First post, by Demolition-Man
- Member
I have two different RIVA 128 PCI cards, a Diamond Viper V330, and an Elsa Victory Erazor 4. The Diamond card worked perfectly, but when testing other graphics cards including the Elsa card, I lost the driver for the Diamond. I have tested five different drivers for the two cards, none of them work completely. Three special drivers for the Diamond. One for Windows 95, two for Windows 98, plus the last general RIVA 128 driver in version 3.37. With the Elsa there were two drivers specifically for this card and the general driver. Depending on the driver, there are problems with 3DMark 99 in the "Texture Filtering Speed" tests and always with "n Pixel Polygons". Also, depending on the driver, my DVD player (PowerDVD 4.0) no longer works.
Maybe it only affects 3DMark 99, the DirectX tests and e.g. Turok work. Do you have another driver that you can recommend? Maybe a later unofficial driver? Difficult to say which specific drivers I had tested exactly because the version number cannot be recognized afterwards. Who has experience and can help?
Thanks!
