First post, by TamaMan
I upgraded my 486 PC (Informtech IT486SR board with i486DX@33MHz) with an i486DX2@66MHz actually some time ago. All has been well but I have been unable to calibrate/use the joystick, have tried a dedicated Gravis gameport card and different sound cards/joysticks. GRAVUTIL works OK but games don't.
Now just recently tried Doom and Duke Nukem 3D and noticed hanging MIDI notes with the music when General MIDI or Sound Canvas selected. I have the usual SC-55+MT-32 combo hooked up via an SCC-1 MIDI out. Both SCC-1 and SC-55 hang the notes. MIDI music in other GM titles (Colonization, Transport Tycoon, etc.) work OK.
I have tried disabling internal cache and disengaging the turbo button. No help (and no playable Doom/Duke3D).
Am I back to the i486DX@33MHz or what could be the cause?
Thanks!
-TamaMan
High fidelity recordings of 90s PRO MIDI music and game soundtracks on real hardware
486DX@66 MHz, 16 MiB RAM, Trident 8900CL 1 MiB, NEC MultiSync 2A, SB Pro Old, SCC-1, SC-55, MT-32
Reply 1 of 5, by jakethompson1
It's unclear whether you are saying this stuff definitely worked with the 486DX-33 or not.
If it did, then you might consider that this looks like an early 486 board and the BIOS may not know about the DX2-66 and thinks you have a 50 MHz bus, and the ISA slots are running at some unusual speed. If so you might look for the ability to disable any Auto Config features any manually set the ISA divider to 4. You may need to use AMISETUP if the options to do so have been hidden.
Reply 2 of 5, by Horun
Did it properly work with a DX33 ?? The retro web page says it can use a DX2: https://theretroweb.com/motherboards/s/informtech-it486sr.
What joystick are you using ? Sounds like something has gone a-miss and is getting worse. check the PSU, all rails. Also look the caps on the board over closely.
Reply 3 of 5, by TamaMan
The motherboard's manual does list "66MHz 486DX2" as a supported (max) CPU. Jumper settings (CPU type & oscillator frequency) and cache speed requirements are the same than for a 33MHz 486DX CPU.
Joysticks have worked fine with the 486DX@33MHz. The GM/SoundCanvas MIDI (in Doom/Duke3D) situation is unknown as have not tested with the 486DX@33MHz (have sold that CPU after the upgrade). The PC is one of my original ones from the early 90s and I didn't own any Roland/GM/SoundCanvas gear back then.
I'll try to investigate if the BIOS (bus) speed adjustment has any impact on this. And in the meanwhile I'll try to get a 486DX-33 SX419 CPU to rule out any issues with the MIDI adapter (the SCC-1 card).
-TamaMan
Reply 4 of 5, by TamaMan
Update: Changing the DX2 recommended (and BIOS default) "AT Bus Clock Selection" BIOS setting from "CLKI/4" to "CLKI/6" seems to fix the GM/Sound Canvas MIDI issue in Doom and Duke Nukem 3D. Need to test the joystick still.
Reply 5 of 5, by TamaMan
Update 2: The joystick issue was non-related and was limited to only couple of game adapters. Game ports on a Sound Blaster 2.0 and the IT Multipack-4 work OK.
I'll try to measure the bus speed to document the difference between BIOS settings "CLKI/4" and "CLKI/6" if someone else was similar issues with an MPU/SCC-1 card.
