First post, by vico
Apparently everything is well configured but I can't hear the MIDI sound (MPU-401), the sounds configured with "Sound Blaster" are heard perfectly, I must also say that this happens both in Windows 98, Windows 98 MS-DOS mode and MS -DOS 6.22.
I don't know if this is due to some incompatibility with my Compaq motherboard or if it's a physical damage to my sound card, I hope you can guide me.
Reply 1 of 4, by weedeewee
If i'm not mistaken the mpu-401 is the actual midi in/out interface that exists on those cards and will never output any sound, except when a suitable midi device is connected using one of those joystick2midi adapters.
Do not ask Why !
Reply 2 of 4, by Gmlb256
And the output from the external MIDI device should be connected to the sound card's line-in port. It has nothing to do with motherboard incompatibility nor any physical damage.
Reply 3 of 4, by weedeewee
Gmlb256 wrote on 2023-07-31, 16:29:
... and the sound card should be connected to speakers or an amplifier to which speakers are connected 😀
Do not ask Why !
Reply 4 of 4, by vico
The thing is that before changing my board, which was a Soyo SY-6BA+ III (which unfortunately got ruined) I could hear the MPU-401 midi sound emulated in games like Wiering Software's Charlie and Charile II and now with this Compaq motherboard I can't .
    915.21 KiB
