First post, by buckeye
Wanting a new "foundation" for my XP system so hoping for some suggestions. The Intel 35DP35 I have now
is too barebones therefore looking for something with a little more "muscle".
My current specs:
CPU: Intel E8600 3.33GHz. Duo Core 2
Motherboard: Intel DP35DP
Memory: 4GB 800MHz. DDR2 Corsair
CPU Cooler: Zalman CNPS9500
GPU: EVGA Geforce 470
Storage: TeamGroup T-Force Vulcan 512GB SSD
Sound Card: Creative Labs X-Fi Titanium PCi-E
Looking for something with beefier heatsinks, ps/2 connections, (2) PCi-E slots. Any ideas appreciated!
Reply 1 of 8, by ciornyi
Hey mate , I'd assume by 2 pci-e slots you mean 16x or full sized ? If so there is two options with crossfire or sli plus full speed or only half per slot.
Here is list you can choose from :
https://theretroweb.com/motherboards/?showIma … 5D%5Bcount%5D=2
DOS: 166mmx/16mb/Y719/S3virge
DOS/95: PII333/128mb/AWE64/TNT2M64
Win98: P3_900/256mb/SB live/3dfx V3
Win Me: Athlon 1700+/512mb/Audigy2/Geforce 3Ti200
Win XP: E8600/4096mb/SB X-fi/HD6850
Reply 2 of 8, by cyclone3d
A good LGA1366 setup would be even nicer than LGA775.
If you really want 2x x16 PCIe slots that can run at x16 at the same time on LGA775, the options are going to be pretty limited.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 8, by RandomStranger
How about the ASUS P5E Deluxe? I thinkt it's a nice looking board.
Reply 4 of 8, by informatyk
P5Q boards are even better than P5K. I am using Asus P5Q Pro in my XP build. It can also work with Xeon-s after modification of lga and bios which I did.
LGA1366 boards are expensive and rare
Reply 5 of 8, by buckeye
ciornyi wrote on 2023-06-08, 05:37:
The only reason I wanted (2) pci-e slots was for flexibility regarding placement of the sound card. The geforce 470 runs hot and didn't want
the sound card too close to it.
Reply 6 of 8, by buckeye
cyclone3d wrote on 2023-06-08, 06:20:
LGA1366 huh? Didn't even think of that one. Do you have a setup for reference?
Reply 7 of 8, by buckeye
RandomStranger wrote on 2023-06-08, 06:36:
How about the ASUS P5E Deluxe? I thinkt it's a nice looking board. https://www.scspb.ru/php-files/infusions/oscommerce/images/mb […]
Yes that one looks nice indeed, plus I can put the sound card farther away from the geforce.
The beefier heatsinks/piping will help with temps too.
Reply 8 of 8, by bogdanpaulb
I would go lga1366 but in my case i want/need: serial/parallel/fdd/ide+sata/pci-e and pci slots because it's a all in one win xp / win 7 machine for me and my main 'work horse'. Lga1366 boards that check all those boxes without additional cards to be added are hard to find (and besides some workstation ones that are not so 'bright', generally expensive on the market here) but P45/P43 lga775 boards are still fairly cheap and common. So it depends on what are your needs.
