First post, by theiceman085
I am shopping around now for a replacement for my Riva TNT 2 in my P2 400 MHZ system with an Asus P2B mainboard.
At some point in the future, the P2 400 will be replaced with the P3 900mhz ( have already purchased that cpu should arrive soon) but for the few month, I want to play around with the P2 400 MHz to see what it can do.
My initial GPU of choice where either the gf mx 400 or the gf mx 440 but while shopping around and researching the gf3 family caught my attention.
The hardware features sound quite interesting and the cards especially the gf 3 ti 200 do not cost a fortune.
The original Gf3 is a bit rarer but I have seen a Elsa Geforce 3 for a good price.
Would you guys say that there is a reason from a purely technical point of view to choose an original Geforce 3 over the ti 200?
Which one would be the better partner for my Asus P2B mainboard when it reaches its final form with the P3 900 MHZ
Reply 1 of 14, by bloodem
The GeForce 3 Ti has lower core/memory clock speeds compared to the vanilla GeForce 3, which results in a ~ 10 - 15% speed difference.
Definitely not something to write home about, but if you can get it for a very good price, the GeForce 3 is better (and it's more desirable/sought-after).
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 2 of 14, by iraito
The difference on a P3 900 would be negligible since both cards would be bottlenecked, i would go for the Ti200, even on a fast P4 the difference wouldn't be that high, it's actually around 10% no more no less.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 3 of 14, by bloodem
iraito wrote on 2023-06-21, 17:25:
This would be true for lower resolutions, however at 1280 x 1024 / 1600 x 1200 the GeForce 3 (Ti 200) is a good match for the P3 900 when it comes to period correct games.
Reply 4 of 14, by iraito
bloodem wrote on 2023-06-21, 17:28:
Uhm yeah in this case it would be useful, but both of them would behave really similarly with the CPU in question.
Reply 5 of 14, by The Serpent Rider
Original GeForce 3 is an underclocked GeForce 3 Ti 500 in all but name really. GeForce 3 Ti 200 is a different beast, because it's not only underclocked, but also undervolted GeForce 3 with usually simplified PCB and VRM, which might be useful - less heat and less power consumption, even when overclocked to match clock speed of GF3/GF3Ti500.
Reply 6 of 14, by theiceman085
bloodem wrote on 2023-06-21, 17:25:
Thanks for the info. Yeah from a collectors point of view the Elsa Geforce would be the first choice because it es much rarer. The price is a bit higher than the ti 200 but if is a bit better i might consider getting it and not the ti 200.
The resolutions I want to play are not super high. only 800x600 and 1024x768. I think most of the old games I am into look the best with that resolutions.
@iraito and serpent rider Thx for your replies as well.
Reply 8 of 14, by theiceman085
A001 wrote on 2023-06-21, 20:22:
The Gladiac 920 has razor sharp output even at highest resolutions.
Thanks for the info. That's good to know that these cards have very good image.
Reply 9 of 14, by Errius
Watch the fans with these. If the fan dies you have just seconds to shut down the computer before the GPU dies too.
My Gladiac 920 (2001-6) survived one fan failure, but not a second. I was too slow.
Is this too much voodoo?
Reply 10 of 14, by theiceman085
Errius wrote on 2023-06-22, 10:15:
Thanks for the warning. It is good to know that there might be some issues with the fan and that card overheats fast if the fan dies.
I will not forget the warning in case I should go with the Elsa card.
So far the seller has not replied to my email if his offer is still active or not.
Reply 11 of 14, by ciornyi
Id take them both .I have one from gainward and it performs very well here 3dmark01 score:
    249.67 KiB
    267.52 KiB
DOS: 166mmx/16mb/Y719/S3virge
DOS/95: PII333/128mb/AWE64/TNT2M64
Win98: P3_900/256mb/SB live/3dfx V3
Win Me: Athlon 1700+/512mb/Audigy2/Geforce 3Ti200
Win XP: E8600/4096mb/SB X-fi/HD6850
Reply 12 of 14, by The Serpent Rider
theiceman085 wrote on 2023-06-22, 11:00:
I suggest to replace it to one of those Zalman flower cooler clones without waiting. Original coolers for GeForce 3 and 4 Ti series mostly were sub-optimal anyway, even in pristine condition.
Reply 13 of 14, by iraito
The Serpent Rider wrote on 2023-06-23, 16:07:
I suggest to replace it to one of those Zalman flower cooler clones without waiting. Original coolers for GeForce 3 series were sub-optimal anyway.
And i second this, i did just that with mine and the overclocking is ridiculous while still keeping really cool.
Reply 14 of 14, by theiceman085
iraito wrote on 2023-06-23, 16:09:
Thx for the info. I am going to that to be on the save side.
I got the the elsa card btw. Will get shipped to me tomorrow.
