First post, by link7458
Sorry,I am come from Taiwan,Taipei,and my English level is low.
If I locale the game:Princess Maker 2 with DosBox;It will be cause some problem,but I used command (CMD);the game can locale.
I typed these message to locale the game:
Z:\>SET BLASTER=A220 I7 D1 H5 T6
Z:\>SET ULTRASND=240,3,3,3,5
Z:\>SET ULTRADIR=C:\ULTRASND
Z:\>mount D D:\
Drive D is mounted as local directory D:\
Z:\>D:
D:\>cd dosgames
D:\>DOSGAMES>cd pm2
D:\>DOSGAMES\pm2>pm2.exe
But It will be display this string error message:
Exit to error: CPU:GRP5:Illegal Call 7
I already tried to change the game configure,and didn't use EMS memory,but not solve this problem.
*My DosBox is newest version
The game:Princess Maker 2 download link:
http://www.box.net/shared/ydx75pn94m
The file storage from http://www.box.net/
Please help me to solve this problem. Thasnks a lot.
The game Image:
    31.16 KiB
Reply 2 of 8, by link7458
collector wrote:
Run the game's setup to set the game to not use ems.
Sorry,I said that before. I didn't use EMS memory,and the problem not solve yet.
Reply 3 of 8, by eL_PuSHeR
Try mounting as "mount d d:\dosgames" or "mount c d:\dosgames" to see if there is some difference. Then...
d:
cd pm2
pm2
or
c:
cd pm2
pm2
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 8, by eL_PuSHeR
Try editting dosbox.conf and set ems=false.
Open dosbox.conf with notepad. It's a text file.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 6 of 8, by link7458
I edited dosbox.conf with notepad;the problem was same.
Thanks for your helping.
Reply 7 of 8, by millin
[cpu]
# core -- CPU Core used in emulation: normal,simple,dynamic,auto.
# auto switches from normal to dynamic if appropriate.
core=full
Although not listed, but set core=full is the only choice to let this game run.....
PocketDosBox
Reply 8 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
are you certain ? I used to play pm2 a lot in the past, but I must admit that I haven't tried it recently.
Water flows down the stream
