Problem with floppy 5.25"
First post, by GEOCE
"I'm having a problem with my 5.25" floppy disk drive. It's very old, over 30 years, and it suddenly stopped reading disks. It's part of my INVES 386SX 25 Mhz computer. When I insert a disk, it acts like it's reading it, but I get an MS-DOS error message "Error initializing disk in drive B:". It's as if it's not detecting the disk. I don't know what to do, I've cleaned it and nothing. Can anyone help me and tell me from their experience how I could fix it? It has incalculable sentimental value and I don't know anyone who can fix this kind of thing." :_(
Reply 1 of 28, by Nemo1985
Forgive me but I wouldn't call it clean...
Check if the heads are clean. If the disk spindle but it's unable to read the best hope is that the heads need to be cleaned, go for a cotton swab wet of ipa.
Reply 2 of 28, by GEOCE
I have cleaned the floppy disk drive head twice, but it's as if it doesn't detect the disk. It's not detecting anything, and the head is not moving or lowering, and the motor is not spinning. It just makes a noise of attempting to read 'tacata tacata' and gives an error.
Reply 3 of 28, by Nemo1985
GEOCE wrote on 2023-05-05, 05:38:
I see, well if it does some noise something is moving... the first thing that happens when you insert a disk is the spindle motor turning on.
Did you try the bios option about the drive seek on boot? If the head is moving forward and backward the problem is somewhere else.
Reply 4 of 28, by konc
Suggestion: try the drive on a completely different computer with different controller and cable, as A: and single. This is to rule out all other parameters and focus on the drive, because right now it's not certain that it's the drive's fault.
Reply 5 of 28, by GEOCE
Yes, during the startup, the head of both drives moves, both the 3 1/2 and the 5 1/4. The BIOS startup process works correctly. The controller works properly and the other connected drive works perfectly, although I have another controller that I could test to rule it out, but I don't think that's the problem. I'll try it out and let you know.
Reply 6 of 28, by GEOCE
What I observe is that when I type B: whether there is a disk or not, I always get the same error. "Not ready reading drive B:" and it makes a "Tacata" noise from the head for a second.
Reply 7 of 28, by Nemo1985
so the head "works", the problem could be the spindle motor or the logic board, how to troubleshoot it I wouldn't know... Do you know what is the model name of the drive?
Reply 8 of 28, by GEOCE
I think I remember that a few months ago, the floppy disk made a loud and unpleasant noise when it was spinning. Could it be the motor? I dont know the model.
Reply 9 of 28, by Nemo1985
Isn't there any label which help to identify it? Can you take the picture of the front panel of the drive?
Reply 11 of 28, by Nemo1985
It seems the Epson SD-600 there should be a small label on the left side if it so...
The problem from your last posts seems to be the spindle motor, can you try it while having it outside of the case? You should be able to check if the disk rotate or not when you insert one.
Reply 12 of 28, by GEOCE
The disk not rotate
Reply 13 of 28, by Nemo1985
apparently we have something to blame then... Unlucky I wouldn't know how to fix it, but if Deunan comes around he has great experience with floppy drives.
I remember I watched a youtube video about the spindle motor but I can't find it right now.
Reply 14 of 28, by GEOCE
Thank you for help me… i want repair.
Reply 15 of 28, by GEOCE
I want to repair it but I don't know where to start. Let's see if you can find the video or if someone knows and can help me
Reply 16 of 28, by Deunan
That drive is very dirty and dusty. Get a small wall painting brush with long, soft hair and clean it. Blow some air through it as well, especially after brushing. Make sure you clean the optical barriers but try to avoid brushing over the worm screw - it has some grease on it and that will stick to the brush (though it's not a big problem, brush can be cleaned, screw can get new grease and even dry but clean screw will work better then dirty one).
That PCB kinda looks like it suffered from a cap spill but it's hard to tell, might be just the dirt. In fact if brushing doesn't do much it might need a proper wash, but lets stick to dry cleaning first.
Can you rotate the spindle (the whole rotor actually) by hand, without using force? Does the the drive spin for a moment when you insert a floppy into it?
Reply 17 of 28, by Nemo1985
It won't be an easy task even more if you can't identify what floppy drive it is.
I hope some other vogonians will be able to help you.
Deunan has come, you are in the best hands now 😀
Reply 18 of 28, by GEOCE
Thank you Deunan. :_)
Which motor are you referring to? I'm a novice at fixing this type of floppy drives. The rotor at the back is working fine, it rotates smoothly when turned manually. When I insert a disk and turn on the drive, it doesn't rotate automatically. Which rotor should I manually rotate to see if it's not stuck?
https://www.youtube.com/shorts/SgtVsg9IqxQ
Reply 19 of 28, by Deunan
Spindle rotor is that big, flat and round thing on the bottom, I asume you turned it and it rotates. It looks like most of the drive actually works but there might be a problem with 12V power supply to the motor board, or it's not getting a clean control signal. Reconnect that small black connector on the side of the main PCB, maybe it's just corrosion and dirt inside. Do you have an ohm/volt meter?
