First post, by sjjot
Hi , can anyone help me ?...I can get the Duke3D heading on DOSbox but I don't know what to type to get to the setup screen . Any sort of help would be useful . Thanx in advance , sjjot .
.......why's it always the build/wolf engine people?
setup.exe
Debian's fucked
wrote:.......why's it always the build/wolf engine people?
setup.exe
I tried this but it didn't work . When it showed this...c:\>...I typed ...setup.exe...& it went to the next line with just beeping colon & nothing else ...like this one only horizontal . Any other ideas please ?
Do you have output=surface in your dosbox.conf file? If so, try anything else like overlay, ddraw or OpenGL.
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Did you install Duke3D through DOSBox? Which game version do you have?
"What's a paladin?!"
wrote:I tried this but it didn't work . When it showed this...c:\>...I typed ...setup.exe...& it went to the next line with just beeping colon & nothing else ...like this one only horizontal . Any other ideas please ?
What did you mount as "C:"? "\Duke3D"?
You could always run setup in windows and just run the actual game in dosbox, but again it should work just fine if everything is in the right spot.
wrote:Did you install Duke3D through DOSBox? Which game version do you have?
I installed Duke on Windows & its version 1.5 .
Install it in DOSBox then. Should work just fine (at least it does for me).
wrote:Install it in DOSBox then. Should work just fine (at least it does for me).
Thanx for your help but i found another solution...eduke32 .
*bangs head on desk*
wrote:wrote:I tried this but it didn't work . When it showed this...c:\>...I typed ...setup.exe...& it went to the next line with just beeping colon & nothing else ...like this one only horizontal . Any other ideas please ?
Ok , i found an easier way...no typing ! I found this port called eduke32 . I just put that & my duke files together & i'm running . I appreciate your help , thanx .
/me supports red_avatar in banging heads onto tables
/me gets ready to hand out aspirins.
_________________
I agree entirely.
For the record - the fact that Duke was installed outside of DOSBox is completely irrelevant.
