First post, by wariacix
PIII 450MHz + Voodoo 2 12mb seems balanced, if not even cpu-sided. But I've just found Geforce 2 MX 400 64MB for literally nothing and ordered it, should I expect a CPU bottleneck now?
I'm planning on trying out some 2000-2003 games with it, since on voodoo they'd probably do less than 15-20 fps.
    1.63 MiB
    The card itself (pulled right from the seller)
P!!! 450 MHz; 256 MB PC100; nVidia Riva TNT2 M64 32mb + 3Dfx Voodoo 2 12mb; Windows 98 SE
Reply 1 of 10, by gamefan_851
Really funny how many people here are in similar boat at the moment.
I am about the make my first pc with a 440bx intel chipset, socket 1 and a cpu between 400 and 800mhz and the mx440 was recommended to me as potential card.
Then we have this guy here
Fastest graphics possible for a p2 400 mhz (Asus P2B mainboard)
that is in almost exactly the same boat as you are and to him the mx 440 was also recommended.
I am not expert just a noob but If the gf4 mx440 is recommended for similar set ups than yours the gf2 mx 400 should be alright.
Reply 2 of 10, by chinny22
What's your currant 2d card?
But yes I'd say its a perfect match. V2 SLI for Glide, and the GF2 MX for 2d/D3D
Reply 3 of 10, by danijelm
I tried this combination a few years ago. All CPUs work at 4.5 x100 = 450 mhz.
The table shows the results of Quake 1 in software V2 and GF mode.
Intel cpus at 450mhz test
I speak sarcasm as a 2nd language
Reply 4 of 10, by rasz_pl
wariacix wrote on 2023-06-11, 23:21:
those will require 2-6x the CPU power to run comfortably
Reply 6 of 10, by wariacix
rasz_pl wrote on 2023-06-12, 14:49:
Especially the later ones probably will not run well, but I have the P3 550MHz laying around, might finally change it and it should improve the situation
Reply 7 of 10, by AlexZ
2000-2002 games require a faster CPU. My PIII 900E can handle them fine, but it isn't fast enough for 2003. You should also get at least GeForce 4 MX440 (128 bit version), not a GeForce 2 MX. FX5600 works too, but it may exhibit font defects in some games. PIII 800-900 are still plentiful.
Voodoo 2 is for 1997-1998. In 1999 Direct 3D support was more common or at least patches were provided. Once you try later games, you will completely forget about Voodoo 2 and 1997-1998.
Pentium III 900E, ECS P6BXT-A+, 384MB RAM, NVIDIA GeForce FX 5600 128MB, Voodoo 2 12MB, 80GB HDD, Yamaha SM718 ISA, 19" AOC 9GlrA
Athlon 64 3400+, MSI K8T Neo V, 1GB RAM, NVIDIA GeForce 7600GT 512MB, 250GB HDD, Sound Blaster Audigy 2 ZS
Reply 8 of 10, by wariacix
I think I'll try to use a Slotket to get a socket 370 processor on board. The problem is I'm not confident it will work, as there's limited data on how they work - my board supports FSB 100 and it doesn't have even coppermine support, and I would like to try coppermine - will it work?
MOBO: MSI MS-6163VA
Reply 9 of 10, by rasz_pl
yay VT82C693, your computer is 30% slower than normal from the start thanks to chipset.
You can still stick 2MX in there, but your boards chipset has broken AGP support and you might experience instability (crashing unless switched to slower AGP mode or older nvidia drivers).
If you really want 2003 games look around for old brand name (that usually means Intel chipset) Pentium 4 office PC with AGP slot. Those are usually extremely cheap (throwaway value) and will deliver solid ~2005 performance.
Reply 10 of 10, by wariacix
I'm not really that much into it, I just want them to work, I'm mostly interested in 1996-2001 tbh so 2mx will probably do fine, but thanks for advice, maybe I'll buy one some day 😁
