First post, by Babasha
Arrived without anything.
Made it DIY paddle-board for ISA slot, burn last firmware 2.09, install 4x SIMM’s, check and install.
Create every RAID, JBOD configuration supported by this controller with Seagate Medalist's 2.1Gb
IMG_2530.1640017820.jpgIMG_1612.1640017900.jpgIMG_1460.1640017931.jpgIMG_1521.1640017959.jpgIMG_1478.1640017986.jpgIMG_1515.1640018011.jpg
Need help? Begin with photo and model of your hardware 😉
Reply 1 of 14, by Horun
Wow good job ! 🤣 it has the same processor as my 286 😀
Reply 2 of 14, by Babasha
Babasha wrote on 2021-12-20, 16:34:
Arrived without anything. […]
Just to remember - these controllers were produced in the first half and until the mid-90s, they are relevant (reveal themselves) on computers and disks of THAT time. No, don't expect a miracle if you have a Super Socket-7 / Slot-1 machine and a newer hard drive(s) than mid-late 1996. There is no need to chase the fastest IDE hard drives or solid-state drives by hanging them on such a controller (the whole point of these cards was to eliminate the weak points of the relatively slow IDE hard drives of THAT time).
Optimal configuration for PCI-variant Tekram DC-6X0C (D) - processor from 486DX2 to Pentium-1 133MHz, motherboard WITHOUT plug & play and highly desirable WITHOUT integrated IDE controller!
At the BIOS level, it is optimal for the motherboard to allow manually assigning interrupts and resources for each of the PCI slots (such were encountered in 1994-1995). Nevertheless, this controller can be "started" on less rare motherboards with plug & play, but the system will allocate resources at its discretion. Since PCI controllers Tekram DC-6X0C (D) are not quite plug & play (according to the authors themselves), it is fraught with possible conflicts with other PCI plug & play cards and devices in your computer. My advice is to minimize the number of boards, especially those that are "greedy" to the number of interrupts they use (such as USB/Firewire "two in one" multicontrollers that can select 3-4 interrupts for themselves and are guaranteed to capture 14 and or 15 interrupts, which will conflict with Tekram. If you have such an option and the board supports it, use an additional paddle-board (micro-board on a loop that is inserted into the "short" part of the ISA-16 connector) to correctly capture IRQ 14 and 15 interrupts for needs controller.
The controllers support the following RAID modes in hardware: "mirroring" RAID-1 and some analogue of JBOD (when the capacity of two hard disks is summed up into one logical disk). JBOD mode works only with pairs of disks on one of the IDE channels (Primary Master + Primary Slave or Secondary Master + Secondary Slave) of the controller. Mirroring works only with pairs of disks on different IDE channels. I did not find a drop in performance when using these modes.
Currently, the controller is used with 4MB of RAM and Seagate Medalist 2.1Gb hard drives in JBOD or "mirror" modes + single laptop Seagate 810Mb HDD. Configuration and testing were carried out under DOS (SS​​T 4.78, Hddspeed, AMIDiag) and partially under Windows 98 in ATTO Disk Bench 32. The hardest part is to interpret the test results. Apparently, these tests are strictly tailored for traditional controllers with hard drives and show incorrect results in some cases or do not carry out some of the tests at all. Everywhere in the tests, the performance of Cache Read Speed ​​is steadily growing from 5.8 - 6 Mb/s to 12 -12.4 Mb/s, and increase in Linear Write Speed ​​from 3.2 - 5.1 Mb/s to 5.7 - 6.1 Mb/s. Phenomenal drop in Liner Read Speed ​​from 3.6 - 5.3Mb / s up to 1.0 - 1.9Mb.
Personal conclusions.
Disk operations, during real work, do not feel as badly sagging performance and introduce lags as when using an integrated controller on the motherboard. It's nice to get a up to 16MB hardware Smartdrive that works both for reading and writing and does not consume the main RAM and processor. Hardware RAID-1 and JBOD - I don't even know what to compare with? I just don’t remember software products for DOS / Win9x with similar functionality, and if there were, the price for them is interesting and how many resources of the central processor of the P1-133MHz level did they “eat”? Plus, the controller itself has a internal cloning function - a kind of Norton Ghost or Partition Magic in cloning mode when setting up a numbers of computers (created an image of a working system and copy it onto a bunch of disks).
Yes, in the BIOS of the controller, you can change the minimum size of the cached block from 512 bytes (sector) to 8Kb (and this is already a file system cluster), which gives a performance increase on file systems, depending on the cluster size, up to 10-15% compared to the value for default.
Tests
The screenshots below show absolutely identical computer configuration (CPU INTEL P1-233, MB - VIA VP2, RAM - 48MB, VIDEO - S3 TRIO 3D 8MB PCI)
In the first case, testing was carried out with an integrated motherboard controller with max. parameters related to IDE
In the second case, testing was carried out with the PCI IDE CACHE controller TEKRAM DC-690CD with default settings (theoretically, you can still change the size of the cached block from 512 bytes to 8Kb, which gives a performance increase of up to 10-15% depending on the type of file system ).
And then the results of real-use performance: installation of Windows NT 4.0 on a Seagate ST32122A 2.1GB hard drive (installed on a FAT-16 partition with automatic conversion to NTFS
7 min 15 sec (on the integrated motherboard controller)
6 min 04 sec (on TEKRAM DC-690CD).
Reply 3 of 14, by OMORES
Can you test this card on a newer system? I believe that Tekram DC-690CD has proper NT 3.x drivers. I'm curios if it works in a configuration where PCI slots are using a PCI-E to PCI bridge.
I'm looking for a PCI - IDE card with NT 3.1 drivers.
What If a Modern GPU Had 1990s Bandwidth?
Reply 4 of 14, by Babasha
OMORES wrote on 2022-05-12, 15:07:
Sorry, I don’t have any PC newer than P1-200MHz.
Reply 5 of 14, by Babasha
One more. Tekram DC-6X0 is specific card and oriented on VERY early PCI realization, poorly compatible with anything higher than late 486/ early P1 motherboard and req’s ISA slot for paddle-board. So its bad idea to try it with modern (late 1996/7) motherboards.
Reply 6 of 14, by OMORES
Babasha wrote on 2022-05-12, 19:14:
Good to know, not on my list anymore.
Anyways, there must be some PCI - IDE adapter (around 1995-1996) - which is supported in NT 3.x but also works with NT 4 and 2000/XP.
Reply 7 of 14, by ltning
Sorry for bringing up again this old thread.
I'm trying to get one of these running, but it insta-reboots my 486 after it has counted RAM and told me "drive configuration changed".
It also will not get past POST (except if I let it time out) if any disks are configured in the system BIOS (with other caching controllers I usually set type 1 there).
I am on firmware 2.08; I can only find 2.06 out there - could you share 2.09? :)
I don't have a paddle board, but the system BIOS lets me indicate which PCI slot has an IDE controller, and assigns IRQ accordingly - so I assume that should be sufficient?
The Floppy Museum - on a floppy, on a 286: http://floppy.museum
286-24/4MB/ET4kW32/GUS+SBPro2
386DX-40/20MB/CL5434 ISA/GUSExtreme
486BL-100/32MB/ET4kW32p VLB/GUSPnP/AWELegacy
~ love over gold ~
Reply 8 of 14, by mkarcher
ltning wrote on 2023-07-15, 17:38:
If you indicate a PCI IDE controller in a slot, it is likely that the BIOS assigns IRQ14 to the PCI interrupt line that is connected to the INTA pin of that PCI slot. This should be sufficient, if the DC-690CD drives the IDE interrupt to the INTA pin. On the other hand, if the IDE interrupt is only driven to the paddle board, you won't get any interrupts without that paddle board.
Reply 9 of 14, by Zerthimon
I'm looking for the latest bios of DC-690C controller (the one without CD support). If somebody has it and would upload it somewhere, i'd be very grateful.
Reply 10 of 14, by mkarcher
You can get 2.06 both for the CD and the non-CD version at http://files.mpoli.fi/hardware/HDD/TEKMAR/ (BDC690CR.ZIP and DC69CDR.ZIP). If you are still at an older version, this might help. I don't know where to find the 2.o8 or 2.09, and I also don't know whether they exist for the non-CD version at all.
Reply 11 of 14, by ltning
If the VLB versions are any indication, the C and CD versions use the same BIOS.
~ love over gold ~
Reply 12 of 14, by Zerthimon
mkarcher wrote on 2023-07-16, 11:08:
Thanks for the link! I already have these versions. I'm looking for the latest version 2.09 (?) if it exists at all.
Reply 13 of 14, by sonicx
Hi, I have firmware version 2.09 and 2.10 for DC690CD.
Reply 14 of 14, by Zerthimon
sonicx wrote on 2023-07-17, 03:34:
Hi! Thank you for this!
I'l try them on DC-690C when I have time.
