ROTT Setup in Win95
Reply 40 of 43, by Suzette
Avoid using WinROTT.
Try going into command prompt (Start>run>'command'), change to the rott directory (cd \ROTT\ROTTPLAY\) and run SETUP.
It is possible you were running from a shortcut with a wrong working folder
I did those steps and got the setup to open as before. This time the error said:
"Rise of The Triad Error!
W_Initfiles:no files found"
Just for good measure, after that, i copied all the files from the CD into that folder and still got the same error message.
Reply 41 of 43, by Suzette
Ok i finally got it to run on DOS. Just in case anyone ever needs to run ROTT on win95, here is how to do it:
Go to http://www.3drealms.com/tech/rott.html#manualinstall and click on "downloading this alternate install program first". Save this to an A disk. Make a folder on your C: called download. Unzip the file to that folder. Read the readme for instructions.
Id like to thank each and every one of you who took the time to help me! 😀
Ill be spending the rest of the day playing ROTT!!!!!! Woohoo!
Reply 42 of 43, by leileilol
Cool 😀
Ignore v0g0ns, he's just desperately promoting broken stuff instead of actually helping with tech issues
