First post, by BEEN_Nath_58
By mistake I proceeded to automate a Windows 11 installation instead of Windows 10, on my old Intel 3rd gen Pentium CPU. For some reason, it installed and is working quite well. So did MS remove the restriction?
Reply 1 of 17, by Trashbytes
BEEN_Nath_58 wrote on 2023-06-09, 06:09:
Might depend on the version of Windows 11 you are installing.
I did find this over on Microsoft
https://support.microsoft.com/en-us/windows/i … 09-ef0a331518f1
Seems to suggest that Windows 11 will install regardless of requirements now but will kindly let you know after install that its not supported by MS, also suggests you are not guaranteed to get updates, pretty sure you'll get updates no issue would be silly of MS to deny security updates.
Reply 2 of 17, by mwdmeyer
If you install via ISO I don't believe there is the same restriction as there is to doing an upgrade from within Windows 10.
Reply 3 of 17, by BEEN_Nath_58
mwdmeyer wrote on 2023-06-09, 06:19:
On my AMD Ryzen 5 1600 machine, the installer refused to proceed without enabling fTPM. On that Intel, it didn't even have any TPM...
Reply 4 of 17, by mwdmeyer
Interesting, I thought you still needed TPM.....
Reply 5 of 17, by Robbbert
I've never tried installing Windows 11 since none of the hardware in my collection (over 70 pcs) is supported, and I wasn't going to throw cash around just to appease Microsoft. The main problem is none of them have TPM 2.0, and the majority are 32-bit only.
Using Windows 11 is therefore assumed to never going to happen.
I looked up "Intel 3rd gen cpu" and it showed a list of Xeon processors from just 2 years ago. Is this what you're using?
Reply 6 of 17, by Grzyb
You mean Ivy Bridge, from 2012..2015, right?
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 7 of 17, by DosFreak
What do you mean by "automate"? Are you being intentionally vague?
AFAIK, there are various methods. The most well known is using the windows 10 setup with the windows 11 install.wim but all I ever use is a batch file on the root of the cd that adds the registry keys needed to bypass the requirements. Using that I've ran 11 on my c2Q since release with no issues. I don't use preview builds since I dont believe on being a guinea pig anymore than I already am with the regular so called final builds of Windows.....
If by automate you mean you created an image and then restored it then I don't see why that wouldn't work, the requirement has so far just been for the installer not for running Windows 11.
Make your games work offline
Reply 8 of 17, by Trashbytes
DosFreak wrote on 2023-06-09, 10:10:
Perhaps they are using a script to automate the install process, much like IT would do for unattended installs.
Reply 9 of 17, by BEEN_Nath_58
Robbbert wrote on 2023-06-09, 09:01:
Grzyb wrote on 2023-06-09, 09:35:
This one
https://ark.intel.com/content/www/us/en/ark/p … e-2-90-ghz.html
The automation script does the post-setup job itself. I was not wearing my spectacles when I was preparing to click on the Install button on the installer, so I proceeded unconsciously. I returned after 15 mins to see the Windows 11 on my screen.
Reply 10 of 17, by weldum
well, I've installed and used successfully windows 11 in various old "unsupported and therefore imposible" machines
-atom n455 with 2gb of ram (awful and drivers were problematic)
-atom n2600 with 2gb of ram (slightly less awful but drivers were worse)
-athlon 64x2 tk57 with 4gb of ram (everything works but is slow)
-pentium t4500 with 4gb of ram (sound doesn't work as it uses an idt soundchip)
-celeron n2840 with 4gb of ram (everything works but is slow because of "efficiency cores")
-phenom x3 8400 with 4gb of ram (everything works but is slow)
all of these machines are way older than the slowest supported machine according to Microsoft and still they run it in some form, the only thing I had to do was to write the original iso from Microsoft website with rufus
rufus will ask you if you want to bypass the requirements check and makes the modifications needed, then i put an ei.cfg file on to the sources folder to allow me to choose the sku
never had a problem
ps: all but the celeron n2840 are bios machines and therefore doesn't support uefi boot nor gpt partition scheme on boot devices, and still windows boot without any additional software
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 11 of 17, by BitWrangler
Good to know there are gonna be options when 10 is no longer getting security updates, on modest systems. Is there a way to obtain specific releases at the moment, or should I download and save this known to work era release for future?
3rd gen pentium though, heh good thing you linked it because I was thinking, P5>P54>P55? nah... Pentium III? nah... Merom, allendale, clarkdale? Maybe?....I know everything up from Nehalem gets called gen 1 2 3 etc, but I usually qualify it with generations of core-i, because there was 2 gens of core before that. THEN there's the generations of x86 cpu architecture that has PPro etc as 6th gen, blah blah, but seemed only AMD was counting after that, K7 K8 etc
Reply 12 of 17, by SPBHM
I had win 11 on my Sandy Bridge system and it worked fine, but I kind of had to force install it,
on my Haswell system (4th gen) I'm not getting the option to update or install 11 without forcing it either,
Reply 13 of 17, by Cosmic
I ran Windows 11 on an i5 Sandy Bridge Thinkpad X230 for a couple weeks. It didn't make good use of the small 1366x768 display though, so I went back to Windows 10 which flies on this CPU. I plan to run Windows 10 LTSC and maybe the IoT version for a while after mainline 10 EOLs. I'm slowly warming up to 11... but I still don't like the taskbar and start menu changes.
UMC UM8498: DX2-66 SX955 WB | 32MB FPM | GD5426 VLB | Win3.1/95
MVP3: 600MHz K6-III+ | 256MB SDRAM | MX440 AGP | 98SE/NT4
440BX: 1300MHz P!!!-S SL5XL | 384MB ECC Reg | Quadro FX500 AGP | XP SP3
Reply 14 of 17, by leileilol
op didn't install win11 on a pmmx.........smh
Reply 16 of 17, by Cosmic
schmatzler wrote on 2023-06-10, 00:19:
Cosmic wrote on 2023-06-09, 23:53:
https://github.com/valinet/ExplorerPatcher
Cheers schmatzler. I've seen the Classic Shell and similar replacements, but the linked ExplorerPatcher looks much more like what I would want to use. I've made it through many Windows upgrades and always spent some time using solutions like this to get comfortable, this is the first that I really like for Windows 11. Thanks for the link.
Reply 17 of 17, by ptr1ck
I'll put another vote in for Explorer Patcher.
The only issue I have had with it is, sometimes after a windows update, the symbols for Explorer Patcher need to be reacquired and the application restarted. Occasionally this means I need to hit task manager and restart it manually after rebooting from update because the desktop will be all black.
"ITXBOX" SFF-Win11
KT133A-NV28-V2 SLI-DOS/WinME
