First post, by Gamecollector
installh.bat:
Spoiler
echo off
cls
if %1a == a goto Drv
if %1 == c: goto begin
if %1 == C: goto begin
if %1 == d: goto begin
if %1 == D: goto begin
if %1 == e: goto begin
if %1 == E: goto begin
if %1 == f: goto begin
if %1 == F: goto begin
goto Drv
:begin
if %2a == a goto Drv
if %2 == 1 goto getvid
if %2 == 2 goto getvid
if %2 == 3 goto getvid
goto Drv
:getvid
cls
echo
echo Creating directory %1\FMPLAY...
if exist %1\FMPLAY\*.* goto dirct
%1
cd\
md %1\FMPLAY
if %3a == a goto SourceA
copy %3\fmplay\*.dat %1\fmplay\*.* >nul
copy %3\fmplay\*.lo? %1\fmplay\*.* >nul
copy %3\fmplay\fmmap.pak %1\fmplay\*.* >nul
copy %3\fmplay\*.ter %1\fmplay\*.* >nul
copy %3\fmplay\sentinel.exe %1\fmplay\*.* >nul
copy %3\fmplay\fm-*.exe %1\fmplay\*.* >nul
copy %3\fmplay\gamerem.fm %1\fmplay\*.* >nul
copy %3\fmplay\gameA.* %1\fmplay\gameA.* >nul
copy %3\fmplay\gameA.* %1\fmplay\gameB.* >nul
if %2 == 1 goto EGA
if %2 == 2 goto CGA
:TANDY
copy %3\fmplay\song0?.kt %1\fmplay\*.sng >nul
copy %3\fmplay\sfxwar.kt %1\fmplay\*.exe >nul
copy %3\fmplay\grafxtan.exe %1\fmplay\fm-grafx.exe >nul
goto copydone
:EGA
copy %3\fmplay\song0?.kp %1\fmplay\*.sng >nul
copy %3\fmplay\sfxwar.kp %1\fmplay\*.exe >nul
copy %3\fmplay\grafxega.exe %1\fmplay\fm-grafx.exe >nul
goto copydone
:CGA
copy %3\fmplay\grafxcga.exe %1\fmplay\fm-grafx.exe >nul
:copydone
echo Sentinel Worlds GAME DISK now installed on HARD DRIVE %1.
echo
echo Now Insert DATA DISK and use 'INSTALLD' command
…Show last 83 lines
echo
goto done
:SourceA
copy a:\fmplay\*.dat %1\fmplay\*.* >nul
copy a:\fmplay\*.lo? %1\fmplay\*.* >nul
copy a:\fmplay\fmmap.pak %1\fmplay\*.* >nul
copy a:\fmplay\*.ter %1\fmplay\*.* >nul
copy a:\fmplay\sentinel.exe %1\fmplay\*.* >nul
copy a:\fmplay\fm-*.exe %1\fmplay\*.* >nul
copy a:\fmplay\gamerem.fm %1\fmplay\*.* >nul
copy a:\fmplay\gameA.* %1\fmplay\gameA.* >nul
copy a:\fmplay\gameA.* %1\fmplay\gameB.* >nul
if %2 == 1 goto EGAA
if %2 == 2 goto CGAA
:TANDYA
copy a:\fmplay\song0?.kt %1\fmplay\*.sng >nul
copy a:\fmplay\sfxwar.kt %1\fmplay\*.exe >nul
copy a:\fmplay\grafxtan.exe %1\fmplay\fm-grafx.exe >nul
goto copydoneA
:EGAA
copy a:\fmplay\song0?.kp %1\fmplay\*.sng >nul
copy a:\fmplay\sfxwar.kp %1\fmplay\*.exe >nul
copy a:\fmplay\grafxega.exe %1\fmplay\fm-grafx.exe >nul
goto copydoneA
:CGAA
copy a:\fmplay\grafxcga.exe %1\fmplay\fm-grafx.exe >nul
:copydoneA
echo
echo
goto done
:Drv
cls
echo ╔═══════════════════════════════════════════════════════════════════════╗
echo ║ Sentinel Worlds Hard Disk Installation ║
echo ║ ║
echo ║ There are several parameters that can be used in this installation ║
echo ║ program. The format for this command is: ║
echo ║ ║
echo ║ installh t: v [s:] ║
echo ║ ║
echo ║ where t: is the target drive you wish to install Sentinel Worlds onto ║
echo ║ Drives C:, D:, E:, F: are the only valid target drives. ║
echo ║ v is the video display adapter you have (1=EGA, 2=CGA 3=Tandy 1000). ║
echo ║ ║
echo ║ [s:] is optional, and is the source drive that contains your orignal. ║
echo ║ if you do not specify any drive, A: will be assumed. Use this if you ║
echo ║ are installing from a drive other than A: ║
echo ║ Examples: ║
echo ║ installh c: 1 This installs Sentinel Worlds onto drive C: from ║
echo ║ drive A: using the EGA graphics driver. ║
echo ║ installh d: 3 b: This installs Sentinel Worlds onto drive D: from ║
echo ║ drive B: using the Tandy 1000 graphics driver. ║
echo ║ ║
echo ║ If you don't want to install Sentinel Worlds now, press Ctrl-c. ║
echo ║ When the message asks if you want to terminate the batch job type Y. ║
echo ╚═══════════════════════════════════════════════════════════════════════╝
pause
goto error
:dirct
echo
echo Installation Error!
echo Sentinel Worlds has been installed on the specified drive.
echo To reinstall, delete all files in the FMPLAY subdirectory, then try
echo installing again.
echo
goto done
:error
echo
echo Sentinel Worlds has not been installed successfully. Perhaps there is not
echo room on the disk, you need at least 720K of free disk space.
echo
:done
"Copy a:\fmplay\gameA.* %1\fmplay\gameA.* >nul", "copy a:\fmplay\gameA.* %1\fmplay\gameB.* >nul", "copy a:\fmplay\song0?.kp %1\fmplay\*.sng >nul" and "copy a:\fmplay\sfxwar.kp %1\fmplay\*.exe >nul" fail in DOSBox 0.74-3.
I can't use file masks in a COPY destination? Except "*.*"? Seriously?
Reply 1 of 1, by Awasaky
This bug happens when trying to install Sentinel Worlds I: Future Magic from mounted image of original diskette 3.5 or 5.25 to virtual hard drive.
Checked 0.74-3, 0.73, 0.65
But with DOSBox Daum 27.01.2014 installer works correctly.
