TM) Software CODEC
Copyright Notice Copyright (C) 1993-1996 DSP Group, Inc.
License Information TrueSpeech is a trademark of DSP Group, Inc., Santa Clara, California.
Driver Features Compresses and decompresses DSP Group TrueSpeech(TM) audio data.
Driver Version 1.00
[ Fraunhofer IIS MPEG Layer-3 Codec (advanced) ]
Driver Description Fraunhofer IIS MPEG Layer-3 Codec (advanced)
Copyright Notice Copyright © 1996-1999 Fraunhofer Institut Integrierte Schaltungen IIS
Driver Features bitrates up to 56kBit/s, mono and stereo codec (advanced)
Driver Version 1.09
[ Indeo® audio software ]
Driver Description Indeo® audio software
Copyright Notice Copyright © 1997 Intel Corporation
Driver Features Indeo® audio software
Driver Version 2.05
[ Lernout & Hauspie CODECs ]
Driver Description Lernout & Hauspie CODECs
Copyright Notice Copyright (c) 1996 Lernout & Hauspie Speech Software Codecs NV and Microsoft Co
License Information
Driver Features Lernout & Hauspie (TM) Speech Products Voice Compression. Compresses and decompresses Lernout & Hauspie audio data.
Driver Version 1.00
[ Microsoft ADPCM CODEC ]
Driver Description Microsoft ADPCM CODEC
Copyright Notice Copyright (C) 1992-1996 Microsoft Corporation
Driver Features Compresses and decompresses Microsoft ADPCM audio data.
Driver Version 4.00
[ Microsoft CCITT G.711 A-Law and u-Law CODEC ]
Driver Description Microsoft CCITT G.711 A-Law and u-Law CODEC
Copyright Notice Copyright (c) 1993-1996 Microsoft Corporation
Driver Features Compresses and decompresses CCITT G.711 A-Law and u-Law audio data.
Driver Version 4.00
[ Microsoft G.723.1 CODEC ]
Driver Description Microsoft G.723.1 CODEC
Copyright Notice Copyright © 1996 Intel Corporation and Microsoft Corporation
Driver Features Compresses and decompresses G.723.1 audio data.
Driver Version 1.02
[ Microsoft GSM 6.10 Audio CODEC ]
Driver Description Microsoft GSM 6.10 Audio CODEC
Copyright Notice Copyright (C) 1993-1996 Microsoft Corporation
Driver Features Compresses and decompresses audio data conforming to the ETSI-GSM (European Telecommunications Standards Institute-Groupe Special Mobile) recommendation 6.10.
Driver Version 4.00
[ Microsoft IMA ADPCM CODEC ]
Driver Description Microsoft IMA ADPCM CODEC
Driver Features Compresses and decompresses IMA ADPCM audio data.
Driver Version 4.00
[ Microsoft PCM Converter ]
Driver Description Microsoft PCM Converter
Driver Features Converts frequency and bits per sample of PCM audio data.
Driver Version 5.00
[ Sipro Lab Telecom ACELP.net audio codec ]
Driver Description Sipro Lab Telecom ACELP.net audio codec
Copyright Notice Copyright © 1995-99 Sipro Lab Telecom Inc., Montreal
Driver Features ACELP.net audio encoder/decoder. For licensing please access HTTP: //www.sipro.com
Driver Version 2.08
[ Windows Media Audio ]
Driver Description Windows Media Audio
Copyright Notice Copyright (C) Microsoft Corporation, 1999 - 1999
Driver Features Compresses and decompresses audio data.
Driver Version 4.02
--------[ VCM ]---------------------------------------------------------------------------------------------------------
frapsvid.dll Fraps Video Decompressor
iccvid.dll Cinepak® Codec
ir32_32.dll
ir50_32.dll Indeo® video 5.10
mpg4c32.dll Microsoft MPEG-4 Video Codec v1
msh261.drv Microsoft H.261 ICM Driver
msh263.drv Microsoft H.263 ICM Driver
msrle32.dll Microsoft RLE Compressor
msvidc32.dll Microsoft Video 1 Compressor
msyuv.dll Microsoft UYVY Video Decompressor
--------[ Windows Storage ]---------------------------------------------------------------------------------------------
[ Floppy disk drive ]
Device Properties:
Driver Description Floppy disk drive
Driver Date 14-Nov-99
Driver Version 5.0.2183.1
Driver Provider Microsoft
INF File flpydisk.inf
Device Properties:
[ Maxtor 6E020L0 ]
Device Properties:
Driver Description Maxtor 6E020L0
INF File disk.inf
Device Manufacturer:
Company Name Maxtor Corporation
Product Information http://www.maxtor.com/en/products/
[ ST36811A ]
Device Properties:
Driver Description ST36811A
INF File disk.inf
Company Name Seagate Technology LLC
Product Information http://www.seagate.com/products/discsales
[ COMBO IDE5232CO ]
Device Properties:
Driver Description COMBO IDE5232CO
INF File cdrom.inf
[ LG CD-ROM CRD-8400B ]
Device Properties:
Driver Description LG CD-ROM CRD-8400B
INF File cdrom.inf
Optical Drive Properties:
Manufacturer LG
Device Type CD-ROM
Speed 40x
Company Name LG Electronics
Product Information http://www.lge.com/c_product/pc/optical.jsp?c … navigation=1,18
[ Intel(r) 82371AB/EB PCI Bus Master IDE Controller ]
Device Properties:
Driver Description Intel(r) 82371AB/EB PCI Bus Master IDE Controller
Driver Date 19-Jun-03
INF File mshdc.inf
Device Resources:
Port FFA0-FFAF
[ Primary IDE Channel ]
Device Properties:
Driver Description Primary IDE Channel
INF File mshdc.inf
Device Resources:
IRQ 0E
Port 01F0-01F7
Port 03F6-03F6
[ Secondary IDE Channel ]
Device Properties:
Driver Description Secondary IDE Channel
INF File mshdc.inf
Device Resources:
IRQ 0F
Port 0170-0177
Port 0376-0376
--------[ Logical Drives ]----------------------------------------------------------------------------------------------
A: Removable Disk
C: Local Disk NTFS 04F9-8936 6142 MB 238 MB 4 %
D: (Stuff) Local Disk NTFS 8443-A211 19877 MB 12411 MB 62 %
E: Optical Drive
F: Optical Drive
--------[ Physical Drives ]---------------------------------------------------------------------------------------------
[ Drive #1 (6150 MB) ]
#1 (Active) NTFS C: 0 MB 6142 MB
[ Drive #2 (19.4 GB) ]
#1 NTFS D: (Stuff) 0 MB 19877 MB
--------[ Optical Drives ]----------------------------------------------------------------------------------------------
COMBO IDE5232CO ? ? ?
LG CD-ROM CRD-8400B LG CD-ROM 40x
--------[ ASPI ]--------------------------------------------------------------------------------------------------------
00 00 00 Disk Drive ST36811A
00 01 00 Disk Drive Maxtor 6 E020L0
00 07 00 Host Adapter atapi
01 00 00 Optical Drive COMBO ID E5232CO
01 01 00 Optical Drive LG CD-RO M CRD-8400B
01 07 00 Host Adapter atapi
--------[ EIDE ]--------------------------------------------------------------------------------------------------------
[ ST36811A (6CS0QZQE) ]
EIDE Device Properties:
Model ID ST36811A
Serial Number 6CS0QZQE
Revision 3.09
Parameters 13328 cylinders, 15 heads, 63 sectors per track, 512 bytes per sector
LBA Sectors 12594960
Buffer 512 KB
Multiple Sectors 32
ECC Bytes 4
Max. PIO Transfer Mode PIO 4
Max. UDMA Transfer Mode UDMA 4 (ATA-66)
Active UDMA Transfer Mode UDMA 2 (ATA-33)
Unformatted Capacity 6150 MB
EIDE Device Features:
SMART Supported
Security Mode Supported
Power Management Supported
Advanced Power Management Supported
Write Cache Supported
Host Protected Area Supported
Power-Up In Standby Not Supported
Automatic Acoustic Management Not Supported
48-bit LBA Not Supported
Device Configuration Overlay Not Supported
EIDE Device Manufacturer:
[ Maxtor 6E020L0 (E11Z3H9E) ]
Model ID Maxtor 6E020L0
Serial Number E11Z3H9E
Revision NAR61590
Parameters 40395 cylinders, 16 heads, 63 sectors per track, 512 bytes per sector
LBA Sectors 40718160
Buffer 2 MB (Dual Ported, Read Ahead)
Multiple Sectors 16
ECC Bytes 57
Max. UDMA Transfer Mode UDMA 6 (ATA-133)
Unformatted Capacity 19882 MB
SMART Supported
Automatic Acoustic Management Supported
Device Configuration Overlay Supported
--------[ SMART ]-------------------------------------------------------------------------------------------------------
01 Raw Read Error Rate 0 91 86 234228211 OK: Always passing
03 Spin Up Time 0 98 98 0 OK: Always passing
04 Start/Stop Count 20 92 92 8578 OK: Value is normal
05 Reallocated Sector Count 36 100 100 22 OK: Value is normal
07 Seek Error Rate 30 69 60 16948216 OK: Value is normal
09 Power-On Time Count 0 85 85 13608 OK: Always passing
0A Spin Retry Count 90 100 99 0 OK: Value is normal
0C Power Cycle Count 0 100 100 533 OK: Always passing
C5 Current Pending Sector Count 0 100 100 0 OK: Always passing
C6 Off-Line Uncorrectable Sector Count 0 100 100 0 OK: Always passing
C7 Ultra ATA CRC Error Rate 0 200 200 0 OK: Always passing
--------[ Keyboard ]----------------------------------------------------------------------------------------------------
Keyboard Properties:
Keyboard Name HID Keyboard Device
Keyboard Type IBM enhanced (101- or 102-key) keyboard
Keyboard Layout US
ANSI Code Page 1252
OEM Code Page 437
Repeat Delay 1
Repeat Rate 31
--------[ Mouse ]-------------------------------------------------------------------------------------------------------
Mouse Properties:
Mouse Name HID-compliant mouse
Mouse Buttons 16
Mouse Hand Right
Pointer Speed 0
Double-Click Time 500 msec
X/Y Threshold 0 / 0
Wheel Scroll Lines 3
Mouse Features:
Active Window Tracking Disabled
ClickLock Disabled
Hide Pointer While Typing Disabled
Mouse Wheel Present
Move Pointer To Default Button Disabled
Pointer Trails Disabled
Sonar Disabled
--------[ Windows Network ]---------------------------------------------------------------------------------------------
[ 3Com 3C918 Integrated Fast Ethernet Controller (3C905B-TX Compatible) ]
Network Adapter Properties:
Interface Type Ethernet
Hardware Address 00-B0-D0-4B-BF-D7
Connection Name Local Area Connection
Connection Speed 100 Mbps
MTU 1500 bytes
Bytes Received 690842 (674.7 KB)
Bytes Sent 13340 (13.0 KB)
Network Adapter Addresses:
IP / Subnet Mask 192.168.137.237 / 255.255.255.0
Gateway 192.168.137.1
DHCP 192.168.137.1
Network Adapter Manufacturer:
Company Name 3Com Corporation
Product Information http://www.3com.com/products/en_US/prodlist.j … ds+%26+Adapters
Driver Download http://www.3com.com/products/en_US/downloadsindex.jsp
--------[ PCI / PnP Network ]-------------------------------------------------------------------------------------------
3Com 3C905B-TX Fast EtherLink XL 10/100 Adapter PCI
--------[ IAM ]---------------------------------------------------------------------------------------------------------
[ Active Directory ]
Account Properties:
Account Name Active Directory
Account ID Active Directory GC
Account Type LDAP (Default)
Connection Name Not Specified (IE Default)
LDAP Server NULL:3268
LDAP User Name NULL
LDAP Search Base NULL
LDAP Search Timeout 1 min
Account Features:
LDAP Authentication Required Yes
LDAP Secure Authentication Yes
LDAP Secure Connection No
LDAP Simple Search Filter No
[ Bigfoot Internet Directory Service ]
Account Properties:
Account Name Bigfoot Internet Directory Service
Account ID Bigfoot
Account Type LDAP
LDAP Server ldap.bigfoot.com
LDAP URL http://www.bigfoot.com
Account Features:
LDAP Authentication Required No
LDAP Secure Authentication No
LDAP Simple Search Filter Yes
[ InfoSpace Business Directory Service ]
Account Properties:
Account Name InfoSpace Business Directory Service
Account ID InfoSpace Business
Account Type LDAP
LDAP Server ldapbiz.infospace.com
LDAP URL http://www.infospace.com
Account Features:
[ InfoSpace Internet Directory Service ]
Account Properties:
Account Name InfoSpace Internet Directory Service
Account Type LDAP
LDAP Server ldap.infospace.com
Account Features:
[ Switchboard Internet Directory Service ]
Account Properties:
Account Name Switchboard Internet Directory Service
Account ID Switchboard
Account Type LDAP
LDAP Server ldap.switchboard.com
LDAP URL http://www.switchboard.com
Account Features:
[ VeriSign Internet Directory Service ]
Account Properties:
Account Name VeriSign Internet Directory Service
Account ID VeriSign
Account Type LDAP
LDAP Server directory.verisign.com
LDAP URL http://www.verisign.com
Account Features:
[ WhoWhere Internet Directory Service ]
Account Properties:
Account Name WhoWhere Internet Directory Service
Account ID WhoWhere
Account Type LDAP
LDAP Server ldap.whowhere.com
LDAP URL http://www.whowhere.com
Account Features:
[ Yahoo! People Search ]
Account Properties:
Account Name Yahoo! People Search
Account ID Yahoo!
Account Type LDAP
LDAP Server ldap.yahoo.com
LDAP URL http://www.yahoo.com/search/people
Account Features:
--------[ Internet ]----------------------------------------------------------------------------------------------------
Internet Settings:
Start Page http://www.msn.com
Search Page http://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
Download Folder
Current Proxy:
Proxy Status Disabled
LAN Proxy:
--------[ DirectX Files ]-----------------------------------------------------------------------------------------------
amstream.dll 6.05.01.0900 Final Retail English 64512 12-Dec-02 00:14:32
bdaplgin.ax 5.03.00.0900 Final Retail English 16896 17-Feb-03 10:14:32
bdasup.sys 5.03.00.0900 Final Retail English 11392 17-Feb-03 10:14:32
ccdecode.sys 5.03.00.0900 Final Retail English 16384 17-Feb-03 10:14:32
d3d8.dll 5.03.00.0900 Final Retail English 1177600 12-Dec-02 00:14:32
d3dim.dll 5.00.2180.0001 Final Retail English 446224 12-Dec-02 00:14:32
d3dim700.dll 5.03.01.0902 Final Retail English 797184 30-May-03 09:00:02
d3dpmesh.dll 5.00.2134.0001 Final Retail English 37648 12-Dec-02 00:14:32
d3dramp.dll 5.00.2180.0001 Final Retail English 591120 12-Dec-02 00:14:32
d3dref.dll 5.00.2180.0001 Final Retail English 93456 06-Dec-99 23:00:00
d3drm.dll 5.00.2134.0001 Final Retail English 364816 12-Dec-02 00:14:32
d3dxof.dll 5.00.2135.0001 Final Retail English 49424 12-Dec-02 00:14:32
ddraw.dll 5.03.00.0900 Final Retail English 284160 12-Dec-02 00:14:32
ddrawex.dll 5.00.2134.0001 Final Retail English 24336 06-Dec-99 23:00:00
devenum.dll 6.05.01.0902 Final Retail English 132608 30-May-03 09:00:02
diactfrm.dll 5.01.2600.0881 Final Retail English 459264 30-Oct-01 08:10:00
dimap.dll 5.01.2600.0881 Final Retail English 44032 30-Oct-01 08:10:00
dinput.dll 5.01.2600.0881 Final Retail English 645120 30-Oct-01 08:10:00
dinput8.dll 5.01.2600.0881 Final Retail English 664576 30-Oct-01 08:10:00
dmband.dll 5.03.00.0900 Final Retail English 27136 12-Dec-02 00:14:32
dmcompos.dll 5.03.00.0900 Final Retail English 58368 12-Dec-02 00:14:32
dmime.dll 5.03.00.0900 Final Retail English 171520 12-Dec-02 00:14:32
dmloader.dll 5.03.00.0900 Final Retail English 33280 12-Dec-02 00:14:32
dmscript.dll 5.03.00.0900 Final Retail English 76800 12-Dec-02 00:14:32
dmstyle.dll 5.03.00.0900 Final Retail English 98816 12-Dec-02 00:14:32
dmsynth.dll 5.03.00.0900 Final Retail English 100864 12-Dec-02 00:14:32
dmusic.dll 5.03.00.0900 Final Retail English 116736 12-Dec-02 00:14:32
dplaysvr.exe 5.03.00.0900 Final Retail English 28160 12-Dec-02 00:14:32
dplayx.dll 5.03.00.0903 Final Retail English 219648 14-Apr-04 14:56:46
dpmodemx.dll 5.03.00.0900 Final Retail English 77824 12-Dec-02 00:14:32
dpnaddr.dll 5.03.00.0900 Final Retail English 3072 12-Dec-02 00:14:32
dpnet.dll 5.03.00.0900 Final Retail English 723968 12-Dec-02 00:14:32
dpnhpast.dll 5.03.00.0901 Final Retail English 32768 24-Mar-03 09:00:02
dpnhupnp.dll 5.03.00.0901 Final Retail English 68096 24-Mar-03 09:00:02
dpnlobby.dll 5.03.00.0900 Final Retail English 3072 12-Dec-02 00:14:32
dpnsvr.exe 5.03.00.0900 Final Retail English 16896 12-Dec-02 00:14:32
dpvacm.dll 5.03.00.0900 Final Retail English 19968 12-Dec-02 00:14:32
dpvoice.dll 5.03.00.0900 Final Retail English 381952 12-Dec-02 00:14:32
dpvsetup.exe 5.03.00.0900 Final Retail English 80896 12-Dec-02 00:14:32
dpvvox.dll 5.03.00.0900 Final Retail English 112128 12-Dec-02 00:14:32
dpwsockx.dll 5.03.00.0903 Final Retail English 76800 12-Apr-04 23:11:26
dsdmo.dll 5.03.00.0900 Final Retail English 186880 12-Dec-02 00:14:32
dsdmoprp.dll 5.03.00.0900 Final Retail English 491520 12-Dec-02 00:14:32
dsound.dll 5.03.00.0900 Final Retail English 355328 12-Dec-02 00:14:32
dsound3d.dll 5.03.00.0900 Final Retail English 1294336 12-Dec-02 00:14:32
dswave.dll 5.03.00.0900 Final Retail English 18432 12-Dec-02 00:14:32
dx7vb.dll 5.03.00.0900 Final Retail English 602624 12-Dec-02 00:14:32
dx8vb.dll 5.03.01.0902 Final Retail English 1189888 30-May-03 09:00:02
dxapi.sys 5.00.2180.0001 Final Retail English 10064 15-Dec-99
dxmasf.dll 6.04.09.1133 Final Retail English 498742 22-Aug-06 04:05:26
gameenum.sys 5.00.2195.6655 Final Retail English 9808 19-Jun-03 12:05:04
gcdef.dll 5.01.2600.0881 Final Retail English 206336 30-Oct-01 08:10:00
iac25_32.ax 2.00.05.0053 Beta Retail English 199680 06-Dec-99 23:00:00
ipsink.ax 5.03.00.0900 Final Retail English 14848 17-Feb-03 10:14:32
ir41_32.ax 4.51.16.0003 Final Retail English 848384 06-Dec-99 23:00:00
ir41_qc.dll 4.30.62.0002 Final Retail English 120320 06-Dec-99 23:00:00
ir41_qcx.dll 4.30.64.0001 Final Retail English 338432 13-Dec-03 22:33:18
ir50_32.dll 5.2562.15.0055 Final Retail English 755200 06-Dec-99 23:00:00
ir50_qc.dll 5.00.63.0048 Final Retail English 200192 06-Dec-99 23:00:00
ir50_qcx.dll 5.00.64.0048 Final Retail English 183808 06-Dec-99 23:00:00
ivfsrc.ax 5.10.02.0051 Final Retail English 154624 06-Dec-99 23:00:00
joy.cpl 5.01.2600.0881 Final Retail English 326144 30-Oct-01 08:10:00
ks.sys 5.03.00.0900 Final Retail English 130304 12-Dec-02 00:14:32
ksproxy.ax 5.03.00.0900 Final Retail English 117248 12-Dec-02 00:14:32
kstvtune.ax 5.03.01.0902 Final Retail English 274432 04-Jun-03 10:30:32
ksuser.dll 5.03.00.0900 Final Retail English 4096 12-Dec-02 00:14:32
kswdmcap.ax 5.03.00.0900 Final Retail English 226304 17-Feb-03 10:14:42
ksxbar.ax 5.03.01.0902 Final Retail English 39424 04-Jun-03 09:18:28
mciqtz32.dll 6.05.01.0900 Final Retail English 34304 12-Dec-02 00:14:32
mfc40.dll 4.01.00.6140 Final Retail English 924432 06-Dec-99 23:00:00
mfc42.dll 6.00.9586.0000 Beta Retail English 1015859 19-Jun-03 12:05:04
mpe.sys 5.03.00.0900 Final Retail English 15104 17-Feb-03 10:14:32
mpg2splt.ax 6.05.01.0900 Final Retail English 136192 12-Dec-02 00:14:32
msdmo.dll 6.05.01.0900 Final Retail English 13312 12-Dec-02 00:14:32
msdv.sys 5.03.00.0900 Final Retail English 56832 17-Feb-03 10:14:32
msdvbnp.ax 6.05.01.0900 Final Retail English 52224 17-Feb-03 10:14:32
mskssrv.sys 5.03.00.0900 Final Retail English 7424 12-Dec-02 00:14:32
mspclock.sys 5.03.00.0900 Final Retail English 5248 12-Dec-02 00:14:32
mspqm.sys 5.00.2134.0001 Final Retail English 4816 25-Sep-99 05:36:32
mstee.sys 5.03.00.0900 Final Retail English 5504 12-Dec-02 00:14:32
msvidctl.dll 6.05.01.0900 Final Retail English 480256 17-Feb-03 10:14:36
mswebdvd.dll 6.05.01.0900 Final Retail English 324096 12-Dec-02 00:14:32
msyuv.dll 5.03.00.0901 Final Retail English 16896 24-Nov-09 17:24:28
nabtsfec.sys 5.03.00.0900 Final Retail English 83968 17-Feb-03 10:14:34
ndisip.sys 5.03.00.0900 Final Retail English 10112 17-Feb-03 10:14:34
pid.dll 5.01.2600.0881 Final Retail English 31744 30-Oct-01 08:10:00
psisdecd.dll 6.05.01.0900 Final Retail English 354816 17-Feb-03 10:14:34
psisrndr.ax 6.05.01.0900 Final Retail English 30208 17-Feb-03 10:14:34
qasf.dll 9.00.00.2980 Final Retail English 241664 11-Dec-02 17:34:40
qcap.dll 6.05.01.0900 Final Retail English 257024 12-Dec-02 00:14:32
qdv.dll 6.05.01.0900 Final Retail English 311808 12-Dec-02 00:14:32
qdvd.dll 6.05.01.0902 Final Retail English 449024 30-May-03 09:00:02
qedit.dll 6.05.01.0900 Final Retail English 1798144 12-Dec-02 00:14:32
qedwipes.dll 6.05.01.0900 Final Retail English 733184 12-Dec-02 00:14:32
quartz.dll 6.05.01.0914 Final Retail English 1227776 09-Feb-10 01:12:30
slip.sys 5.03.00.0900 Final Retail English 10880 17-Feb-03 10:14:34
stream.sys 5.03.00.0900 Final Retail English 45696 12-Dec-02 00:14:32
streamip.sys 5.03.00.0900 Final Retail English 14976 17-Feb-03 10:14:34
strmdll.dll 4.01.00.3938 Beta Retail English 247326 21-Aug-09 17:06:52
swenum.sys 5.03.00.0900 Final Retail English 4096 12-Dec-02 00:14:32
vbisurf.ax 5.03.00.0900 Final Retail English 27648 17-Feb-03 10:14:34
wsock32.dll 5.00.2195.6603 Final Retail English 21776 19-Jun-03 12:05:04
wstdecod.dll 5.03.00.0900 Final Retail English 47104 17-Feb-03 10:14:36
--------[ DirectX Video ]-----------------------------------------------------------------------------------------------
[ Primary Display Driver ]
DirectDraw Device Properties:
DirectDraw Driver Name display
DirectDraw Driver Description Primary Display Driver
Hardware Driver nv4_disp.dll
Hardware Description NVIDIA RIVA TNT2 Model 64/Model 64 Pro
Direct3D Device Properties:
Available Local Video Memory 15254 KB
Available Non-Local Video Memory (AGP) 0 KB
Rendering Bit Depths 16, 32
Z-Buffer Bit Depths 16, 24
Min Texture Size 1 x 1
Max Texture Size 2048 x 2048
Vertex Shader Version Not Supported
Pixel Shader Version Not Supported
Direct3D Device Features:
Additive Texture Blending Supported
AGP Texturing Not Supported
Anisotropic Filtering Not Supported
Bilinear Filtering Supported
Cubic Environment Mapping Not Supported
Cubic Filtering Not Supported
Decal-Alpha Texture Blending Supported
Decal Texture Blending Supported
Directional Lights Not Supported
DirectX Texture Compression Not Supported
DirectX Volumetric Texture Compression Not Supported
Dithering Supported
Dot3 Texture Blending Not Supported
Dynamic Textures Supported
Edge Antialiasing Not Supported
Environmental Bump Mapping Not Supported
Environmental Bump Mapping + Luminance Not Supported
Factor Alpha Blending Supported
Geometric Hidden-Surface Removal Not Supported
Guard Band Supported
Hardware Scene Rasterization Supported
Hardware Transform & Lighting Not Supported
Mipmap LOD Bias Adjustments Supported
Modulate-Alpha Texture Blending Supported
Modulate Texture Blending Supported
Non-Square Textures Supported
N-Patches Not Supported
Perspective Texture Correction Supported
Point Lights Not Supported
Point Sampling Supported
Projective Textures Not Supported
Quintic Bezier Curves & B-Splines Not Supported
Range-Based Fog Supported
Rectangular & Triangular Patches Not Supported
Rendering In Windowed Mode Supported
Specular Flat Shading Supported
Specular Gouraud Shading Supported
Specular Phong Shading Not Supported
Spot Lights Not Supported
Stencil Buffers Supported
Sub-Pixel Accuracy Supported
Table Fog Supported
Texture Alpha Blending Supported
Texture Clamping Supported
Texture Mirroring Supported
Texture Transparency Supported
Texture Wrapping Supported
Triangle Culling Not Supported
Trilinear Filtering Supported
Vertex Alpha Blending Supported
Vertex Fog Supported
Volume Textures Not Supported
W-Based Fog Supported
W-Buffering Supported
Z-Based Fog Supported
Z-Bias Not Supported
Z-Test Not Supported
Problem Hardware Transform & Lighting is not supported. Modern 3D games may require it.
--------[ DirectX Sound ]-----------------------------------------------------------------------------------------------
[ Primary Sound Driver ]
DirectSound Device Properties:
Device Description Primary Sound Driver
Driver Module
Primary Buffers 1
Min / Max Secondary Buffers Sample Rate 4000 / 191999 Hz
Primary Buffers Sound Formats 8-bit, 16-bit, Mono, Stereo
Secondary Buffers Sound Formats 8-bit, 16-bit, Mono, Stereo
Total / Free Sound Buffers 32 / 31
Total / Free Static Sound Buffers 32 / 31
Total / Free Streaming Sound Buffers 32 / 31
Total / Free 3D Sound Buffers 32 / 31
Total / Free 3D Static Sound Buffers 32 / 31
Total / Free 3D Streaming Sound Buffers 32 / 31
DirectSound Device Features:
Certified Driver Yes
Emulated Device No
Precise Sample Rate Supported
[ SB Live! Audio [DCC0] ]
Device Description SB Live! Audio [DCC0]
Driver Module ctaud2k.sys
Primary Buffers 1
Emulated Device No
[ Crystal WDM Audio ]
Device Description Crystal WDM Audio
Driver Module cwbwdm.sys
Primary Buffers 1
Min / Max Secondary Buffers Sample Rate 4150 / 50400 Hz
Total / Free Sound Buffers 0 / 0
Total / Free Static Sound Buffers 0 / 0
Total / Free Streaming Sound Buffers 0 / 0
Total / Free 3D Sound Buffers 0 / 0
Total / Free 3D Static Sound Buffers 0 / 0
Total / Free 3D Streaming Sound Buffers 0 / 0
Emulated Device No
[ Conexant Audio ]
Device Description Conexant Audio
Driver Module crtaud.sys
Primary Buffers 1
Min / Max Secondary Buffers Sample Rate 8000 / 48000 Hz
Emulated Device No
--------[ DirectX Music ]-----------------------------------------------------------------------------------------------
DirectMusic Device Properties:
Synthesizer Type Software
Device Class Output Port
Device Type WDM Multimedia
Audio Channels 2
MIDI Channels 16000
Voices 1000
Available Memory System Memory
DirectMusic Device Features:
Built-In GM Instrument Set No
Built-In Roland GS Sound Set No
DirectSound Not Supported
DLS L1 Sample Collections Supported
DLS L2 Sample Collections Not Supported
External MIDI Port No
Fixed DLS Memory Size No
Port Sharing Not Supported
Chorus Effect Not Supported
Delay Effect Not Supported
Reverb Effect Supported
[ Crystal MPU-401 ]
Device Description Crystal MPU-401
Synthesizer Type Hardware
Device Class Input Port
MIDI Channels 16
DLS L1 Sample Collections Not Supported
External MIDI Port Yes
Reverb Effect Not Supported
[ Crystal MPU-401 ]
MIDI Channels 16
[ SB Live! DirectMusic Synthesizer [DCC0] ]
Device Description SB Live! DirectMusic Synthesizer [DCC0]
Audio Channels 64
MIDI Channels 1024
Voices 64
DirectSound Supported
Chorus Effect Supported
Audio Channels 2
MIDI Channels 16000
Voices 1000
[ Conexant Audio ]
Audio Channels 2
MIDI Channels 16000
Voices 1000
[ Microsoft MIDI Mapper [Emulated] ]
Device Description Microsoft MIDI Mapper [Emulated]
Device Type Windows Multimedia
MIDI Channels 16
Port Sharing Supported
[ Crystal FM Synthesizer [Emulated] ]
Device Description Crystal FM Synthesizer [Emulated]
MIDI Channels 16
[ Microsoft GS Wavetable SW Synth [Emulated] ]
Device Description Microsoft GS Wavetable SW Synth [Emulated]
MIDI Channels 16
[ Crystal MPU-401 [Emulated] ]
Device Description Crystal MPU-401 [Emulated]
MIDI Channels 16
[ SB Live! Sw Synth [DCC0] [Emulated] ]
Device Description SB Live! Sw Synth [DCC0] [Emulated]
MIDI Channels 16
[ SB Live! Synth A [DCC0] [Emulated] ]
Device Description SB Live! Synth A [DCC0] [Emulated]
MIDI Channels 16
[ SB Live! Synth B [DCC0] [Emulated] ]
Device Description SB Live! Synth B [DCC0] [Emulated]
MIDI Channels 16
[ SB Live! MIDI Port [DCC0] [Emulated] ]
Device Description SB Live! MIDI Port [DCC0] [Emulated]
MIDI Channels 16
[ Riptide MPU401 [Emulated] ]
Device Description Riptide MPU401 [Emulated]
MIDI Channels 16
MIDI Channels 16
MIDI Channels 16
MIDI Channels 16
[ Microsoft Synthesizer ]
Device Description Microsoft Synthesizer
Device Type User-Mode Synthesizer
Audio Channels 2
MIDI Channels 16000
Voices 1000
DLS L2 Sample Collections Supported
--------[ DirectX Input ]-----------------------------------------------------------------------------------------------
[ Mouse ]
DirectInput Device Properties:
Device Description Mouse
Device Type Mouse
Device Subtype Unknown
Axes 3
Buttons/Keys 8
DirectInput Device Features:
Emulated Device Yes
Alias Device No
Polled Device No
Polled Data Format No
Attack Force Feedback Not Supported
Deadband Force Feedback Not Supported
Fade Force Feedback Not Supported
Saturation Force Feedback Not Supported
+/- Force Feedback Coefficients Not Supported
+/- Force Feedback Saturation Not Supported
[ Keyboard ]
Device Description Keyboard
Device Type Keyboard
Device Subtype IBM PC Enhanced 101/102-key or Microsoft Natural keyboard
Buttons/Keys 128
Emulated Device Yes
Alias Device No
Polled Device No
[ Gaming Mouse G502 ]
Device Description Gaming Mouse G502
Device Type Unknown
Buttons/Keys 652
Emulated Device Yes
Alias Device No
Polled Device No
Device Type Unknown
Buttons/Keys 3
Emulated Device Yes
Alias Device No
Polled Device No
Device Type Unknown
Emulated Device Yes
Alias Device No
Polled Device No
Device Type Unknown
Emulated Device Yes
Alias Device No
Polled Device No
--------[ Windows Devices ]---------------------------------------------------------------------------------------------
Computer:
Advanced Configuration and Power Interface (ACPI) PC
Disk drives:
Maxtor 6E020L0
ST36811A
Display adapters:
ATI Technologies Inc. 3D RAGE PRO AGP 2X
DVD/CD-ROM drives:
COMBO IDE5232CO
LG CD-ROM CRD-8400B
Floppy disk controllers:
Standard floppy disk controller
Floppy disk drives:
Floppy disk drive
Floppy disk drive
Human Interface Devices:
HID-compliant consumer control device
HID-compliant device
IDE ATA/ATAPI controllers:
Primary IDE Channel
Keyboards:
HID Keyboard Device
Mice and other pointing devices:
HID-compliant mouse
Monitors:
Samsung SyncMaster 900SL (CSM92*)
Network adapters:
Direct Parallel
WAN Miniport (IP)
WAN Miniport (L2TP)
WAN Miniport (PPTP)
Non-Plug and Play Drivers:
ASCTRM
Beep
Diskperf
dmboot
dmload
Fips
FlashNT
IPSEC driver
KSecDD
mnmdd
mountmgr
MSMQ access control
NDIS System Driver
NDProxy
NetBios over Tcpip
NetDetect
Null
partmgr
ParVdm
PfModNT
RivaTuner32
Secdrv
VgaSave
Other devices:
PCI Simple Communications Controller
Ports (COM & LPT):
Sound, video and game controllers:
3dfxzone.it FastVoodoo2 4.0 XP Gold Edition
Audio Codecs
Creative Game Port
Creative SB Live! Value
Crystal WDM Audio Control Registers
Crystal WDM MPU-401 Compatible
Disabled Device
Legacy Audio Drivers
Legacy Video Capture Devices
Media Control Devices
Microsoft Kernel System Renderer
Microsoft WINMM WDM Audio Compatibility Driver
Riptide Gameport
Riptide Input Device
Video Codecs
Storage volumes:
Generic volume
Generic volume
System devices:
ACPI Fixed Feature Button
DEC 21152 PCI to PCI bridge
Direct memory access controller
Intel 82371AB/EB PCI to ISA bridge (ISA mode)
Intel 82443BX Pentium(r) II Processor to AGP Controller
Intel 82443BX Pentium(r) II Processor to PCI Bridge
ISAPNP Read Data Port
Microcode Update Device
Microsoft ACPI-Compliant System
Numeric data processor
Parallel Class Enumerator
PCI bus
Plug and Play Software Device Enumerator
Programmable interrupt controller
System board
System board
System CMOS/real time clock
System speaker
System timer
Volume Manager
Universal Serial Bus controllers:
Intel 82371AB/EB PCI to USB Universal Host Controller
USB Root Hub
--------[ Physical Devices ]--------------------------------------------------------------------------------------------
PCI Devices:
Bus 0, Device 17, Function 0 3Com 3C905B-TX Fast EtherLink XL 10/100 Adapter
Bus 2, Device 10, Function 0 3Dfx Voodoo2 3D Accelerator
Bus 1, Device 0, Function 0 ATI Rage Pro Turbo Video Adapter
Bus 0, Device 13, Function 1 Creative Labs Game Port
Bus 0, Device 13, Function 0 Creative Labs SB Live! Value (CT4780) Sound Card
Bus 0, Device 15, Function 0 DEC 21152AB PCI-PCI Bridge
Bus 0, Device 7, Function 1 Intel 82371AB/EB PIIX4 - IDE Controller
Bus 0, Device 7, Function 2 Intel 82371AB/EB PIIX4 - USB Host Controller
Bus 0, Device 7, Function 0 Intel 82371EB PCI ISA IDE Xcelerator 4 - PIIX4E [A-0]
Bus 0, Device 7, Function 3 Intel 82371EB PIIX4E - Power Management Controller [A-0]
Bus 0, Device 1, Function 0 Intel 82443BX/ZX AGP Controller [C-1]
Bus 0, Device 0, Function 0 Intel 82443BX/ZX Host Bridge/Controller [C-1]
Bus 2, Device 9, Function 0 nVIDIA RIVA TNT2 M64 Video Adapter
Bus 0, Device 14, Function 0 Rockwell Master Riptide Audio Device
Bus 0, Device 14, Function 2 Rockwell Riptide Game Controller
Bus 0, Device 14, Function 1 Rockwell/Conexant Modem Enumerator
PnP Devices:
PNP0303 101/102-Key or MS Natural Keyboard
PNP0501 16550A-compatible UART Serial Port
PNP0C08 ACPI Driver/BIOS
FIXEDBUTTON ACPI Fixed Feature Button
CSC0000 Crystal PnP Audio System CODEC
CSC0010 Crystal PnP Audio System Control Registers
CSC0003 Crystal PnP Audio System MPU-401
CSC000F Disabled Device [NoDB]
PNP0200 DMA Controller
PNP0401 ECP Parallel Port
PNP0700 Floppy Disk Controller
PNP0F13 Logitech PS/2 Port Mouse
PNP0C04 Numeric Data Processor
PNP0800 PC Speaker
PNP0A03 PCI Bus
PNP0000 Programmable Interrupt Controller
PNP0B00 Real-Time Clock
PNP0C01 System Board Extension
PNP0100 System Timer
USB Devices:
046D C07D USB Composite Device
046D C07D USB Human Interface Device
Ports:
COM1 Communications Port (COM1)
COM2 Communications Port (COM2)
LPT1 ECP Printer Port (LPT1)
--------[ Device Resources ]--------------------------------------------------------------------------------------------
DMA 00 Undetermined Crystal WDM Audio Codec
DMA 01 Undetermined Crystal WDM Audio Codec
DMA 02 Exclusive Standard floppy disk controller
DMA 04 Exclusive Direct memory access controller
IRQ 00 Exclusive System timer
IRQ 01 Exclusive Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
IRQ 03 Shared Communications Port (COM2)
IRQ 04 Shared Communications Port (COM1)
IRQ 05 Exclusive Crystal WDM Audio Codec
IRQ 06 Exclusive Standard floppy disk controller
IRQ 08 Exclusive System CMOS/real time clock
IRQ 09 Shared 3Com 3C918 Integrated Fast Ethernet Controller (3C905B-TX Compatible)
IRQ 09 Shared Creative SB Live! Value
IRQ 09 Shared Riptide Bus / Firmware Downloader
IRQ 09 Shared Intel 82371AB/EB PCI to USB Universal Host Controller
IRQ 09 Shared Microsoft ACPI-Compliant System
IRQ 09 Shared NVIDIA RIVA TNT2 Model 64/Model 64 Pro
IRQ 0B Shared PCI Simple Communications Controller
IRQ 0C Exclusive PS/2 Compatible Mouse
IRQ 0D Exclusive Numeric data processor
IRQ 0E Exclusive Primary IDE Channel
IRQ 0F Exclusive Secondary IDE Channel
Memory 00000000-0009FFFF Exclusive System board
Memory 000A0000-000BFFFF Shared PCI bus
Memory 000A0000-000BFFFF Shared NVIDIA RIVA TNT2 Model 64/Model 64 Pro
Memory 000A0000-000BFFFF Undetermined DEC 21152 PCI to PCI bridge
Memory 000C8000-000DFFFF Shared PCI bus
Memory 000F0000-000FFFFF Exclusive System board
Memory 00100000-00FFFFFF Exclusive System board
Memory 01000000-2FFFFFFF Exclusive System board
Memory 40000000-FFDFFFFF Shared PCI bus
Memory EC000000-EFFFFFFF Exclusive Intel 82443BX Pentium(r) II Processor to AGP Controller
Memory F0000000-F3FFFFFF Exclusive DEC 21152 PCI to PCI bridge
Memory F1000000-F1FFFFFF Undetermined 3dfxzone.it FastVoodoo2 4.0 XP Gold Edition
Memory F2000000-F3FFFFFF Exclusive NVIDIA RIVA TNT2 Model 64/Model 64 Pro
Memory F5000000-F5FFFFFF Exclusive Intel 82443BX Pentium(r) II Processor to AGP Controller
Memory FA000000-FAFFFFFF Exclusive NVIDIA RIVA TNT2 Model 64/Model 64 Pro
Memory FA000000-FBFFFFFF Exclusive DEC 21152 PCI to PCI bridge
Memory FC000000-FEFFFFFF Exclusive Intel 82443BX Pentium(r) II Processor to AGP Controller
Memory FF000000-FF00FFFF Undetermined PCI Simple Communications Controller
Memory FF010000-FF010FFF Exclusive Riptide Input Device
Memory FF011000-FF01107F Exclusive 3Com 3C918 Integrated Fast Ethernet Controller (3C905B-TX Compatible)
Memory FFE00000-FFFFFFFF Exclusive System board
Port 0000-001F Exclusive Direct memory access controller
Port 0000-0CF7 Shared PCI bus
Port 0020-003F Exclusive Programmable interrupt controller
Port 0040-005F Exclusive System timer
Port 0060-0060 Exclusive Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Port 0061-0061 Exclusive System speaker
Port 0062-0063 Exclusive System board
Port 0064-0064 Exclusive Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Port 0065-006F Exclusive System board
Port 0070-007F Exclusive System CMOS/real time clock
Port 0080-009F Exclusive Direct memory access controller
Port 00A0-00BF Exclusive Programmable interrupt controller
Port 00C0-00DF Exclusive Direct memory access controller
Port 00E0-00EF Exclusive System board
Port 00F0-00FF Exclusive Numeric data processor
Port 0170-0177 Exclusive Secondary IDE Channel
Port 01F0-01F7 Exclusive Primary IDE Channel
Port 0209-0209 Exclusive Riptide Gameport
Port 0220-0233 Undetermined Crystal WDM Audio Codec
Port 0274-0277 Exclusive ISAPNP Read Data Port
Port 0279-0279 Exclusive ISAPNP Read Data Port
Port 02F8-02FF Exclusive Communications Port (COM2)
Port 0330-0331 Exclusive Crystal WDM MPU-401 Compatible
Port 0360-0363 Exclusive Riptide Audio Device
Port 0376-0376 Exclusive Secondary IDE Channel
Port 0378-037F Exclusive ECP Printer Port (LPT1)
Port 0388-038B Undetermined Crystal WDM Audio Codec
Port 03A0-03A7 Exclusive Disabled Device
Port 03B0-03BB Shared NVIDIA RIVA TNT2 Model 64/Model 64 Pro
Port 03B0-03BB Undetermined DEC 21152 PCI to PCI bridge
Port 03C0-03DF Shared NVIDIA RIVA TNT2 Model 64/Model 64 Pro
Port 03C0-03DF Undetermined DEC 21152 PCI to PCI bridge
Port 03F0-03F5 Exclusive Standard floppy disk controller
Port 03F6-03F6 Exclusive Primary IDE Channel
Port 03F7-03F7 Exclusive Standard floppy disk controller
Port 03F8-03FF Exclusive Communications Port (COM1)
Port 04D0-04D1 Exclusive Programmable interrupt controller
Port 0534-053B Undetermined Crystal WDM Audio Codec
Port 0778-077F Exclusive ECP Printer Port (LPT1)
Port 0800-085F Exclusive System board
Port 0A79-0A79 Exclusive ISAPNP Read Data Port
Port 0D00-FFFF Shared PCI bus
Port 0F00-0F07 Exclusive Crystal WDM Audio Control Registers
Port D880-D8FF Exclusive 3Com 3C918 Integrated Fast Ethernet Controller (3C905B-TX Compatible)
Port DC40-DC7F Exclusive Riptide Bus / Firmware Downloader
Port DCB8-DCBF Exclusive Creative Game Port
Port DCC0-DCDF Exclusive Creative SB Live! Value
Port DCE0-DCFF Exclusive Intel 82371AB/EB PCI to USB Universal Host Controller
Port E000-EFFF Exclusive Intel 82443BX Pentium(r) II Processor to AGP Controller
Port FFA0-FFAF Exclusive Intel(r) 82371AB/EB PCI Bus Master IDE Controller
--------[ Auto Start ]--------------------------------------------------------------------------------------------------
Adobe Gamma Loader StartMenu\Common C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
ColorVisionStartup StartMenu\Common D:\Program Files\PANTONE COLORVISION\Startup\ColorVisionStartup.exe
FlashPath Monitor StartMenu\Common C:\Program Files\SmartDisk\FlashPath\sdstat.exe
internat.exe Registry\User\Run internat.exe
Jet Detection Registry\Common\Run C:\Program Files\Creative\SBLive\PROGRAM\ADGJDet.exe
Microsoft Office StartMenu\Common C:\Program Files\Microsoft Office\Office\OSA9.EXE -b -l
NeroFilterCheck Registry\Common\Run C:\WINNT\system32\NeroCheck.exe
NvCplDaemon Registry\Common\Run RUNDLL32.EXE C:\WINNT\system32\NvCpl.dll,NvStartup
NvMediaCenter Registry\User\Run RUNDLL32.EXE C:\WINNT\system32\NVMCTRAY.DLL,NvTaskbarInit
nwiz Registry\Common\Run nwiz.exe /install
PANTONE(R) colorist StartMenu\User C:\Program Files\Pantone Inc\PANTONE(R) colorist\PANTONE(R) colorist.exe,
QuickTime Task Registry\Common\Run C:\Program Files\QuickTime\qttask.exe -atboottime
RefreshLock Registry\Common\Run C:\Program Files\RefreshLock\RefreshLock.exe
RivaTuner Registry\Common\Run C:\Program Files\RivaTuner v2.0 RC 16\RivaTuner.exe /T
RivaTunerStartupDaemon Registry\Common\Run C:\Program Files\RivaTuner v2.0 RC 16\RivaTuner.exe /S
Synchronization Manager Registry\Common\Run mobsync.exe /logon
UpdReg Registry\Common\Run C:\WINNT\UpdReg.EXE
Voodoo2 Registry\Common\Run rundll32.exe 3dfxv2ps.dll,UpdateRegSettings
WINDVDPatch Registry\Common\Run CTHELPER.EXE
--------[ Installed Programs ]------------------------------------------------------------------------------------------
3dfxzone.it FastVoodoo2 4.0 XP Gold Edition Unknown
Adobe Acrobat 5.0 15.2 MB
Adobe Acrobat Reader 3.01 5.3 MB
Adobe Photoshop Elements 3.0 219.2 MB
AIDA32 v3.02 1.5 MB
AOL Instant Messenger (SM) Unknown
Audacity 2.0.6 49.5 MB
BitTorrent 3.2.1 Unknown
CCleaner (remove only) 988.0 KB
DirectX 9 Hotfix - KB839643 Unknown
eJay Mix Station - Deinstallation Unknown
eJay MP3 Plus - Deinstallation 52.8 MB
FlashPath 640.0 KB
Fraps 1.8 MB
Gtk+ Runtime Environment 2.4.14-rc3 20.6 MB
Half-Life Unknown
Holiday Activity Unknown
Hotfix for MDAC 2.53 (KB927779) Unknown
Hotfix for Microsoft .NET Framework 2.0 Service Pack 1 (KB953300) Unknown
Hotfix for Microsoft .NET Framework 2.0 Service Pack 1 (KB971110) Unknown
Java 2 Runtime Environment Standard Edition v1.3.1 22.1 MB
JFK Reloaded 1.1 Unknown
Kid Keys 2.0 Unknown
Kid Pix Deluxe 4 Unknown
L&H TTS3000 Español Unknown
Legacy Update 296.0 KB
Lernout & Hauspie TruVoice American English TTS Engine Unknown
LimeWire 1.6b 5.8 MB
MadOnion.com/3DMark2000 38.4 MB
Microsoft .NET Framework 1.1 Security Update (KB971108) Unknown
Microsoft .NET Framework 1.1 Security Update (KB979906) Unknown
Microsoft .NET Framework 1.1 Unknown
Microsoft .NET Framework 2.0 Service Pack 1 Unknown
Microsoft 3D Movie Maker 1.0 Unknown
Microsoft Base Smart Card Cryptographic Service Provider Package Unknown
Microsoft Office 2000 Disc 2 Unknown
Microsoft Office 2000 Professional Unknown
Mozilla Firefox (2.0.0.7) 19.5 MB
MSN Messenger 5.0 4.2 MB
Nero Media Player Unknown
Nero OEM Unknown
NeroVision Express 2 Unknown
Net2Phone 1.9 MB
Netscape 6 (6.2.1) Unknown
NVIDIA Windows 2000/XP Display Drivers 19.0 MB
PANTONE(R) colorist Unknown
Postal 2 Share The Pain Unknown
QuickTime Unknown
RealPlayer Basic Unknown
RivaTuner v2.0 RC 16 7.9 MB
Security Update for DirectX 9.0 (KB975560) Unknown
Security Update for DirectX 9.0 (KB975562) Unknown
Security Update for Windows 2000 (KB941569) Unknown
Security Update for Windows Media Player (KB911564) Unknown
Security Update for Windows Media Player (KB952069) Unknown
Security Update for Windows Media Player (KB954155) Unknown
Security Update for Windows Media Player (KB968816) Unknown
Security Update for Windows Media Player (KB977816) Unknown
Security Update for Windows Media Player 6.4 (KB925398) Unknown
Security Update for Windows Media Player 6.4 (KB954600) Unknown
Security Update for Windows Media Player 6.4 (KB974112) Unknown
Sierra Utilities Unknown
SnagIt 5 Unknown
Sound Blaster Live! Web 2K/XP Unknown
Spyder2 Unknown
The GIMP 2.2.12 Unknown
Unreal Tournament Unknown
Update Rollup 1 for Windows 2000 SP4 Unknown
VLC media player 1.0.1 Unknown
WebFldrs Unknown
Winamp (remove only) Unknown
Windows 2000 Hotfix - KB842773 Unknown
Windows 2000 Hotfix - KB867282 Unknown
Windows 2000 Hotfix - KB893756 Unknown
Windows 2000 Hotfix - KB896358 Unknown
Windows 2000 Hotfix - KB896422 Unknown
Windows 2000 Hotfix - KB896423 Unknown
Windows 2000 Hotfix - KB896688 Unknown
Windows 2000 Hotfix - KB899587 Unknown
Windows 2000 Hotfix - KB899589 Unknown
Windows 2000 Hotfix - KB900725 Unknown
Windows 2000 Hotfix - KB901017 Unknown
Windows 2000 Hotfix - KB901214 Unknown
Windows 2000 Hotfix - KB905414 Unknown
Windows 2000 Hotfix - KB905495 Unknown
Windows 2000 Hotfix - KB905749 Unknown
Windows 2000 Hotfix - KB908531 Unknown
Windows 2000 Hotfix - KB913580 Unknown
Windows 2000 Hotfix - KB914388 Unknown
Windows 2000 Hotfix - KB917008 Unknown
Windows 2000 Hotfix - KB917537 Unknown
Windows 2000 Hotfix - KB918118 Unknown
Windows 2000 Hotfix - KB920213 Unknown
Windows 2000 Hotfix - KB920670 Unknown
Windows 2000 Hotfix - KB920683 Unknown
Windows 2000 Hotfix - KB921398 Unknown
Windows 2000 Hotfix - KB922582 Unknown
Windows 2000 Hotfix - KB923191 Unknown
Windows 2000 Hotfix - KB923561 Unknown
Windows 2000 Hotfix - KB923810 Unknown
Windows 2000 Hotfix - KB923980 Unknown
Windows 2000 Hotfix - KB924270 Unknown
Windows 2000 Hotfix - KB924667 Unknown
Windows 2000 Hotfix - KB925902 Unknown
Windows 2000 Hotfix - KB926122 Unknown
Windows 2000 Hotfix - KB926247 Unknown
Windows 2000 Hotfix - KB926436 Unknown
Windows 2000 Hotfix - KB927891 Unknown
Windows 2000 Hotfix - KB928843 Unknown
Windows 2000 Hotfix - KB935839 Unknown
Windows 2000 Hotfix - KB937143 Unknown
Windows 2000 Hotfix - KB937894 Unknown
Windows 2000 Hotfix - KB938827 Unknown
Windows 2000 Hotfix - KB942831 Unknown
Windows 2000 Hotfix - KB943055 Unknown
Windows 2000 Hotfix - KB943485 Unknown
Windows 2000 Hotfix - KB944338 Unknown
Windows 2000 Hotfix - KB950749 Unknown
Windows 2000 Hotfix - KB950974 Unknown
Windows 2000 Hotfix - KB951748-V2 Unknown
Windows 2000 Hotfix - KB952004 Unknown
Windows 2000 Hotfix - KB952954 Unknown
Windows 2000 Hotfix - KB953155 Unknown
Windows 2000 Hotfix - KB955069 Unknown
Windows 2000 Hotfix - KB955759 Unknown
Windows 2000 Hotfix - KB956802 Unknown
Windows 2000 Hotfix - KB956844 Unknown
Windows 2000 Hotfix - KB957097 Unknown
Windows 2000 Hotfix - KB958470 Unknown
Windows 2000 Hotfix - KB958644 Unknown
Windows 2000 Hotfix - KB958869 Unknown
Windows 2000 Hotfix - KB959426 Unknown
Windows 2000 Hotfix - KB960225 Unknown
Windows 2000 Hotfix - KB960803 Unknown
Windows 2000 Hotfix - KB960859 Unknown
Windows 2000 Hotfix - KB961501 Unknown
Windows 2000 Hotfix - KB967715 Unknown
Windows 2000 Hotfix - KB969059 Unknown
Windows 2000 Hotfix - KB970238 Unknown
Windows 2000 Hotfix - KB970483 Unknown
Windows 2000 Hotfix - KB971032 Unknown
Windows 2000 Hotfix - KB971468 Unknown
Windows 2000 Hotfix - KB971961 Unknown
Windows 2000 Hotfix - KB972270 Unknown
Windows 2000 Hotfix - KB973507 Unknown
Windows 2000 Hotfix - KB973869 Unknown
Windows 2000 Hotfix - KB973904 Unknown
Windows 2000 Hotfix - KB974318 Unknown
Windows 2000 Hotfix - KB974392 Unknown
Windows 2000 Hotfix - KB974571 Unknown
Windows 2000 Hotfix - KB975254 Unknown
Windows 2000 Hotfix - KB975560 Unknown
Windows 2000 Hotfix - KB976323 Unknown
Windows 2000 Hotfix - KB977914 Unknown
Windows 2000 Hotfix - KB978037 Unknown
Windows 2000 Hotfix - KB978542 Unknown
Windows 2000 Hotfix - KB978601 Unknown
Windows 2000 Hotfix - KB978706 Unknown
Windows 2000 Hotfix - KB979309 Unknown
Windows 2000 Hotfix - KB979482 Unknown
Windows 2000 Hotfix - KB979559 Unknown
Windows 2000 Hotfix - KB979683 Unknown
Windows 2000 Hotfix - KB980195 Unknown
Windows 2000 Hotfix - KB980218 Unknown
Windows 2000 Hotfix - KB980232 Unknown
Windows 2000 Hotfix - KB981350 Unknown
Windows 2000 Hotfix (SP5) Q818043 Unknown
Windows Installer 3.1 (KB893803) Unknown
Windows Media Player Hotfix [See Q828026 for more information] Unknown
WinZip Unknown
--------[ Windows Update ]----------------------------------------------------------------------------------------------
DirectX 9 Hotfix - KB839643 Update 4/30/2006
Microsoft .NET Framework 1.1 Security Update (KB971108) Update 29-Apr-06
Microsoft .NET Framework 1.1 Security Update (KB979906) Update 29-Apr-06
Microsoft .NET Framework 1.1 Service Pack 1 (KB867460) Update 29-Apr-06
Microsoft Data Access Components KB870669
Update Rollup 1 for Windows 2000 SP4 Update 4/29/2006
Windows 2000 Hotfix - KB329115 Update 4/29/2006
Windows 2000 Hotfix - KB835732 Update 4/29/2006
Windows 2000 Hotfix - KB842773 Update 4/29/2006
Windows 2000 Hotfix - KB867282 Update 4/29/2006
Windows 2000 Hotfix - KB893756 Update 4/29/2006
Windows 2000 Hotfix - KB896358 Update 4/29/2006
Windows 2000 Hotfix - KB896422 Update 4/29/2006
Windows 2000 Hotfix - KB896423 Update 4/29/2006
Windows 2000 Hotfix - KB896688 Update 4/29/2006
Windows 2000 Hotfix - KB899587 Update 4/29/2006
Windows 2000 Hotfix - KB899589 Update 4/29/2006
Windows 2000 Hotfix - KB900725 Update 4/29/2006
Windows 2000 Hotfix - KB901017 Update 4/29/2006
Windows 2000 Hotfix - KB901214 Update 4/29/2006
Windows 2000 Hotfix - KB905414 Update 4/29/2006
Windows 2000 Hotfix - KB905495 Update 4/29/2006
Windows 2000 Hotfix - KB905749 Update 4/29/2006
Windows 2000 Hotfix - KB908531 Update 4/29/2006
Windows 2000 Hotfix - KB913580 Update 4/29/2006
Windows 2000 Hotfix - KB914388 Update 4/29/2006
Windows 2000 Hotfix - KB917008 Update 4/29/2006
Windows 2000 Hotfix - KB917537 Update 4/30/2006
Windows 2000 Hotfix - KB918118 Update 4/29/2006
Windows 2000 Hotfix - KB920213 Update 4/29/2006
Windows 2000 Hotfix - KB920670 Update 4/29/2006
Windows 2000 Hotfix - KB920683 Update 4/29/2006
Windows 2000 Hotfix - KB921398 Update 4/29/2006
Windows 2000 Hotfix - KB922582 Update 4/29/2006
Windows 2000 Hotfix - KB923191 Update 4/29/2006
Windows 2000 Hotfix - KB923561 Update 4/29/2006
Windows 2000 Hotfix - KB923810 Update 4/29/2006
Windows 2000 Hotfix - KB923980 Update 4/29/2006
Windows 2000 Hotfix - KB924270 Update 4/29/2006
Windows 2000 Hotfix - KB924667 Update 4/29/2006
Windows 2000 Hotfix - KB925902 Update 4/29/2006
Windows 2000 Hotfix - KB926122 Update 4/29/2006
Windows 2000 Hotfix - KB926247 Update 4/30/2006
Windows 2000 Hotfix - KB926436 Update 4/29/2006
Windows 2000 Hotfix - KB927891 Update 4/29/2006
Windows 2000 Hotfix - KB928843 Update 4/29/2006
Windows 2000 Hotfix - KB935839 Update 4/29/2006
Windows 2000 Hotfix - KB937143 Update 4/29/2006
Windows 2000 Hotfix - KB937894 Update 4/29/2006
Windows 2000 Hotfix - KB938827 Update 4/29/2006
Windows 2000 Hotfix - KB942831 Update 4/30/2006
Windows 2000 Hotfix - KB943055 Update 4/29/2006
Windows 2000 Hotfix - KB943485 Update 4/29/2006
Windows 2000 Hotfix - KB944338 Update 4/29/2006
Windows 2000 Hotfix - KB950749 Update 4/29/2006
Windows 2000 Hotfix - KB950974 Update 4/29/2006
Windows 2000 Hotfix - KB951748-V2 Update 4/29/2006
Windows 2000 Hotfix - KB952004 Update 4/29/2006
Windows 2000 Hotfix - KB952954 Update 4/29/2006
Windows 2000 Hotfix - KB953155 Update 4/30/2006
Windows 2000 Hotfix - KB955069 Update 4/29/2006
Windows 2000 Hotfix - KB955759 Update 4/29/2006
Windows 2000 Hotfix - KB956802 Update 4/29/2006
Windows 2000 Hotfix - KB956844 Update 4/29/2006
Windows 2000 Hotfix - KB957097 Update 4/29/2006
Windows 2000 Hotfix - KB958470 Update 4/29/2006
Windows 2000 Hotfix - KB958644 Update 4/29/2006
Windows 2000 Hotfix - KB958869 Update 4/29/2006
Windows 2000 Hotfix - KB959426 Update 4/29/2006
Windows 2000 Hotfix - KB960225 Update 4/29/2006
Windows 2000 Hotfix - KB960803 Update 4/29/2006
Windows 2000 Hotfix - KB960859 Update 4/29/2006
Windows 2000 Hotfix - KB961501 Update 4/29/2006
Windows 2000 Hotfix - KB967715 Update 4/29/2006
Windows 2000 Hotfix - KB969059 Update 4/29/2006
Windows 2000 Hotfix - KB970238 Update 4/29/2006
Windows 2000 Hotfix - KB970483 Update 4/30/2006
Windows 2000 Hotfix - KB971032 Update 4/30/2006
Windows 2000 Hotfix - KB971468 Update 4/29/2006
Windows 2000 Hotfix - KB971961 Update 4/29/2006
Windows 2000 Hotfix - KB972270 Update 4/29/2006
Windows 2000 Hotfix - KB973507 Update 4/29/2006
Windows 2000 Hotfix - KB973869 Update 4/29/2006
Windows 2000 Hotfix - KB973904 Update 4/29/2006
Windows 2000 Hotfix - KB974318 Update 4/29/2006
Windows 2000 Hotfix - KB974392 Update 4/29/2006
Windows 2000 Hotfix - KB974571 Update 4/29/2006
Windows 2000 Hotfix - KB975254 Update 4/30/2006
Windows 2000 Hotfix - KB975560 Update 4/29/2006
Windows 2000 Hotfix - KB976323 Update 4/30/2006
Windows 2000 Hotfix - KB977914 Update 4/29/2006
Windows 2000 Hotfix - KB978037 Update 4/29/2006
Windows 2000 Hotfix - KB978542 Update 4/29/2006
Windows 2000 Hotfix - KB978601 Update 4/29/2006
Windows 2000 Hotfix - KB978706 Update 4/29/2006
Windows 2000 Hotfix - KB979309 Update 4/29/2006
Windows 2000 Hotfix - KB979482 Update 4/29/2006
Windows 2000 Hotfix - KB979559 Update 4/29/2006
Windows 2000 Hotfix - KB979683 Update 4/29/2006
Windows 2000 Hotfix - KB980195 Update 4/29/2006
Windows 2000 Hotfix - KB980218 Update 4/29/2006
Windows 2000 Hotfix - KB980232 Update 4/29/2006
Windows 2000 Hotfix - KB981350 Update 4/29/2006
Windows 2000 Hotfix (SP5) Q818043 Update 4/29/2006
Windows 2000 Service Pack 4 Service Pack 4/29/2006
Windows Installer 3.1 (KB893803) Update 4/29/2006
Windows Media Player Hotfix [See Q828026 for more information] Update 4/29/2006
--------[ Environment ]-------------------------------------------------------------------------------------------------
ALLUSERSPROFILE C:\Documents and Settings\All Users
APPDATA C:\Documents and Settings\Pickel\Application Data
CommonProgramFiles C:\Program Files\Common Files
COMPUTERNAME Pickel-PC
ComSpec C:\WINNT\system32\cmd.exe
GTK_BASEPATH C:\Drivers\GTK
HOMEDRIVE C:
HOMEPATH \Documents and Settings\Pickel
LOGONSERVER \\Pickel-PC
NUMBER_OF_PROCESSORS 1
OS Windows_NT
Os2LibPath C:\WINNT\system32\os2\dll;
Path C:\Drivers\GTK\bin;C:\WINNT\system32;C:\WINNT;C:\WINNT\System32\Wbem
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
PROCESSOR_ARCHITECTURE x86
PROCESSOR_IDENTIFIER x86 Family 6 Model 8 Stepping 6, GenuineIntel
PROCESSOR_LEVEL 6
PROCESSOR_REVISION 0806
SystemDrive C:
SystemRoot C:\WINNT
TEMP C:\DOCUME~1\Pickel\LOCALS~1\Temp
TMP C:\DOCUME~1\Pickel\LOCALS~1\Temp
USERDOMAIN Pickel-PC
USERNAME Pickel
USERPROFILE C:\Documents and Settings\Pickel
windir C:\WINNT
--------[ System Files ]------------------------------------------------------------------------------------------------
[ autoexec.nt ]
@echo off
REM AUTOEXEC.BAT is not used to initialize the MS-DOS environment.
REM AUTOEXEC.NT is used to initialize the MS-DOS environment unless a
REM different startup file is specified in an application's PIF.
REM Install CD ROM extensions
lh %SystemRoot%\system32\mscdexnt.exe
REM Install network redirector (load before dosx.exe)
lh %SystemRoot%\system32\redir
REM Install DPMI support
lh %SystemRoot%\system32\dosx
[ config.nt ]
REM Windows MS-DOS Startup File
REM
REM CONFIG.SYS vs CONFIG.NT
REM CONFIG.SYS is not used to initialize the MS-DOS environment.
REM CONFIG.NT is used to initialize the MS-DOS environment unless a
REM
REM ECHOCONFIG
REM By default, no information is displayed when the MS-DOS environment
REM is initialized. To display CONFIG.NT/AUTOEXEC.NT information, add
REM the command echoconfig to CONFIG.NT or other startup file.
REM
REM NTCMDPROMPT
REM When you return to the command prompt from a TSR or while running an
REM MS-DOS-based application, Windows runs COMMAND.COM. This allows the
REM TSR to remain active. To run CMD.EXE, the Windows command prompt,
REM rather than COMMAND.COM, add the command ntcmdprompt to CONFIG.NT or
REM other startup file.
REM
REM DOSONLY
REM By default, you can start any type of application when running
REM COMMAND.COM. If you start an application other than an MS-DOS-based
REM application, any running TSR may be disrupted. To ensure that only
REM MS-DOS-based applications can be started, add the command dosonly to
REM CONFIG.NT or other startup file.
REM
REM EMM
REM You can use EMM command line to configure EMM(Expanded Memory Manager).
REM The syntax is:
REM
REM EMM = [A=AltRegSets] [RAM]
REM
REM AltRegSets
REM specifies the total Alternative Mapping Register Sets you
REM want the system to support. 1 <= AltRegSets <= 255. The
REM default value is 8.
REM BaseSegment
REM specifies the starting segment address in the Dos conventional
REM memory you want the system to allocate for EMM page frames.
REM The value must be given in Hexdecimal.
REM 0x1000 <= BaseSegment <= 0x4000. The value is rounded down to
REM 16KB boundary. The default value is 0x4000
REM RAM
REM specifies that the system should only allocate 64Kb address
REM space from the Upper Memory Block(UMB) area for EMM page frames
REM and leave the rests(if available) to be used by DOS to support
REM loadhigh and devicehigh commands. The system, by default, would
REM allocate all possible and available UMB for page frames.
REM
REM The EMM size is determined by pif file(either the one associated
REM with your application or _default.pif). If the size from PIF file
REM is zero, EMM will be disabled and the EMM line will be ignored.
REM
dos=high, umb
device=%SystemRoot%\system32\himem.sys
files=40
[ msdos.sys ]
[ boot.ini ]
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect
[ system.ini ]
; for 16-bit app support
[drivers]
wave=mmdrv.dll
timer=timer.drv
[mci]
[driver32]
[386enh]
woafont=dosapp.FON
EGA80WOA.FON=EGA80WOA.FON
EGA40WOA.FON=EGA40WOA.FON
CGA80WOA.FON=CGA80WOA.FON
CGA40WOA.FON=CGA40WOA.FON
[ win.ini ]
[fonts]
[extensions]
[mci extensions]
[files]
[Mail]
MAPI=1
MAPIX=1
CMC=1
CMCDLLNAME=mapi.dll
CMCDLLNAME32=mapi32.dll
MAPIXVER=1.0.0.1
OLEMessaging=1
[MCI Extensions.BAK]
asf=MPEGVideo
asx=MPEGVideo
ivf=MPEGVideo
m3u=MPEGVideo
mp2v=MPEGVideo
mp3=MPEGVideo
mpv2=MPEGVideo
wax=MPEGVideo
wm=MPEGVideo
wma=MPEGVideo
wmv=MPEGVideo
wvx=MPEGVideo
wmx=MPEGVideo2
[WinZip]
Note-1=This section is required only to install the optional WinZip Internet Browser Support build 0231.
Note-2=Removing this section of the win.ini will have no effect except preventing installation of WinZip Internet Browser Support build 0231.
win32_version=6.3-8.0
[OLFax Ports]
OLFModem=C:\Program Files\Microsoft Office\Office\1033\WFXMSRVR.EXE,WFXMSRVR,WFXOUTLOOKSMTPPOP3, 60
--------[ System Folders ]----------------------------------------------------------------------------------------------
Administrative Tools C:\Documents and Settings\Pickel\Start Menu\Programs\Administrative Tools
AppData C:\Documents and Settings\Pickel\Application Data
Cache C:\Documents and Settings\Pickel\Local Settings\Temporary Internet Files
Common Administrative Tools C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools
Common AppData C:\Documents and Settings\All Users\Application Data
Common Desktop C:\Documents and Settings\All Users\Desktop
Common Documents C:\Documents and Settings\All Users\Documents
Common Favorites C:\Documents and Settings\All Users\Favorites
Common Programs C:\Documents and Settings\All Users\Start Menu\Programs
Common Start Menu C:\Documents and Settings\All Users\Start Menu
Common Startup C:\Documents and Settings\All Users\Start Menu\Programs\Startup
Common Templates C:\Documents and Settings\All Users\Templates
Cookies C:\Documents and Settings\Pickel\Cookies
Desktop C:\Documents and Settings\Pickel\Desktop
Device C:\WINNT\inf
Favorites C:\Documents and Settings\Pickel\Favorites
Fonts C:\WINNT\Fonts
History C:\Documents and Settings\Pickel\Local Settings\History
Local AppData C:\Documents and Settings\Pickel\Local Settings\Application Data
Local Settings C:\Documents and Settings\Pickel\Local Settings
Media C:\WINNT\Media
My Pictures C:\Documents and Settings\Pickel\My Documents\My Pictures
NetHood C:\Documents and Settings\Pickel\NetHood
Personal C:\Documents and Settings\Pickel\My Documents
Personal C:\Documents and Settings\Pickel\My Documents\
PrintHood C:\Documents and Settings\Pickel\PrintHood
Program Files C:\Program Files
Programs C:\Documents and Settings\Pickel\Start Menu\Programs
Recent C:\Documents and Settings\Pickel\Recent
SendTo C:\Documents and Settings\Pickel\SendTo
Start Menu C:\Documents and Settings\Pickel\Start Menu
Startup C:\Documents and Settings\Pickel\Start Menu\Programs\Startup
System C:\WINNT\system32
Temp C:\DOCUME~1\Pickel\LOCALS~1\Temp\
Templates C:\Documents and Settings\Pickel\Templates
Wallpaper C:\WINNT\Web\Wallpaper
Windows C:\WINNT
--------[ Power Management ]--------------------------------------------------------------------------------------------
Power Management Properties:
Current Power Source AC Line
Battery Status No Battery
Full Battery Lifetime Unknown
Remaining Battery Lifetime Unknown
--------[ Regional ]----------------------------------------------------------------------------------------------------
Time Zone:
Current Time Zone Central Daylight Time
Current Time Zone Description (GMT-06:00) Central Time (US & Canada)
Change To Standard Time Last Sunday of October 02:00:00
Change To Daylight Time First Sunday of April 02:00:00
Language:
Language Name (Native) English
Language Name (English) English
Language Name (ISO 639) en
Country/Region:
Country Name (Native) United States
Country Name (English) United States
Country Name (ISO 3166) US
Country Code 1
Currency:
Currency Name (Native) US Dollar
Currency Name (English) US Dollar
Currency Symbol (Native) $
Currency Symbol (ISO 4217) USD
Currency Format $123,456,789.00
Negative Currency Format ($123,456,789.00)
Formatting:
Time Format HH🇲🇲ss
Short Date Format dd-MMM-yy
Long Date Format dddd, dd MMMM, yyyy
Number Format 123,456,789.00
Negative Number Format -123,456,789.00
List Format first, second, third
Native Digits 0123456789
Days of Week:
Native Name for Monday Monday / Mon
Native Name for Tuesday Tuesday / Tue
Native Name for Wednesday Wednesday / Wed
Native Name for Thursday Thursday / Thu
Native Name for Friday Friday / Fri
Native Name for Saturday Saturday / Sat
Native Name for Sunday Sunday / Sun
Months:
Native Name for January January / Jan
Native Name for February February / Feb
Native Name for March March / Mar
Native Name for April April / Apr
Native Name for May May / May
Native Name for June June / Jun
Native Name for July July / Jul
Native Name for August August / Aug
Native Name for September September / Sep
Native Name for October October / Oct
Native Name for November November / Nov
Native Name for December December / Dec
Miscellaneous:
Calendar Type Gregorian (localized)
Default Paper Size US Letter
Measurement System Metric
--------[ Memory Read ]-------------------------------------------------------------------------------------------------
P4A-2140 Abit TH7II i850 PC1066 RDRAM 3180 MB/s
P4A-2140 Abit TH7II i850 PC800 RDRAM 2600 MB/s
P4A-2400 Asus P4T533-C i850E PC800 RDRAM 2540 MB/s
AthlonXP 1.7 GHz Abit KX7-333 KT333 PC2900 DDR SDRAM 2480 MB/s
AthlonXP-1800+ Epox 8K3A+ KT333 PC2700 DDR SDRAM 2050 MB/s
AthlonXP-1700+ Asus A7V8X KT400 PC2700 DDR SDRAM 2020 MB/s
AthlonXP-2000+ Asus A7V333 KT333 PC2700 DDR SDRAM 2010 MB/s
Celeron4-1800 MSI 645 Ultra SiS645 PC2100 DDR SDRAM 1910 MB/s
AthlonXP-1800+ Epox 8KHA+ KT266A PC2100 DDR SDRAM 1880 MB/s
AthlonXP-1800+ MSI KT3 Ultra KT333 PC2100 DDR SDRAM 1840 MB/s
AthlonXP-1800+ Asus A7V333 KT333 PC2100 DDR SDRAM 1830 MB/s
AthlonXP-1600+ Abit KG7 AMD-760 PC2100 DDR SDRAM 1550 MB/s
Duron-600 Tyan Tiger MP AMD-760MP PC1600 DDR SDRAM 1080 MB/s
PIII-733EB MSI 815EM Pro i815E AGP PC133 SDRAM 1030 MB/s
PIII-1200S Asus TUV4X ApolloPro133T PC133 SDRAM 1000 MB/s
P4-1.6 Asus P4B-MX i845 PC133 SDRAM 990 MB/s
PIII-733EB MSI 815EM Pro i815E Int. PC133 SDRAM 910 MB/s
Duron-800 Asus A7V-E KT133A PC133 SDRAM 900 MB/s
This Computer Unknown 733 MB/s
Celeron2-713 Matsonic MS7177CT ApolloPro133T PC112 SDRAM 580 MB/s
Celeron2-633 MSI MS-6178 i810E PC66 SDRAM 470 MB/s
PII-266 Intel DK440LX i440LX PC66 SDRAM 330 MB/s
C3-800 VIA EPIA PLE133 PC133 SDRAM 210 MB/s
--------[ Memory Write ]------------------------------------------------------------------------------------------------
P4A-2140 Abit TH7II i850 PC800 RDRAM 1260 MB/s
P4A-2140 Abit TH7II i850 PC1066 RDRAM 990 MB/s
AthlonXP 1.7 GHz Abit KX7-333 KT333 PC2900 DDR SDRAM 850 MB/s
P4A-2400 Asus P4T533-C i850E PC800 RDRAM 760 MB/s
AthlonXP-1700+ Asus A7V8X KT400 PC2700 DDR SDRAM 760 MB/s
AthlonXP-1800+ Epox 8K3A+ KT333 PC2700 DDR SDRAM 740 MB/s
AthlonXP-2000+ Asus A7V333 KT333 PC2700 DDR SDRAM 730 MB/s
Celeron4-1800 MSI 645 Ultra SiS645 PC2100 DDR SDRAM 690 MB/s
AthlonXP-1600+ Abit KG7 AMD-760 PC2100 DDR SDRAM 680 MB/s
AthlonXP-1800+ Epox 8KHA+ KT266A PC2100 DDR SDRAM 600 MB/s
AthlonXP-1800+ Asus A7V333 KT333 PC2100 DDR SDRAM 580 MB/s
AthlonXP-1800+ MSI KT3 Ultra KT333 PC2100 DDR SDRAM 570 MB/s
Duron-600 Tyan Tiger MP AMD-760MP PC1600 DDR SDRAM 480 MB/s
P4-1.6 Asus P4B-MX i845 PC133 SDRAM 420 MB/s
Duron-800 Asus A7V-E KT133A PC133 SDRAM 320 MB/s
PIII-733EB MSI 815EM Pro i815E AGP PC133 SDRAM 280 MB/s
PIII-733EB MSI 815EM Pro i815E Int. PC133 SDRAM 250 MB/s
PIII-1200S Asus TUV4X ApolloPro133T PC133 SDRAM 210 MB/s
This Computer Unknown 182 MB/s
C3-800 VIA EPIA PLE133 PC133 SDRAM 180 MB/s
Celeron2-713 Matsonic MS7177CT ApolloPro133T PC112 SDRAM 150 MB/s
Celeron2-633 MSI MS-6178 i810E PC66 SDRAM 140 MB/s
PII-266 Intel DK440LX i440LX PC66 SDRAM 110 MB/s
--------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
B00 D00 F00: Intel 82443BX/ZX Host Bridge/Controller [C-1]
Offset 00: 86 80 90 71 06 01 10 22 03 00 00 06 00 40 00 00
Offset 10: 08 00 00 EC 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 0C 00 00 00 00 00 00 09 03 10 11 01 00 00 00 00
Offset 60: 10 20 30 40 50 60 60 60 00 2A 00 A0 AA 8A 00 00
Offset 70: 20 1F 0A 78 AA 0A 07 01 00 3F 10 38 00 00 00 00
Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 00 00 00 00 04 61 00 00 00 05 00 00 00 00 00 00
Offset A0: 02 00 10 00 03 02 00 1F 02 03 00 00 00 00 00 00
Offset B0: 80 00 00 00 30 00 00 00 00 00 00 00 20 10 00 00
Offset C0: 00 00 00 00 00 00 00 00 18 0C FF FF 7F 00 00 00
Offset D0: 08 08 02 02 02 12 00 00 0C 00 00 00 00 00 00 00
Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 F8 00 60 20 0F 00 00 00 00 00 00
B00 D01 F00: Intel 82443BX/ZX AGP Controller [C-1]
Offset 00: 86 80 91 71 1F 01 20 02 03 00 04 06 00 40 01 00
Offset 10: 00 00 00 00 00 00 00 00 00 01 01 40 E0 E0 A0 22
Offset 20: 00 FC F0 FE 00 F5 F0 F5 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 84 00
Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D07 F00: Intel 82371EB PCI ISA IDE Xcelerator 4 - PIIX4E [A-0]
Offset 00: 86 80 10 71 0F 00 80 02 02 00 01 06 00 00 80 00
Offset 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 4D 00 20 00
Offset 60: 09 09 09 09 10 00 00 00 00 F6 80 00 00 00 00 00
Offset 70: 00 00 00 00 00 00 0C 0C 00 00 00 00 00 00 00 00
Offset 80: 00 00 07 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset B0: 05 00 00 E1 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 00 00 00 00 00 00 00 00 00 00 21 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 30 0F 00 00 00 00 00 00
B00 D07 F01: Intel 82371AB/EB PIIX4 - IDE Controller
Offset 00: 86 80 11 71 05 00 80 02 01 80 01 01 00 20 00 00
Offset 20: A1 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 77 E3 33 E3 BB 00 00 00 03 00 22 00 00 00 00 00
B00 D07 F02: Intel 82371AB/EB PIIX4 - USB Host Controller
Offset 00: 86 80 12 71 05 00 80 02 01 00 03 0C 00 40 00 00
Offset 20: E1 DC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 09 04 00 00
Offset 60: 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 30 0F 00 00 00 00 00 10
B00 D07 F03: Intel 82371EB PIIX4E - Power Management Controller [A-0]
Offset 00: 86 80 13 71 01 00 80 02 02 00 80 06 00 00 00 00
Offset 40: 01 08 00 00 00 01 00 00 00 00 00 00 00 00 00 00
Offset 50: 00 00 00 00 00 00 00 00 04 00 00 02 00 00 00 00
Offset 60: 00 00 00 00 00 00 00 00 04 08 11 00 00 00 00 00
Offset 80: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 51 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D0D F00: Creative Labs SB Live! Value (CT4780) Sound Card
Offset 00: 02 11 02 00 05 01 90 02 0A 00 01 04 00 40 80 00
Offset 10: C1 DC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 02 11 22 80
Offset 30: 00 00 00 00 DC 00 00 00 00 00 00 00 09 01 02 14
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 06
B00 D0D F01: Creative Labs Game Port
Offset 00: 02 11 02 70 05 01 90 02 0A 00 80 09 00 40 80 00
Offset 10: B9 DC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 02 11 20 00
Offset 30: 00 00 00 00 DC 00 00 00 00 00 00 00 00 00 00 00
B00 D0E F00: Rockwell Master Riptide Audio Device
Offset 00: 7A 12 10 43 07 01 90 02 00 00 01 04 00 40 80 00
Offset 10: 41 DC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 35 12 10 43
Offset 30: 00 00 00 00 40 00 00 00 00 00 00 00 09 01 00 00
Offset 40: 01 00 01 02 00 00 00 00 20 02 88 03 60 03 09 02
Offset 50: 99 9D 03 00 01 00 00 00 00 00 00 00 00 00 00 00
B00 D0E F01: Rockwell/Conexant Modem Enumerator
Offset 00: 7A 12 11 43 07 01 90 02 00 00 80 07 00 40 80 00
Offset 10: 00 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 35 12 11 43
Offset 30: 00 00 00 00 40 00 00 00 00 00 00 00 0B 01 00 00
Offset 40: 01 00 21 44 00 00 00 00 00 00 00 00 00 00 00 00
B00 D0E F02: Rockwell Riptide Game Controller
Offset 00: 7A 12 12 43 07 01 90 02 00 00 80 09 00 00 80 00
Offset 10: 00 00 01 FF 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 35 12 12 43
Offset 30: 00 00 00 00 40 00 00 00 00 00 00 00 FF 00 00 00
Offset 40: 01 00 01 04 00 00 00 00 00 00 00 00 00 00 00 00
B00 D0F F00: DEC 21152AB PCI-PCI Bridge
Offset 00: 11 10 24 00 07 01 90 02 03 00 04 06 08 40 01 00
Offset 10: 00 00 00 00 00 00 00 00 00 02 02 40 F1 01 80 22
Offset 20: 00 FA F0 FB 01 F0 F1 F3 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 DC 00 00 00 00 00 00 00 00 00 0A 00
Offset 40: 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 00 00 00 00 00 00 00 00 30 3F 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 01
Offset E0: 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D11 F00: 3Com 3C905B-TX Fast EtherLink XL 10/100 Adapter
Offset 00: B7 10 55 90 17 01 10 02 24 00 00 02 08 40 00 00
Offset 10: 81 D8 00 00 00 10 01 FF 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 28 10 82 00
Offset 30: 00 00 00 F9 DC 00 00 00 00 00 00 00 09 01 0A 0A
Offset 50: 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 76
B01 D00 F00: ATI Rage Pro Turbo Video Adapter
Offset 00: 02 10 42 47 80 00 90 02 5C 00 00 03 08 40 00 00
Offset 10: 00 00 00 FD 01 EC 00 00 00 F0 FF FC 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 28 10 82 40
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 0B 01 08 00
Offset 40: 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 02 00 10 00 03 02 00 FF 02 03 00 1F 00 00 00 00
B02 D09 F00: nVIDIA RIVA TNT2 M64 Video Adapter
Offset 00: DE 10 2D 00 27 00 B0 02 15 00 00 03 00 F8 00 00
Offset 10: 00 00 00 FA 08 00 00 F2 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 DE 10 06 00
Offset 30: 00 00 00 00 60 00 00 00 00 00 00 00 09 01 05 01
Offset 40: DE 10 06 00 02 00 20 00 03 00 00 1F 00 00 00 00
Offset 50: 01 00 00 00 01 00 00 00 CE D6 23 00 0F 00 00 00
Offset 60: 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
B02 D0A F00: 3Dfx Voodoo2 3D Accelerator
Offset 00: 1A 12 02 00 02 00 80 00 02 00 00 04 00 00 00 00
Offset 10: 08 00 00 F1 00 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 03 40 01 00 00 00 00 00 00 00 00 00 7F F0 FF 0F
Offset 50: 00 00 00 00 43 16 00 30 00 00 00 00 00 00 00 00
--------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------
C000:0000 U.J.K7400.L.w.VIDEO ..........IBM VGA Compatible.......009/23.79
C000:0040 ..............................PMIDX.[............[.NV..........
C000:0080 ....F.B.`.Z.......P...q(......F.Z...........?>76.....NVIDIA TNT2
C000:00C0 Model 64 VGA BIOS..........qq..................................
C000:0100 ......Version 2.05.17.02.01 ...Copyright (C) 1996-1999 NVidia Co
C000:0140 rp....e............n............z........z........z........z....
C000:0180 ....z........z........y..h..0y..h..7z........y..h...z........z..
C000:01C0 ...%. z.....b.Az........z.....W..cn............n.........b.Az..h
C000:0200 .....z........z........x..8..x....?x..(..x..3..x..!..x..+..x..,.
C000:0240 .qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
C000:0280 qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqPCIR..-.........J.......V
C000:02C0 ESA..F.............Riva TNT...........................Chip Rev B
C000:0300 1.....................................@.@. . .h.h.j.l...9.....`2
C000:0340 ...f..Pf...f..Wf.Xf.......f...f..)....t....f.a.`...t.Rf......u..
C000:0380 ..t.ZPRf...f..Wf.ZXf..f.......f.....f.Rf.......f....3.f..f%..f..
C000:03C0 ..Z...fB......$....fJ.-.fB... $....a.`....t.Rf......u....t.ZRPf.
--------[ Debug - Unknown ]---------------------------------------------------------------------------------------------
HDD Maxtor 6E020L0
HDD ST36811A
Motherboard Motherboard ID
Motherboard Unknown
Optical COMBO IDE5232CO
PnP Disabled Device [NoDB]
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
Reply 1 of 3, by leileilol
I'd probably take the Rage Pro out. Also nVidia is probably allergic to any second video device wanting the Direct3D HAL (coming from experience with nVidia vs PowerVR PCX2 cards at Direct3D). I've never had a problem with Direct3d when it was a 3dfx V3 paired with a 3dfx V2 (in a non-nvidia-using context).
Reply 2 of 3, by Pickelhaube808
leileilol wrote on 2023-05-01, 00:25:
I'll try throwing something like my mach64 in there to test, but if it does turn out to be the nvidia card, i will need to find a 2d card with a good enough ramdac to keep my crt at 150hz. I will have to completely uninstall the rage pro from devmgmt then too because there's no way to physically remove it from the system without desoldering it from the motherboard.
I guess I could also just use a banshee as my 2d card and let 2x voodoo2s do all of the 3d? Or would the banshee fight with the others and try to do the 3d itself?
Reply 3 of 3, by leileilol
I'd also take advantage of the Banshee for 3d because there's some areas where that's better than two Voodoo2s regarding texture management and pixel buffers.
