Reply 140 of 430, by nd22
BIOS settings are not as rich on the KD7A as the other 2 motherboards so I did not took any pictures.
To summarize, the parts I used are:
CPU: Athlon XP 2800
RAM: 2 * 1 GB sticks different models but with the same memory timings set in the BIOS. FSB: DRAM = 1:1.
GPU: Leadtek Geforce 7800gs 256mb
PSU: Enermax 465w with 35A on the 5V rail.
Cooler: some copper based model that kept the temperatures in check despite being no name
DVD: some unknown model
HDD: Maxtor 120 GB on AT7; WD 74 GB on AT7 – MAX 2; WD 120 GB on KD7A.
Monitor: Eizo 21.3 inch 1600*1200 LCD.
Windows: XP SP3 with no updates.
Compatibility testing and setting up took around 6 months for all 3 systems; actually testing the performance took only 2 months! The video card is running without a single problem on all 3 from the outset. Ram: it was quite difficult to find 1 GB sticks compatibles with AT7 – MAX and MAX 2: only the particular modules seen in the pictures work without errors when using aggressive settings, on KD7A the first modules I put in worked with no problems.
