First post, by derpmochump
it's an older socket 462 board with universal agp slot, no ISA slots. got a 850mhz duron in it.
both hard drives inside were broken.
I plugged in a hard drive and installed win98se and used hardware info and it tells me:
sis 7305 + 85C503/5513/961 motherboard
onboard graphics: SiS300
network card: SiS900 Fast Ethernet 10/100 LAN
where do I got to get win98SE drivers for this?
I have no idea. 🤣
MSI MS-6734 KM3M mobo / Athlon XP 3000+ /512mb ddr1 ram
Voodoo 3 3000 PCI @185mhz / Aureal vortex 2 (dell oem)
3dfx ref. drivers win98se and dual boot with winXP-32 bit running amigasport 3.0 3dfx drivers oc'd with koolsmokey's V.Control in XP
Reply 1 of 21, by kixs
Open the case and see what motherboard is installed - the model should be written somewhere on it. Then you go driver hunting.
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 2 of 21, by derpmochump
kixs wrote on 2023-07-16, 11:45:
oh it doesn't have it's OEM i did look.
Reply 3 of 21, by Horun
Are you sure it isn't a SIS 735 chipset like the ECS K7S5A ? Is the SIS300 video onboard or a AGP card ?
I have the old w95/98/2k drivers CD from my ECS ... posted here: https://archive.org/details/ecs-k-7-s-5-a-cd-6-2-s-driver-cd (note: you cannot browse content for some reason)
it has the SIS735 chipset and SIS900 LAN drivers and SIS530/620/630/730 vid drivers plus a bunch of others.....
For the SIS300 you probably need this: https://us.driverscollection.com/?file_id=14164
Reply 4 of 21, by derpmochump
Horun wrote on 2023-07-16, 16:57:
Are you sure it isn't a SIS 735 chipset like the ECS K7S5A ? Is the SIS300 video onboard or a AGP card ? I have the old w95/98/ […]
hold on i'll make pics for you
Reply 5 of 21, by derpmochump
no model number on board, also there is a modem in the top slot thingy dunno what that is either.
Reply 6 of 21, by derpmochump
oh yeah and graphics are onboard but also has universal agp slot
Reply 7 of 21, by kixs
You have probably noticed... there are at least 8 bad caps. This will make the board unstable.
You can also try some sys info program to identify the motherboard - AIDA32 for Windows or AIDA16, NSSI for DOS.
Reply 8 of 21, by derpmochump
kixs wrote on 2023-07-16, 17:51:
yeah i noticed the leaky caps, it still works though, i did use hwinfo already.
Reply 9 of 21, by Horun
Yeah Win98 is not that good at detecting proper, there is no SIS7305 chipset AFAIK but there is a 730, 733 and 735. The Hardware ID's would help a lot....
It look like a PCchips M810LMR v3 or close like this (some had full dip bios other had plcc), it has the SIS730 chipset:
https://theretroweb.com/motherboards/s/pcchip … r-3-0#downloads
Reply 10 of 21, by Ydee
derpmochump wrote on 2023-07-16, 11:35:
I think, it is not 7305, but 730s chipset - single chip solution from SiS. Drivers you can obtain here: http://w3.sis.com/download/
Member Horun was faster:)
Reply 11 of 21, by derpmochump
Horun wrote on 2023-07-16, 18:12:
HWiNFO32 v7.26-4800
Creation Time 14.09.2001 00:07
Content:
CPU
Motherboard
Memory
Bus
Video
Monitor
Drives
Audio
Network
Ports
DURON98
[Current Computer]
Computer Name: DURON98
[Operating System]
Operating System: Microsoft Windows 98SE
UEFI Boot: Not Present
Secure Boot: Not Capable
Hypervisor-protected Code Integrity (HVCI): Disabled
Central Processor(s)
[CPU Unit Count]
Number Of Processor Packages (Physical): 1
Number Of Processor Cores: 1
Number Of Logical Processors: 1
AMD Duron-846
[General Information]
Processor Name: AMD Duron-846
Current Processor Frequency: 846.3 MHz
Current Processor Frequency [MHz]: 846
CPU ID: 00000631
Extended CPU ID: 00000731
CPU Brand Name: AMD Duron(tm) Processor
CPU Vendor: AuthenticAMD
CPU Stepping: A2
CPU Code Name: Spitfire
CPU Technology: 180 nm
CPU Platform: Socket A (462)
Number of CPU Cores: 1
Number of Logical CPUs: 1
[Operating Points]
CPU Current: 846.3 MHz = 8.50 x 99.6 MHz
CPU Bus Type: FSB (DDR)
[Cache and TLB]
L1 Cache: Instruction: 64 KBytes, Data: 64 KBytes
L2 Cache: Integrated: 64 KBytes
Instruction TLB: Fully associative, 16 entries
Data TLB: Fully associative, 24 entries
[Standard Feature Flags]
FPU on Chip Present
Enhanced Virtual-86 Mode Present
I/O Breakpoints Present
Page Size Extensions Present
Time Stamp Counter Present
Pentium-style Model Specific Registers Present
Physical Address Extension Present
Machine Check Exception Present
CMPXCHG8B Instruction Present
APIC On Chip / PGE (AMD) Not Present
Fast System Call Present
Memory Type Range Registers Present
Page Global Feature Present
Machine Check Architecture Present
CMOV Instruction Present
Page Attribute Table Present
36-bit Page Size Extensions Present
Processor Number Not Present
CLFLUSH Instruction Not Present
Debug Trace and EMON Store Not Present
Internal ACPI Support Not Present
MMX Technology Present
Fast FP Save/Restore (IA MMX-2) Present
Streaming SIMD Extensions Not Present
Streaming SIMD Extensions 2 Not Present
Self-Snoop Not Present
Multi-Threading Capable Not Present
Automatic Clock Control Not Present
IA-64 Processor Not Present
Signal Break on FERR Not Present
Streaming SIMD Extensions 3 Not Present
PCLMULQDQ Instruction Support Not Present
MONITOR/MWAIT Support Not Present
Supplemental Streaming SIMD Extensions 3 Not Present
FMA Extension Not Present
CMPXCHG16B Support Not Present
Streaming SIMD Extensions 4.1 Not Present
Streaming SIMD Extensions 4.2 Not Present
x2APIC Not Present
POPCNT Instruction Not Present
AES Cryptography Support Not Present
XSAVE/XRSTOR/XSETBV/XGETBV Instructions Not Present
XGETBV/XSETBV OS Enabled Not Present
AVX Support Not Present
Half-Precision Convert (CVT16) Not Present
[Extended Feature Flags]
FPU on Chip Present
AMD-style Model Specific Registers Present
APIC On Chip Not Present
SYSCALL and SYSRET Instructions Present
Multi-Processing / Brand feature Not Present
No Execute Not Present
MMX+ Extensions Present
Fast FP Save/Restore Present
Fast FP Save/Restore Optimizations Not Present
1 GB large page support Not Present
RDTSCP Instruction Not Present
x86-64 Long Mode Not Present
3DNow! Technology Extensions Present
3DNow! Technology Present
LAHF/SAHF Long Mode Support Not Present
Core Multi-Processing Legacy Mode Not Present
Secure Virtual Machine Not Present
Extended APIC Register Space Not Present
LOCK MOV CR0 Support Not Present
Advanced Bit Manipulation Not Present
SSE4A Support Not Present
Misaligned SSE Mode Not Present
PREFETCH(W) Support Not Present
OS Visible Work-around Support Not Present
Instruction Based Sampling Not Present
XOP Instruction Support Not Present
SKINIT, STGI, and DEV Support Not Present
Watchdog Timer Support Not Present
TBM0 Instruction Support Not Present
Lightweight Profiling Support Not Present
FMA4 Instruction Support Not Present
Translation Cache Extension Not Present
NodeId Support Not Present
Trailing Bit Manipulation Not Present
Topology Extensions Not Present
Core Performance Counter Extensions Not Present
NB Performance Counter Extensions Not Present
Streaming Performance Monitor Architecture Not Present
Data Breakpoint Extension Not Present
Performance Time-Stamp Counter Not Present
L2I Performance Counter Extensions Not Present
MWAITX/MONITORX Support Not Present
Secure Memory Encryption Not Present
Secure Encrypted Virtualization Not Present
[Enhanced Features]
Core Performance Boost Not Supported
[Memory Ranges]
Maximum Physical Address Size: 36-bit (64 GBytes)
Maximum Virtual Address Size: 32-bit (4 GBytes)
[MTRRs]
Motherboard
[Computer]
Computer Brand Name: Unknown or Noname
[Motherboard]
Motherboard Model:
Motherboard Chipset: SiS 730S + 85C503/5513/961
Motherboard Slots: 3xPCI, 1xAGP v2.0
USB Version Supported: v1.0
[BIOS]
BIOS Manufacturer: American Megatrends
BIOS Date: 07/15/97
BIOS Version: 062710
UEFI BIOS: Not Capable
Super-IO/LPC Chip: ITE IT8705/SiS950
Trusted Platform Module (TPM) Chip: Not Found
SMBIOS DMI
BIOS
BIOS Vendor: American Megatrends Inc.
BIOS Release Date: 07/15/97
BIOS Start Segment: F000
BIOS Size: F000
ISA Support: Present
MCA Support: Not Present
EISA Support: Not Present
PCI Support: Present
PC Card (PCMCIA) Support: Not Present
Plug-and-Play Support: Present
APM Support: Present
Flash BIOS: Present
BIOS Shadow: Present
VL-VESA Support: Not Present
ESCD Support: Present
Boot from CD: Present
Selectable Boot: Present
BIOS ROM Socketed: Present
Boot from PC Card: Not Present
EDD Support: Present
NEC PC-98 Support: Not Present
ACPI Support: Present
USB Legacy Support: Present
AGP Support: Present
I2O Boot Support: Not Present
LS-120 Boot Support: Present
ATAPI ZIP Drive Boot Support: Present
IEE1394 Boot Support: Not Present
Smart Battery Support: Not Present
BIOS Boot Specification Support: Present
Function key-initiated Network Service Boot Support: Not Present
Targeted Content Distribution Support: Not Present
UEFI Specification Support: Not Present
Virtual Machine: Not Present
System
System Manufacturer:
Product Name:
Product Version: 1234567890
Product Serial Number:
Mainboard
Mainboard Manufacturer:
Mainboard Name:
Mainboard Version:
Mainboard Serial Number:
System Enclosure
Manufacturer: Uknown Chassis Manufacture
Case Type: Desktop
Version: Version 1.00
Serial Number: 1234567890
Asset Tag Number: 0123ABC
Processor
Processor Manufacturer: AMD
Processor Version:
External Clock: 66 MHz
Maximum Clock Supported: 1200 MHz
Current Clock: 850 MHz
CPU Socket: Populated
CPU Status: Enabled
Processor Type: Central Processor
Processor Voltage: 3.3 V, 2.9 V
Processor Upgrade: LIF
Socket Designation: Sockey-A
Internal Cache
Socket Designation: Internal Cache
Cache State: Enabled
Cache Location: Internal
Cache Type: L1 Unified
Cache Scheme: Write-Back
Supported SRAM Type: Synchronous
Current SRAM Type: Synchronous
Cache Speed: Unknown
Error Correction Type: None
Maximum Cache Size: 1024 KBytes
Installed Cache Size: None
Cache Associativity: 4-way Set-Associative
Internal Cache
Cache Type: L2 Unified
Error Correction Type: Single-bit ECC
Installed Cache Size: Single-bit ECC
OEM Strings
SMBIOS Support from AMI
Tested by James
System Configuration Options
System Management BIOS from Atlanta
SMBIOS from AMI
BIOS Language
English
Traditional Chinese
Simplified Chinese
Japanese
System Event Log
Unknown
Memory Devices
Memory Controller
Error Detecting Method: 32-bit ECC
Error Correction: Single-Bit
Supported Interleave: 1-Way
Current Interleave: 1-Way
Max. Memory Module Size: 128 MBytes
Supported Memory Speed: 70 ns, 60 ns
Supported Memory Type: SPM, FPM, EDO, Parity, ECC, SIMM
Supported Memory Voltage: 3.3 V
Associated Memory Slots: 4
ROW-0
Socket Designation: ROW-0
Memory Type: DIMM, SDRAM
Memory Speed: Unknown
Installed size: 128 MBytes
Enabled size: 128 MBytes
ROW-1
Socket Designation: ROW-1
ROW-2
Socket Designation: ROW-2
Memory Type:
Installed size: Not installed
Enabled size: Not installed
ROW-3
Socket Designation: ROW-3
Memory Type:
Port Connectors
SSA SCSI
Port Type: SSA SCSI
Internal Reference: USB
Internal Connector Type: Mini Centronics
External Reference: Def
External Connector Type: DB25 pin male
System Slots
PCI1
Slot Designation: PCI1
Slot Type: PCI
Slot Usage: In use
Slot Data Bus Width: 32-bit
Slot Length: Long
PCI2
Slot Designation: PCI2
Slot Type: PCI
Slot Usage: Empty
Slot Length: Long
PCI3
Slot Designation: PCI3
Slot Type: PCI
Slot Usage: Unknown
Slot Length: Long
Memory
Total Memory Size: 256 MBytes
Total Memory Size [MB]: 256
[Current Performance Settings]
Current Timing (tCAS-tRCD-tRP-tRAS): 3-3-3-6
Memory Channels Active: 1
Row: 0 - 128 MB SDRAM
[General Row Information]
Row Number: 0
Row Size: 128 MBytes
Memory Type: SDRAM
Error Check/Correction: None
Row: 1 - 128 MB SDRAM
Row Number: 1
Memory Type: SDRAM
Row: 2 - <Empty>
Row Number: 2
Row Size: <Empty>
Bus
PCI Bus #0
SiS 730S Chipset - Host-to-PCI Bridge [A2]
Device Name: SiS 730S Chipset - Host-to-PCI Bridge [A2]
Original Device Name: SiS 730S Chipset - Host-to-PCI Bridge [A2]
Device Class: Host-to-PCI Bridge
Revision ID: 2
PCI Address (Bus:Device:Function) Number: 0:0:0
PCI Latency Timer: 32
Hardware ID: PCI\VEN_1039&DEV_0730&SUBSYS_00000000&REV_02
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
Memory Base Address 0 D0000000
[Features]
Bus Mastering: Enabled
Running At 66 MHz: Not Capable
Fast Back-to-Back Transactions: Not Capable
[DRAM Misc. Control 1]
Refresh Queue Depth: 12
DRAM Refresh Period: 15.6 us
Starting Point Control for Ahead Refresh: 10T
Ahead Refresh Function: Enabled
DRAM Refresh Test Mode: Disabled
Refresh Cycle: Enabled
[DRAM Misc. Control 2]
CPU-to-DRAM Synchronous Mode: Asynchronous
CPU-to-DRAM Synchronous Mode: Synchronous
SDRAM Write Retire Rate: X-1-1-1
Foreground Queue Depth: 3
AGP Command Queue Depth: 2-level
[DRAM Misc. Control 3]
Memory Command Output Timing: Delay 1T
Lead-off Time Control for DRAM Background Command: Delay 1T
Lead-off Time Control for DRAM Read/Write Cycles: Delay 1T
One Page Control: Normal
Foreground and Background Command Out-of-Order Control: Out-of-Order
Read/Write Combine Function Control: Enabled
[DRAM Timing Control 1]
SDRAM RAS Active Time (tRAS): 6 T
SDRAM RAS# Precharge Time (tRP): 3 T
SDRAM RAS-to-CAS Delay (tRCD): 3 T
SDRAM Refresh Cycle Time (tRC): tRC=TraS+tRP
DRAM Refresh Command to Different Rank Control: Simultaneous
[DRAM Timing Control 2]
Write Recovery Time (tWR): 1 T
SDRAM ACT to ACT Delay (tRRD): 2 T
MDOE# Control: Enabled
[SDRAM Initialization Control]
Precharge Command: Disabled
Mode Register Set Command: Disabled
Refresh Command: Disabled
NOP Command Control: Normal
SDRAM CAS# Latency (CL) Setting: 3 T
[Memory Buffer Pre-Driver Slew Rating]
CKE Pre-driver Slew Rating: Slow
CSB[5:0]# Pre-driver Slew Rating: Slow
CSA[5:0]# Pre-driver Slew Rating: Slow
DQM[7:0] Pre-driver Slew Rating: Slow
MD[63:0] Pre-driver Slew Rating: Slow
SRAS#/SCAS#/WE#/MA[14:0] Pre-driver Slew Rating: Slow
[Memory Buffer Strength and Current Rating]
CKE Driving Rating: Middle
CSB[5:0]# Driving Rating: Middle
CSA[5:0]# Driving Rating: Middle
DQM[7:0] Driving Rating: Middle
MD[63:0] Driving Rating: Weak
SRAS#/SCAS#/WE#/MA[14:0] Driving Rating: Weak
[PCI Buffer Strength and Current Rating]
AD[31:0] Current Rating: Weak
PCI Control Signals Current Rating: Weak
[ACPI I/O Space Base Address]
ACPI I/O Space base Address: 280
A.G.P. Request Enable: Disabled
Base Address Validity: Valid
[DRAM Self-Refresh Control for Power Management]
Self Refresh Command Output Timing Control: Delay 1T
CKE Output: Enabled
CKE Selection: Normal Mode
Early CKE Delay Adjustment: 8 ns
Early CKE Delay 1T Control: Normal
[ACPI State Control 1]
ACPI C3 State Self-Refresh: Disabled
ACPI C2 State Self-Refresh: Disabled
ACPI C1 State Self-Refresh: Disabled
ACPI S3 State Disconnect: Enabled
ACPI S1 State Disconnect: Enabled
ACPI C3 State Disconnect: Disabled
ACPI C2 State Disconnect: Disabled
ACPI C1 State Disconnect: Disabled
[ACPI State Control 2]
ACPI S3 State Self-Refresh: Enabled
ACPI S1 State Self-Refresh: Disabled
[Shadow RAM Read/Write Attribute Control]
Shadow RAM Enable for PCI Master Access: Enabled
Write Accessibility of Shadow Region 0C0000h~0FFFFFh: Enabled
Read Accessibility of Shadow Region 0C0000h~0FFFFFh: Enabled
[PCI-Hole Area Control]
PCI-Hole Area I: Disabled
PCI-Hole Area II: Disabled
[Allocation of PCI-Hole Area I]
Size of PCI-Hole Area I: 64 KB
PCI-Hole Area I Base: 0
[Allocation of PCI-Hole Area II]
Size of PCI-Hole Area II: 64 KB
PCI-Hole Area II Base: 0
[PCI Host Bridge Control]
Tri-State Control of Secondary IDE Channel: Signals Enabled
Tri-State Control of Primary IDE Channel: Signals Enabled
Delay 1T Option for Master Initiated Fast Write: Enabled
Mask Read Error: Mask
Dedicated PCI Bus for IDE: Enabled
Target Discard Timer Test Mode: Disabled
PCI Ordering Mode: Enabled
Memory Burst (CPU-to-AGP Burst): Enabled
Maximum Grant Count of PCI Master before Grant to PMR: 4
Memory Burst (CPU-to-PCI Burst): Enabled
PCI Grant Parking on PCI Master: Parking on PMR
[PCI Discard Timer]
PCI Discard Timer: 65535 PCICLKs
[BIU Control 1]
CPU-to-PCI/GUI Memory Post Write Control: Enabled
SysDC Probe Command Counter: 4
SysDC Read Command Counter: 4
SysDC Write Command Counter: 4
Probe Limit: 3
[BIU Control 2]
Data: D4AA
[SDRCLK/SDWCLK Control]
SDRCLK Control: -1.0ns
SDWCLK Control: +2.0ns
[SDWCLK Control]
SDWCLK Control for MA/SRAS#/SCAS#/RAMW#: +1.5ns
SDWCLK Control for Low DQM[3:0]/MD[31:0]: +5.0ns
[GART Base Address for Re-Mapping]
GART Base Address: 0
[Graphics Window Control]
Graphics Window Size: 64 Mbytes
Graphic Window Base Address Validity: Invalid
GART Base Address Validity: Invalid
[Page Table Cache Control]
GART-Write Invalidate Page Table Cache Control: Detect and invalidate
Page Table Cache: Enabled
[Integrated VGA Control]
VGA Configuration Access: Enabled
Integrated GUI: Enabled
MDA Existence: Not present
[CPU/PCI-GUI Privilege Timer]
Initial Value for GUI High Privilege Timer: 0 Clocks
Initial Value for CPU/PCI High Privilege Timer: 0 Clocks
[Memory Arbitration Control]
CPU/PCI-GUI Privilege Timer Control: CPU/PCI High Privilege
Memory Request Latency Control: Fast
CPU/PCI Memory Access Arbitration Mode: Rotating priority
BIU/PCI Memory Access Pipeline: Disabled
Enhanced 3D Performance: Enabled
Rising AGP Request Priority to Shorten CPU High Request Waiting Time: Enabled
[GUI Grant Timer]
Initial Value of GUI High Requests Timer: 5 Transactions
Initial Value of GUI Low Requests Timer: 4 Transactions
[BIU Serial Initialization Packet (SIP)]
SysDataEvenClkDly (EC): 3.0 clocks
SysDataOddClkDly (OC): 2.5 clocks
SysDataEvenDly (ED): 1.0 clock
SysDataOddDly (OD): 0.5 clocks
SysAddDly (AD): No Delay
SysPushPull (PP): Push/pull output drivers
DECSysComp (DS): Non-Alpha logic
SysDCDelay (DL): 2
SysAddWide (EX): Short
SysAddPage (PM): Page mode
SysAddClkDly (AC): 2.0 clocks
SysResetClkOffset (RO): Bit-time 0
SysDataRecMuxPreload (DM): 3
SysAddRecMuxPreload (AM): 3
BitTimesPerSysClk (BT): 2 transfers/SYSCLK
[BIU Status 1]
SysDC Out Delay: 1 clocks
SysDC In Delay: 7 clocks
[BIU Status 2]
Address FIFO Initialize Count: 3
Data FIFO Initialize Count: 3
WrToRd Delay: 1
RdToWr Delay: 1
[FID-Change Status]
FID Value: 11.0x
Received FID-Change: No (FID value valid)
[S2K I/O Compensation Offset Value]
Fixed-Time Compensation: Disabled
Manual Control Compensation Offset: Disabled
NMOS Compensation Offset: +1
PMOS Compensation Offset: -1
[A.G.P. Status]
Max. AGP Request Queue Depth: 31
AGP Side Band Addressing: Supported
>4GB Address Limit: Not supported
Fast Write Transfer: Not supported
Supported AGP Data Transfer: 1x and 2x
[A.G.P. Command]
AGP Sideband Addressing: Disabled
AGP Status: Disabled
>4GB Address Limit: Disabled
Fast Write Transfer: Disabled
Current AGP Transfer Rate: None
[A.G.P. Compliant Target/Arbiter Control]
Read Buffer Threshold Point for Read GNT: 1 block
Pipeline Option for Read Grant: Fast
A.G.P. Flush Option: Only low-priority write
Pipeline Option for PCI Grant: Fast
A.G.P. Activity Forwarding: Enabled
TRDY# Delay for Data Transfer: Minimum
[A.G.P. Priority Rotation Timer]
Initial Value for APRT Timer: 96 AGP clocks
[Data Priority Rotation Timer]
Initial Value for DPT Timer: 96 AGP clocks
[WBFC & DTC]
Data Transfer Counter: 8
Write Buffer Flush Counter: 8
[PCI66 Discard Timer]
PCI66 Discard Timer: 65535 PCICLKs
[A.G.P. Buffer Driving Strength Control]
Manual Calibration Driving Strength Value: 136
[A.G.P. I/O Buffer Control]
Calibration Out Control: Manual
A.G.P. Buffer Slew Rate Control: Fast
Input Buffer Type Selection: Differential pair
A.G.P. / SiS301 I/O Selection: SiS301
Automatic Calibration: Disabled
Calibration Counter: 5 ms
ST[2:0] Output Control: Tri-state
SiS961 MuTIOL - IDE Controller
Device Name: SiS961 MuTIOL - IDE Controller
Original Device Name: SiS961 MuTIOL - IDE Controller
Device Class: IDE Controller
Revision ID: D0
PCI Address (Bus:Device:Function) Number: 0:0:1
PCI Latency Timer: 128
Hardware ID: PCI\VEN_1039&DEV_5513&SUBSYS_55131039&REV_D0
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
I/O Base Address 4 FF00
[Features]
[IDE Primary Channel/Master Drive Data Recovery Time Control]
Recovery Time: 1 PCICLK
[IDE Primary Channel/Master Drive Data Active Time Control]
Ultra DMA Mode: Enabled
Ultra DMA 33/66 cycle time: 4 CLK
Data Active Time Control: 3 PCICLK
[IDE Primary Channel/Slave Drive Data Recovery Time Control]
Recovery Time: 12 PCICLK
[IDE Primary Channel/Slave Drive Data Active Time Control]
Ultra DMA Mode: Disabled
Ultra DMA 33/66 cycle time: N/A
Data Active Time Control: 8 PCICLK
[IDE Secondary Channel/Master Drive Data Recovery Time Control]
[IDE Secondary Channel/Master Drive Data Active Time Control]
[IDE Secondary Channel/Slave Drive Data Recovery Time Control]
[IDE Secondary Channel/Slave Drive Data Active Time Control]
[IDE Status Register]
Channel 1 Cable Type: 40 pins cable type
Channel 0 Cable Type: 40 pins cable type
PCI Read Request Threshold Setting: If FIFO 50.0% full
PCI Write Request Threshold Setting: If FIFO 25.0% full
[IDE General Control 0]
Burst Mode: Enabled
Test Mode: Enabled
Fast post-write control: Enabled
Secondary Channel Master PIO Mode: Disabled
Primary Channel Master PIO Mode: Disabled
IDE Secondary Channel: Enabled
IDE Primary Channel: Enabled
[IDE General Control 1]
Reset IDE State Machine: Disabled
Secondary Channel Post Write: Disabled
Primary Channel Post Write: Disabled
Secondary Channel Master Prefetch: Disabled
Primary Channel Master Prefetch: Enabled
[Prefetch Counts]
Primary Channel Prefetch Count: 512
Secondary Channel Prefetch Count: 512
SiS 85C503/5513/961 PCI-to-ISA Bridge
Device Name: SiS 85C503/5513/961 PCI-to-ISA Bridge
Original Device Name: SiS 85C503/5513/961 PCI-to-ISA Bridge
Device Class: PCI-to-ISA Bridge
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:1:0
PCI Latency Timer: 0
Hardware ID: PCI\VEN_1039&DEV_0008&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
[BIOS Control Register]
ACPI State: Enabled
PCI Delayed Transaction: Disabled
PCI Posted Write Buffer: Enabled
Positive Decode of Upper 64K BIOS: Disabled
BIOS Subtractive Decode: Disabled
Lower BIOS: Disabled
Extended BIOS (FFF80000-FFFDFFFF): Disabled
[INTA# Remapping Control]
Remapping Control: Enabled
IRQ Remapping: IRQ5
[INTB# Remapping Control]
IRQ Remapping: IRQ11
[INTC# Remapping Control]
IRQ Remapping: IRQ3
[INTD# Remapping Control]
[ISA Bus Control Register I]
ISA Bus Clock Select: 7.159 MHz
Flash EPROM Control 0: Disabled
RTC Extended Bank: Disabled
Flash EPROM Control 1: Disabled
Automatic Power Control Registers: Disabled
[ISA Bus Control Register II]
16-bit I/O Cycle Command Recovery Time: 5 BUSCLKs
8-bit I/O Cycle Command Recovery Time: 3 BUSCLKs
ROM Cycle Wait State Selection: 1 WS
[DMA Clock and Wait State Control Register]
Extended Terminal Count (TC)Hold Time: i8237 compatible
16-bit DMA Cycle Wait State: 3 DMACLKs
8-bit DMA Cycle Wait State: 4 DMACLKs
Extended DMAMEMR# Control: Enabled
DMA Clock: ISA BUSCLK
[ISA Master/DMA Memory Cycle Control 1]
Top Of ISA Memory: 2 MBytes
Forward E0000h-EFFFFh Access To PCI Bus: Disabled
Forward A0000h-BFFFFh Access To PCI Bus: Disabled
Forward 80000h-9FFFFh Access To PCI Bus: Disabled
Forward 00000h-7FFFFh Access To PCI Bus: Disabled
[ISA Master/DMA Memory Cycle Control 2]
Forward DC000h-DFFFFh Access To PCI Bus: Enabled
Forward D8000h-DBFFFh Access To PCI Bus: Enabled
Forward D4000h-D7FFFh Access To PCI Bus: Enabled
Forward D0000h-D3FFFh Access To PCI Bus: Disabled
Forward CC000h-CFFFFh Access To PCI Bus: Enabled
Forward C8000h-CBFFFh Access To PCI Bus: Enabled
Forward C4000h-C7FFFh Access To PCI Bus: Enabled
Forward C0000h-C3FFFh Access To PCI Bus: Enabled
[ISA Memory Hole]
ISA Memory Hole Bottom: 0
ISA Memory Hole Top: 0
[Shadow Registers]
ICW1-ICW4 (INT1) Shadow Register: 1045011
ICW1-ICW4 (INT2) Shadow Register: 1025811
OCW2-OCW3 (INT1) Shadow Register: A60
OCW2-OCW3 (INT2) Shadow Register: B63
CTC Counter 0 Shadow Register: 174D
CTC Counter 1 Shadow Register: 12
Built-in CTC Shadow Register: 0
[MIRQ0 Remapping Control Register]
MIRQ0 Remapping: Enabled
MIRQ0/IRQx Sharing: Enabled
Interrupt Remapping: IRQ9
[MIRQ1 Remapping Control Register]
MIRQ1 Remapping: Disabled
MIRQ1/IRQx Sharing: Enabled
Interrupt Remapping: IRQ0
[On-board Device DMA Control]
MDRQ1/MDACK1# Remapping: Enabled
DMA Channel Remapping of MDRQ1/MDACK1#: Channel 0
MDRQ0/MDACK0# Remapping: Disabled
DMA Channel Remapping of MDRQ0/MDACK0#: Channel 0
[IDEIRQ Remapping Control]
IDEIRQ Remapping: Disabled
[GPIO0 Control]
GPIO0 Mode: Output mode
GPIO0 Input Active Level: Active low
GPIO0 Input Bounce-Free: Enabled
De-bounce Count for GPIO0: 0
SIO To IDE Master Arbiter: Disabled
[GPIO0 Output Mode Control]
GPIO0 I/O Space Base Address: 1000
GPIO0 I/O Space Address Mask: Disabled
[Data Acquisition Module Base Address]
Data Acquisition Module I/O Base Address: 0
[GPIO Status]
Arbiter Operating Mode: Fixed priority
Built-in RTC Status: Not used
GPIO0 Status: Active
SiS900 Fast Ethernet 10/100 LAN Adapter
Device Name: SiS900 Fast Ethernet 10/100 LAN Adapter
Original Device Name: SiS900 Fast Ethernet 10/100 LAN Adapter
Device Class: Ethernet Adapter
Revision ID: 82
PCI Address (Bus:Device:Function) Number: 0:1:1
PCI Latency Timer: 64
Hardware ID: PCI\VEN_1039&DEV_0900&SUBSYS_09001039&REV_82
[System Resources]
Interrupt Line: IRQ3
Interrupt Pin: INTC#
I/O Base Address 0 C400
Memory Base Address 1 CFFF7000
[Features]
Fast Back-to-Back Transactions: Capable
SiS 7001 USB Open Host Controller
Device Name: SiS 7001 USB Open Host Controller
Original Device Name: SiS 7001 USB Open Host Controller
Device Class: USB OHCI Controller
Revision ID: 7
PCI Address (Bus:Device:Function) Number: 0:1:2
Hardware ID: PCI\VEN_1039&DEV_7001&SUBSYS_70011039&REV_07
[System Resources]
Interrupt Line: IRQ11
Interrupt Pin: INTD#
Memory Base Address 0 CFFFC000
[Features]
USB Version Supported: 1.0
Revision ID: 7
PCI Address (Bus:Device:Function) Number: 0:1:3
Hardware ID: PCI\VEN_1039&DEV_7001&SUBSYS_70001039&REV_07
[System Resources]
Memory Base Address 0 CFFFD000
[Features]
SiS 7018 HW Audio Device
Device Name: SiS 7018 HW Audio Device
Original Device Name: SiS 7018 HW Audio Device
Device Class: Multimedia Audio Adapter
Revision ID: 2
PCI Address (Bus:Device:Function) Number: 0:1:4
Hardware ID: PCI\VEN_1039&DEV_7018&SUBSYS_70181039&REV_02
[System Resources]
Interrupt Pin: INTB#
I/O Base Address 0 C800
Memory Base Address 1 CFFFE000
[Features]
SiS 7013 SW Modem
Device Name: SiS 7013 SW Modem
Original Device Name: SiS 7013 SW Modem
Device Class: Modem
Revision ID: A0
PCI Address (Bus:Device:Function) Number: 0:1:6
Hardware ID: PCI\VEN_1039&DEV_7013&SUBSYS_70131039&REV_A0
[System Resources]
I/O Base Address 0 D000
I/O Base Address 1 CC00
[Features]
SiS A.G.P. Controller / 86C201 Video Adapter
Device Name: SiS A.G.P. Controller / 86C201 Video Adapter
Original Device Name: SiS A.G.P. Controller / 86C201 Video Adapter
Device Class: PCI-to-PCI Bridge
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:2:0
Hardware ID: PCI\VEN_1039&DEV_0001&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
AGP 4x Bus (PCI Bus #1)
SiS 300 Integrated Video Adapter
Device Name: SiS 300 Integrated Video Adapter
Original Device Name: SiS 300 Integrated Video Adapter
Device Class: VGA Compatible Adapter
Revision ID: 31
PCI Address (Bus:Device:Function) Number: 1:0:0
Hardware ID: PCI\VEN_1039&DEV_6300&SUBSYS_63001039&REV_31
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
Memory Base Address 0 C0000000
Memory Base Address 1 CFEE0000
I/O Base Address 2 9C00
[Features]
Bus Mastering: Disabled
Running At 66 MHz: Capable
Aureal Semiconductor Vortex 8830 Audio
Device Name: Aureal Semiconductor Vortex 8830 Audio
Original Device Name: Aureal Semiconductor Vortex 8830 Audio
Revision ID: FA
PCI Address (Bus:Device:Function) Number: 0:9:0
Hardware ID: PCI\VEN_12EB&DEV_0002&SUBSYS_BFBFFFFE&REV_FA
[System Resources]
Interrupt Line: IRQ5
Interrupt Pin: INTA#
Memory Base Address 0 CFF40000
I/O Base Address 1 C000
I/O Base Address 2 BC00
[Features]
ISA/VLB Bus
Video Adapter
SiS300
[Video Chipset]
Video Chipset: SiS300
Video Memory: 16384 MBytes of SDRAM
[Video Card]
Video Card: SiS 300 Integrated Video Adapter [SiS]
Video Bus: AGP 4X @ Disabled
Video BIOS Version: 2.00.50
[Performance]
Graphics Processor Clock: 102.6 MHz
Graphics Memory Clock: 100.2 MHz
Resizable BAR (ReBAR) Support: Not Supported
PCI Location (Bus:Dev:Fnc): 1:00:0
Monitor
Drives
Floppy Drives
1.44 MB 3 1/2
(S)ATA/ATAPI Drives
GENERIC NEC FLOPPY DISK
GENERIC IDE DISK TYPE47
PLEXTOR CD-R PX-W1210A
Easy Disk
Audio
Audio Adapter: SiS 7018 HW Audio Device
Audio Controller Hardware ID: PCI\VEN_1039&DEV_7018&SUBSYS_70181039&REV_02
Audio Adapter: Aureal Semiconductor Vortex 8830 Audio
Audio Controller Hardware ID: PCI\VEN_12EB&DEV_0002&SUBSYS_BFBFFFFE&REV_FA
Network
[General information]
Network Card: SiS900 Fast Ethernet 10/100 LAN Adapter
Vendor Description:
MAC Address: Unknown
[Capabilities]
Maximum Link Speed: Unknown
Supported Media: LocalTalk DIX ARCNET (raw) ARCNET (878.2) ATM Wireless WAN IRDA BPC CoWAN IEEE1394 FireWire
Transmit Buffer Size: Unknown
Receive Buffer Size: Unknown
Ports
Serial Ports
COM1
USB
SiS 7001 PCI to USB Open Host Controller
Root Hub
[Port1] : No Device Connected
[Port2] : No Device Connected
[Port3] : No Device Connected
Root Hub
[Port1] : Silicon Motion Memory Bar
[Device Information]
Device Manufacturer: Silicon Motion
Product Name: Silicon Motion Memory Bar
Serial Number:
USB Version Supported: 2.00
USB Device Speed: USB 1.1 Full-speed
Driver Description: USB Mass Storage Device
Hardware ID: USB\VID_090C&PID_1000
DeviceInstanceId USB\VID_090C&PID_1000\AA04012800007466
Reply 12 of 21, by Horun
This: [General Information]
Revision ID: 2
tells us everything we need to know. Many of those other SIS items (SIS PCI-ISA bridge, SiS A.G.P. Controller/Video, SIS USB, SIS IDE) are internal parts of the SIS730 "Single chip solution"
the only items outside of that chip is the sound, lan and AMR modem.....and possibly the ITE IDE interface chip....
Reply 13 of 21, by derpmochump
Ydee wrote on 2023-07-16, 18:28:
thanks when i go to the sis site i don't see chipset driver download i see:
Reply 14 of 21, by derpmochump
Horun wrote on 2023-07-16, 19:00:
This: [General Information] Device Name: SiS 730S Chipset - Host-to-PCI Bridge [A2] Original Device Name: SiS 730S Chipset - Hos […]
Revision ID: 2
I'm installing stuff from the ISO image you linked from the SiS folder atm.
Reply 15 of 21, by derpmochump
Revision ID: 2
does this board have chipset drivers or it doesn't need because they have some weird single chip solution?
Reply 16 of 21, by Horun
The chipset INF drivers are in the AGP drivers....according to the PCchips and Amptron archive you want SIS AGP v1.16 or agp116a.exe not the newer v2.x version
The audio: Hardware ID: PCI\VEN_1039&DEV_7018 comes up as C-Media AC97 Audio Device,
The video: Hardware ID: PCI\VEN_1039&DEV_6300 comes up as SIS630/730. Driver 630_206_s.zip should work for the onboard...
have some of those in my archives, will dig them out
Reply 17 of 21, by derpmochump
Horun wrote on 2023-07-16, 19:24:
The chipset INF drivers are in the AGP drivers....according to the PCchips and Amptron archive you want SIS AGP v1.16 or agp116a […]
thanks, i will try them tomorrow now, getting late here and i am tired!
I will check back tomorrow for your driver links.
Reply 18 of 21, by Horun
SIS AGP chipset v1.16a and SIS 630 206 video driver.
You must use 7zip or Winrar to decompress them, winzip will not !!
added here is the driver list for same m810LMR board but sold by Amptron under the K7-810LM label....
https://web.archive.org/web/20020806064856/ht … p?name=K7-810LM
note the driver names and versions, the actual download mostly do not work....
added: I think all the drivers you need are on that CD in the \SIS folder, the AMR modem driver is in \Peripheral
Reply 19 of 21, by Ydee
derpmochump wrote on 2023-07-16, 19:01:
You need look better, all you need is here, look (you must choose driver and click on GO button):
