Please provide Linux x86 binaries
Reply 20 of 26, by Napla
Just to let you know.
As usual you can't install anything from source to ubuntu and expect it to work... I just tried to install 0.72 dosbox -> no go... Or at least I can't get midi sounds working, midi works just fine with the "apt-get" version 0.65. Usually the problem is that in ubuntu all default directories are screwed.
MIDI:Can't find device:alsa, finding default handler.
MIDI:Opened device:none
I use exactly same .conf file with both versions.
Reply 21 of 26, by Malcolm81
That's strange, I always compile it from source on Ubuntu and never had any problems. I compiled DOSBox 0.72 a couple of days ago, and everything is working as it should, including MIDI. Are you running Ubuntu 7.04? Maybe there's something about how Timidity is set up?
Reply 22 of 26, by `Moe`
Did you install the libalsa-dev package? (or whatever it is called) For MIDI, you need the ALSA library development package, it isn't handled by SDL AFAIK.
Reply 23 of 26, by Napla
Thanks and sorry all ubuntu lovers 😀 I Just installed randomly alsa packets with synaptics and compiled the source again. Now listening larry 1 vga with mt32d emu... 😉 So after all no need for debian packs.
Reply 24 of 26, by wasiliy
You can get the newest .deb from getdeb.net. Works great for me.
Reply 25 of 26, by valnar
Has there been enough changes to warrant another general release? It would make it seamless for all us Ubuntu or Debian users. 0.73 ??
