Optical mouse near a CRT
First post, by eyalk4568
I know it might be a stupid question but I still wanted to ask it here.
Can you use an optical mouse with a CRT, or can it cause some magnetic interference?
Reply 1 of 9, by weedeewee
You normally use an optical mouse with a table or a mouse pad, just like you would with a normal mouse.
Using it with a crt might work, I never tried it. Could be a bit awkward though, since most crts have a slightly curved surface.
The magnetic interference won't be a problem. the degaus coils might cause enough voltage spikes to be harmful but that would only be when the monitor is turned on or the degaus button is pressed, or the degaus circuitry is misbehaving and firing randomly.
Do not ask Why !
Reply 2 of 9, by eyalk4568
weedeewee wrote on 2023-07-11, 16:28:
🤣 I didn't mean on it I meant near it.
Reply 3 of 9, by Doornkaat
No problems using optical mice near CRTs whatsoever.
Historically there's been a significant overlap where lots of people used optical mice next to CRTs daily.😎
Reply 4 of 9, by keropi
you won't have an issue at all, being using crts+optical mice for decades at this point
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 5 of 9, by HanSolo
It's an optical mouse, not a magnetical one 😀
Reply 7 of 9, by weedeewee
eyalk4568 wrote on 2023-07-11, 17:44:
Well, duuh. 😎
rasz_pl wrote on 2023-07-11, 19:28:
but how do magnets work?
They don't. They just sit there being all attractive and cute.
Do not ask Why !
Reply 8 of 9, by dormcat
My very first mouse bought in 1991 was an Artec serial optical mouse and required a reflective grid underneath; it is still working and stored in my parents' house. My first LCD monitor came in more than a decade later.
I'm more curious about the reasonings behind your thought on optical mouse causing magnetic interference.
Reply 9 of 9, by Horun
THanks all ! I needed a good laugh 😁
