Reply 20 of 54, by The Serpent Rider
Which is not so surprising, because both are DirectX 6 games.
Reply 21 of 54, by pentiumspeed
Geforce2 Ultra is expensive and difficult to find. If we don't mind not using 8 bit platted and fog table, ATi Radeons using older drivers that is stable and is compatible? The intent is finding out so we can have more options?
All we can get more easily is good MX400 128bit and Geforce2 GTS and some Pro.
Not stated much is Geforce3 series, What's the oldest version of drivers can we go with this?
Cheers,
Great Northern aka Canada.
Reply 22 of 54, by The Serpent Rider
GeForce 2 Ultra is certainly difficult to find, but GeForce 2 Ti with 4ns memory isn't. Although some 5ns memory also can handle 460Mhz just fine.
Reply 23 of 54, by Confused UngaBunga
Ok. Case scenario.
You want to run games on windows 98 from say motoracer, up to max payne, red faction, mafia, maybe even half-life 2, and you are looking at a geforce 2 gts 32MB from 2000, on the other hand there is an asus branded geforce 4 MX460 passively cooled from 2003.
You already have a voodoo2 on your pentium 4 machine.
However the geforce4 ti4200 64MB 128bit from creative is being dismisse of all the other cards.
What would you do?
Edit: this is all hypothetical.
Reply 24 of 54, by bartonxp
I'd go for a Geforce 3, same price with better performance and about the same compatibility for the games you listed.
Reply 25 of 54, by Confused UngaBunga
So, none of the cards I've mentioned?
No gts, no mx, no ti?
Reply 26 of 54, by bartonxp
For high resolution gaming and the best possible experience.
1. Ti
2. GTS
3. MX
Obviously, but GF3 is a bit more desirable to all these. Not a Ti 200 either, an orig. GF3 or Ti 500. IMHO.
Reply 27 of 54, by Confused UngaBunga
I like playing at 800x600 or 1024x768 on a 17" crt.
More concerned with compatibility with majority of games and the role of drivers and directx on these specific cards.
Sure I could use the ti4200 and have dx8 on hl2, but then I would have to use later drivers 43, not as compatible as earlier ones.
Reply 28 of 54, by Joseph_Joestar
Confused UngaBunga wrote on 2023-06-28, 18:40:
That's only true for AGP 8x versions of GeForce 4 cards.
The AGP 4x versions can use older drivers such 30.82. Those drivers are highly compatible even with the problematic games from the Need for Speed series.
My retro builds
Reply 29 of 54, by The Serpent Rider
4200 8x can use 31.40. But with some dlls swapping, you can use 28.32.
Reply 30 of 54, by Joseph_Joestar
The Serpent Rider wrote on 2023-06-28, 19:02:
4200 8x can use 30.82.
It's been a while since I tested this, so I could be wrong, but I think it could only use 30.82 under Win2K/XP.
Unless I'm misremembering, this didn't work under Win9x, and the card needed 40.72. Might have been the MX440 8x though, not entirely sure.
My retro builds
Reply 31 of 54, by The Serpent Rider
Here's my screenshot with 31.40 and some DLLs swapped from 28.32: Re: Best Drivers for GeForce4 MX-440
Potentially, DLLs can be downgraded further.
Reply 32 of 54, by Joseph_Joestar
The Serpent Rider wrote on 2023-06-28, 19:07:
That's pretty impressive! I wonder if that would be as compatible with NFS4 as 30.82.
Just to clarify, in my previous post, I was referring to official (non-beta) Nvidia drivers without any modifications. It's cool that these types of mods are possible though.
My retro builds
Reply 33 of 54, by Confused UngaBunga
Took the cooler of the hypothetical ti4200. It's a 8x.
Reply 34 of 54, by Confused UngaBunga
Can't I just use the voodoo2 for games that don't like the ti4200? Or I should keep the voodoo2 but together with a gts?
Reply 35 of 54, by Gmlb256
You can use the Voodoo2 card for D3D games that has rendering issues on GeForce cards (like Incoming) and Glide support without wrappers.
Reply 36 of 54, by Confused UngaBunga
Man, I wish I didn't have so many options.
Edit: sometimes I just want to buy a random retro PC without knowing the specs.
That's the closest one can get to that feeling you didn't have to worry because you were pretty much stuck with what you got. And that's what you used. Period.
Reply 38 of 54, by Confused UngaBunga
Got you. The only option I don't have is to have that amount of systems. Because space.
There is only space one system. Maybe 2 max. My interest is restricted to dos 1987-1995 and windows 1995-2001. But even so! And that is driving me crazy.
Gonna take a look at your builds.
I don't have as many.
Reply 39 of 54, by RetroAddict
The Serpent Rider wrote on 2023-06-28, 16:25:
I was given one of these yesterday, didn't realise they were so thin on the ground now - worth keeping? 😀
