First post, by Red_Machine
So I ordered this thing of AliExpress, miraculously enough it arrived unscathed and I set to work trying out various games and software on it. All seemed to be working fine, until I was trying out a DOS MIDI player (dosmid). After about half an hour of testing various MIDI files, it seems to have locked up during play, the screen went blank and there was some very weird sound output going on. I figured it had just hardlocked, so I turned it off and on again, only to be met with the same black screen and weird noises. Ctrl-Alt-Del won't make it restart, and no amount of power cycling would clear the problem. I've had experience running DOS on laptops before, and sometimes a power off from the button won't completely shut down the unit and you have to remove the battery to get it to fully power off and cold boot. So I dismantled it and unplugged the battery, leaving it for about half an hour for everything to discharge and then put it back together. No dice, same issue. I thought maybe the OPL3 sound card had locked up or something, so I removed that, and while it stopped the sound the machine still wouldn't boot. I put it back in, turned it on and the sound came back as before. I experimented with some of the button combinations, and discovered that it still responded to the commands to turn the speakers on and off and also enable/disable turbo mode, which changed the speed at which the sound was generated. I decided to leave it sitting on for a while, in the hope that it was just still hobbling along trying to play the MIDI file, and now the sound has stopped but it still won't reboot.
I'm stumped at this point, and any help would be appreciated!
Reply 1 of 3, by keenmaster486
You might have no choice but to open it up and check components. Reseat all cables and chips and if that doesn't work you may have to rework solder joints.
World's foremost 486 enjoyer.
Reply 2 of 3, by Daniël Oosterhuis
Oh dear, you're not the first to have issues with one of the two products from this AliExpress seller. Rasteri and Action Retro on YouTube both had the Hand386s they were playing with develop faults quickly. Hopefully this isn't a sign for all of the B8088s and H386s, but it's certainly not encouraging for units to fail this quickly after first use.
Reply 3 of 3, by rasz_pl
20 year old chips, most likely not stored correctly and not baked before soldering, might need going over all the solder joints.
