First post, by DOS Retro
Hi People,
I Have a Soyo TS-C-4 mainboard, currently running a Pentium 233 MMX
Because i already have a couple of Socket 7 systems running on Pentium CPU's and 1 Cyrix, i was thinking about changing this system to an AMK K6 233.
I did some google searches, but i can not find any information about this mainboard.
Does anyone know where to find this board with the jumper settings?
The attachment 2.jpg is no longer available
The attachment 1.jpg is no longer available
Reply 1 of 5, by ediflorianUS
better photos may identify the board better , I only found 5TS2. there is also SY-5TS5 / SY-5TF / SY-5TH
You can check my 486 links there may help...
it seems to be a 5TS/TF after the print-screen SN/ Award bios code :5TS/TF
My 80486-S i66 Project
Reply 2 of 5, by PcBytes
It's a 5TS2, someone posted it here before:
Help ID a Soyo HX board please
Reply 3 of 5, by ediflorianUS
here is a cpu support list , i think you need 3.5v for AMD.
Reply 4 of 5, by DOS Retro
The BIOS Post says its a TS-C-4....
But a quick look at that topic say itś the same board.... i only see one difference, and thats the extra heatsink under the CPU at my mainboard
Is it still right or...?
Im little confused now
Reply 5 of 5, by DOS Retro
I did the magic trick.
I put in the AMD and turned it on. It just found the CPU.
It started Windows ME, and there I checked Sandra and Aida if the voltages were correct.
VCore 3.2volt, I/O 3.3volt
Just as noted on the CPU itself.
It seems like everything is doing well.
Thanks all for the help!
