Reply 49640 of 53137, by weedeewee
HanJammer wrote on 2023-06-26, 18:36:
This rare graphics card. Apparently it's high res monochrome card which came with vertical monochrome monitor (which I don't have). Still super interesting piece of hardware for a price I paid.
128KByte DRAM, 16Kbyte SRAM, 1Kbyte Imox? RAM
Curious what resolution this gives, what frequencies it outputs, and how easily one of those Rpi powered MDA/CGA/EGA to HDMI converters could be adapted to output to a hdmi capable monitor.
Do not ask Why !
Reply 49641 of 53137, by pentiumspeed
This is a dumb video card due to lack of CRT controller and it is driven by the firmware till compatible program designed for this or via a driver to drive it properly at high resolution.
Cheers,
Great Northern aka Canada.
Reply 49642 of 53137, by pentiumspeed
Finally found and bought a vintage ATX case that does have floppy bay, which is exactly same means this will be second one to my first one. This is what I had back in the day in 2002 or so.
Had to pay lot anyway.
Once here, this adds to my first, which these two cases, will be intended for PIII and Pentium class SBC computer.
Cheers,
Reply 49643 of 53137, by ediflorianUS
HanSolo wrote on 2023-06-26, 11:04:
Thanks for the suggestions. Pulling out the RAM board, CD and HD drive and main battery didn't change anything. What I think is […]
Thermalwrong wrote on 2023-06-25, 17:33:
Pull out the expansion RAM board which you can get to from the slide off cover underneath, that's caused real problems on my Thi […]
HanSolo wrote on 2023-06-25, 16:46:
Got an untested IBM 760ED notebook for little money. That's the one with the flip-up-keyboard.
Unfortunately it doesn't show any signs of life 🙁 So I'll probably sell it again for parts.
Pull out the expansion RAM board which you can get to from the slide off cover underneath, that's caused real problems on my Thinkpad 760EL - still can't get that working properly in fact. But it works okay without it.
The Thinkpad 760 series outputs some POST code information through the parallel port, if you've got a reader for that.
Also there's a NIMH battery hiding inside the keyboard part under the palm-rest plastic, which usually damages traces in the area.
ediflorianUS wrote on 2023-06-25, 17:18:
hi. How much for the IBM 760ED? do you need assistance in trying to fix it?
What I think is strange is that it shows absolutely NO sign of life. I think next I'll try to measure the power supply (have to find the pinout first since it has 4 pins).
Then I'll take a look at the other battery.
It probably blew the main fuse-resistor from overvoltage of PS. Easy fix , just try to change the fuse. should work. as sorin says : check main rail 15-16V , then 5V than 3.3v , if you have volts on evrything than it's a problem if it starts and give's black screen (I have IBM that gives green led/hdd/fan but nothing on screen)
My 80486-S i66 Project
Reply 49644 of 53137, by HanJammer
weedeewee wrote on 2023-06-26, 19:04:
This guy has some specs. And pics of the monitor it came with.
https://twitter.com/compu_85/status/1586878113342181376
Reply 49645 of 53137, by WJG6260
Somehow managed to find one of my dream motherboards, and cross it off the list. Never thought an AMI Mark V Baby Screamer would pop up.
Gonna make for one interesting 386 setup, likely with a 486SXL at the helm.
For now, seller’s pics.
371.86 KiB
473.21 KiB
-Live Long and Prosper-
Feel free to check out my YouTube and Twitter!
Reply 49646 of 53137, by pentiumspeed
Remember this American Megatrends did not design the chipsets, rather got typical chipsets remarked with their logo.
Cheers,
Reply 49647 of 53137, by ubiq
Found a GUS from a local seller whose asking price didn't make my eyes bleed.
1.09 MiB
I had a GUS ACE back in the day. Seemed the best way to do it - GUS as a dedicated add-on card without any extra bits fighting another sound card for resources. Don't hear much about those particular cards anymore - guessing they must be rare. Miss mine. 😢
Anyway, I've got this thing to play with now. The slot bracket appears to be made of oddly cheap and bendy aluminum - is this original? If so I guess that's part of its charm, if not then 🤷‍♂️ it will work.
Reply 49648 of 53137, by froller
Texas Instruments PCI1410PGE-based PCMCIA to PCI adapter.
1.98 MiB
1.64 MiB
Despite 5V and 3.3V keys present this board is capable of 5V power only. 3.3V power circuit is unpopulated.
▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ 100%
Virus check complete. All viruses are working properly.
Reply 49649 of 53137, by froller
3 generations of PCMCIA GSM modems by Nokia.
1.73 MiB
1.64 MiB
Reply 49650 of 53137, by danieljm
ubiq wrote on 2023-06-27, 23:58:
Found a GUS from a local seller whose asking price didn't make my eyes bleed. IMG_5375.jpeg […]
Congrats on the find. I just recently found the exact same revision myself (also with a price that was just outside of eye bleeding territory). I poked at the bracket on mine and I would say that is certainly somewhat bendy. But not much more than any other similar bracket that is only mounted by the standoffs on the gameport. In general, if they're screwed into the PCB or have a bend down one side I find they are usually much stronger.
Reply 49651 of 53137, by Trashbytes
froller wrote on 2023-06-28, 00:24:
Kinda curious why people collect old modems, I mean is there any practical use for them since most networks are now digital? does GSM even still exist out in the wild ?
Reply 49652 of 53137, by appiah4
I've been a sucker for punishmentof late, eager to jump on damaged, non-working boards that I lack in my collection, so I grabbed these:
269.21 KiB
199.44 KiB
ZIDA 5DHX-512 sold as not working. It had very detailed photos and as far as I can see nothing is wrong with it except a missing BIOS and a dead battery. Both fixable. Fingers crossed.. I have no HX boards in my hoard so I sprang for it, not a bad deal for 5 bucks.
Then this showed up:
171.92 KiB
181.16 KiB
The battery corrosion is scary, but I hope it is not as bad as it looks, and repairable. It also came with an ISA VGA, ISA Multi-IO, 30-pin RAM and an AM386DX-33, so even if the corrosion damage can't be fixed, it wasn't for nothing. I have other working 386DX boards but I thought saving this would be a nice challenge, so I paid 14 bucks for the lot. Again, not bad.
Fun projects regardless.
Reply 49654 of 53137, by HanJammer
This rare-ish Triumph Adler system along with original monitor.
Reply 49655 of 53137, by theiceman085
Got 2 video cards for my asus p2b p2 400 mhz (later it will be be turned into p3 900 mhz system) a elsa gladiac geforce 3 and a Gainward Geforce Ti 4200. Both cards were available at a good price and I could not resist.
Reply 49656 of 53137, by Trashbytes
appiah4 wrote on 2023-06-28, 06:03:
I've been a sucker for punishmentof late, eager to jump on damaged, non-working boards that I lack in my collection, so I grabbe […]
I hope that's just dust on U29 IC .. but I suspect its not .. it looks weirdly squished on the far end, hopefully its as you said and the damage isnt terminal.
Overall the board looks filthy like its been hiding in a pig pen or Chicken coop,.
Noticed two Three of the ram slots are busted in a way that makes them painful to fix.
Reply 49657 of 53137, by appiah4
Trashbytes wrote on 2023-06-28, 09:56:
I hope that's just dust on U29 IC .. but I suspect its not .. it looks weirdly squished on the far end, hopefully its as you sai […]
U29 and simm slots will need replacing probably.
Reply 49658 of 53137, by HanSolo
Trashbytes wrote on 2023-06-28, 03:34:
Maybe they simply like looking at them?
Collecting something has seldom anything to do with practical use.
And even if something could theoretically be used, like e.g. old graphics cards, a collection of those cards usually means that they just rot unused on the shelf (or in a box in the attic).
Reply 49659 of 53137, by Daniël Oosterhuis
It is possible to run your own GSM network with software defined radios that can output on the right frequencies, so these could potentially be used with the right equipment and software.
Legality differs per state and country, of course, but for instance, I know in my country (the Netherlands), low power 1800MHz band GSM is fair game without a license or permit, and I think 900MHz may be as well (though not 100% sure, legalese isn't my strongest suit 😁 )
Similarly, there is the ability to run dial up networks at home, with the right equipment even up to 56K (V.90/92).
But yeah, it might also just be for collecting sake.
