First post, by atlantisworld
I use StarTech FAN3701U
What adapters can be used to control its speed and noise?
I have it connected to a P5A and k6-2+, it is very good but quite noisy.
Reply 1 of 4, by Dorunkāku
A Zalman fanmate or something like 'Noctua NA-SRC10 3-Pin Low Noise Adapter' will help.
You can use multiple Noctua Low Noise Adapters is series to bring the noise down.
Reply 2 of 4, by bogdanpaulb
You can use something like this if you want to control multiple fans - https://www.google.com/search?q=5.25+fan+cont … =7DkJMcThlC-0xM or like this - https://www.google.com/search?q=bracket+fan+c … =2X7uNy0BcQRqTM - or- https://www.amazon.com/Channels-Cooler-Coolin … t/dp/B07K8TKDXQ - the one star that it got it's probably to the fact that it cant control pwm fans.
Reply 3 of 4, by atlantisworld
Dorunkāku wrote on 2023-05-11, 11:25:
I have gotten a second hand Zalman FanMate 2 Fan Regulator. I think it will be ideal. Thanks!
Reply 4 of 4, by atlantisworld
Here is, Zalman FanMate 2, from 4500 RPM to 2250 RPM, Low Noise 😁
