First post, by Jo22
- l33t++
Hi everyone!
I'm currently trying to get a "modern" Gotek working in a 286 PC.
As it turns out, it's the Atery model, with half the RAM (32 vs 64KB)..
Does anybody, by any chance, has it working in a 286 or higher PC?
I've already checked the jumpers, drive is correctly on S1 (IBM PC Standard).
Cable is a simple, straight one, without a twist. The PC works fine with a real 1,44MB drive and 1,44 MB floppy.
- Just not with the Gotek/FlashFloppy.
When doing a DIR: on DOS prompt, all files in the image are garbled/corrupted.
Formatting via FORMAT works until you're asked for a LABEL.
Then, DOS will throw an write error. Bypassing the error causes FORMAT to cancel everything (says, Sector 0 is corrupted).
Does anybody know about this issue?
I'm an old Gotek/FlashFloppy user, but haven't been up-to-date since about 2-3 years.
The old Goteks didn't behave that weird, I think. Could the low RAM be the issue?
I've found a quick summary/thread in an Amiga forum that explains the shortcomings of that poor Atery Gotek model (AT32F415 MCU, SFRKC30.AT2 board ?).
https://eab.abime.net/showthread.php?p=1596913
If I understand, merely 8KB of RAM are left for caching floppy i/o on such a weak "COVID-19" model .
This worries me, because on a 286 PC, I'm using HD/high-bandwidth images (1,44MB and 500KBits).
An IBM PC with 360KB images and half the bandwidth may still work with the tiny cache, by contrast, not sure.
Any thoughts or ideas welcome. 🙂
Jo22
PS: I've successful done the speaker mod.
I can hear the floppy seek during POST.
The PC itself does NOT complain about an FDC or floppy error (A: is first boot drive).
Edit: Pictures added.
