Which socket 754 motherboard to pick?
First post, by theiceman085
I am looking for a home for my Geforce 4200 from Gainward. At first, I wanted to get P3 Tualatin but then I get some recommendations in my previous thread
Pentium 3 1 GHz Tualatin or P3 1 GHZ Coppermine for Voodoo 3 200 agp card
to consider and board to get a better performance/price ratio.
After doing some research I found a few socket 754 mainboards for a good price
https://www.ebay.at/itm/325529313460?hash=ite … %3ABFBM0vahjrZi
https://www.ebay.at/itm/274733260081?hash=ite … ABk9SR9L2oY62Yg
https://www.ebay.at/itm/274726052475?hash=ite … ABk9SR9L2oY62Yg
And last but not least a Socket 462 mobo
https://www.ebay.at/itm/285379215815?hash=ite … ABk9SR4zO6Y62Yg
Are all of them equally good or would you recommend one model particularly?
The CPU of choice for that system will be a athlon xp. btw.
Reply 1 of 28, by DerBaum
theiceman085 wrote on 2023-08-01, 11:51:
Look at the capacitors. They exploded.
In my opinion thats not a good price even if the board was still working 😁 (because the caps then will probably have exploded after buying it)
You should concider buying a "recapped" board or prepare your self for a solder session... Around this time a lot of boards have problems with leaking and exploding caps...
Just to make you aware of this cap thing... 😀
FCKGW-RHQQ2
Reply 2 of 28, by rasz_pl
60 euro 🤣. With those caps and missing radiator it was clearly pulled from garbage, its only a good offer if you buy it and request&receive full refund for seller sending you complete broken junk that was listed as "in working condition, might have slight cosmetic damage"
Polish allegro.pl has ~130 754 boards, first search result is 10 euro http://hw-museum.cz/mb/88/asus-k8n in perfect condition
Reply 3 of 28, by shevalier
From my experience.
1. If the radiator and the frame around the socket were removed from the motherboard, the motherboard is definitely and unconditionally dead.
2. Wow, still a live nForce 3....
3. An ordinary office motherboard, if IT8282M did not burn out due to a poor-quality PSU, then it does not bring surprises.
rasz_pl wrote on 2023-08-01, 12:59:
Wow, the second still a live nForce 3.... 😀
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 4 of 28, by Joseph_Joestar
A couple of things to note if you're going after a motherboard with a VIA chipset.
1) If you want to use modern SATA drives in native mode (without adapters) you need the VT8237R Plus southbridge. The "plus" revision fixed a bug where the chipset could not recognize SATA III drives. If you don't care about native SATA, you can always use a SATA to IDE adapter and bypass this issue entirely.
2) Choose a motherboard which has multiple BIOS revisions still available for download. There's a nasty microcode bug which cripples AGP performance under Win9x, and it can only be solved by using older BIOS versions. I think @bloodem explained it quite nicely here. Rule of thumb, BIOS versions from 2004 are generally not affected by this, while later ones might be. There are some exceptions to this though.
3) Make sure that the BIOS version you end up flashing supports the CPU that you want to use. Venice and San Diego Athlon64 cores are the best, but they likely need newer BIOS versions. Such CPUs are usually fairly expensive too. On the other hand, the older NewCastle and ClawHammer cores are less expensive and usually work fine with older BIOS versions, but they dissipate more heat.
It's quite tricky getting a motherboard which fits into all of these categories, but the main thing is to avoid the AGP performance bug. That bug will absolutely destroy your gaming performance under Win9x, regardless of which GPU you end up using.
My retro stuff
Reply 5 of 28, by shevalier
PS. If you look at the pinout nForce 3, then the inner square of balls is the grounding .
For some reason, if you remove nForce3 from a dead motherboard, only Asus will have copper glowing instead of melted solder on part of the ground balls.
Neither ECS, nor EliteGroup, nor Gigabyte. Asus K8 series only.
Reply 6 of 28, by stef80
I'd recommend:
1) Asus KV8 SE Deluxe - classic s754 board based on VIA K8T800
2) Asus K8V-MX - should come with VT8237R Plus southbridge, but do check
Joseph_Joestar wrote on 2023-08-01, 13:15:
I's actually the other way around. Venice 3000 and 3200 should be easily obtainable. ClawHammers (1MB L2) are more rare for s754.
Reply 7 of 28, by shevalier
stef80 wrote on 2023-08-01, 13:30:
Too trite.
AMD Mobile Athlon 64 4000+ (E5) - 2.6GHz + 1MB L2 + SSE3, its cool
AMD Turion 64 MT-40 - 2.2GHz + 1Mb L2 + SSE3, its cool enough
To be honest, Venice 2GHz with SSE3 is enough for almost everything.
https://www.cpu-world.com/CPUs/K8/AMD-A ... XBOX).html
Reply 8 of 28, by stef80
None of them were regular s754 chips. 4000 is DTR and Turion is mobile, both without IHS and sketchy BIOS support for desktop boards.
Reply 9 of 28, by shevalier
stef80 wrote on 2023-08-01, 13:47:
The problem with some series of Intel and AMD processors is that there is TIM under the IHS. And it's completely petrified.
If you want a long life for A64, you need to rip off the IHS and smear it with thermal paste, alas.
Or will it be
Athlon 64 3000+ s754. Incorrect BIOS initialization or broken L2 cache?
Reply 10 of 28, by stef80
That's general problem with s754/s939 and AM2 excluding "CZ" code which were soldered ... I think.
Reply 11 of 28, by shevalier
stef80 wrote on 2023-08-01, 14:04:
And some stepping of P IV from Intel.
PS. And Tualatin, of course.
But there do not care, with a TDP of 30 watts.
Reply 12 of 28, by dionb
Before choosing a board, you should choose a platform and then a chipset.
Here you have boards with SoA nVidia nForce2 chipset but also So754 nVidia nForce3 250, Via K8T800 and Via K8M800.
All will run a Gf4Ti, but beyond that, there are differences in performance and compatibility.
The nForce2/3 chipsets have full support up to Windows XP only (you can get away with XP drivers on 32b Vista, although with limitations, but 64b is a no-no), whereas the Via chipsets have full Vista support, and claim of integration of the driver into Windows 7 and 8.
nForce3 has better AGP performance in games, but K8T800/K8M800 have better SATA throughput.
As for the individual boards...
- the Asus K8V-X SE looks in a bad state, missing chipset heatsink and bad caps. Would not trust at all. This was from a period was Asus was no longer synonymous with quality and it shows.
- Biostar K8NHA-M looks in excellent state (if the pic is of the actual item being sold), and is better value for money.
- ECS Elitegroup K8M800-M2 PCB is bent. ECS is bottom-feeding low-end build quality. Still, it's cheap.
- ABIT NF7 one of the last great Abit boards. Clearly a generation older than the rest - no SATA - and sadly a low-end version of the board with MCP southbridge instead of MCP-T. Still great board, but you really need to want Socket A for this.
Reply 13 of 28, by shevalier
dionb wrote on 2023-08-01, 14:26:
nForce2/3 and Windows Vista has nothing to do. Even on Windows XP with antivirus.
For more other operating systems, there are more other rig`s.
Reply 14 of 28, by shevalier
For s754, I would look for something on VIA from Abit, Epox, DFI or Soltek.
With replaced capacitors, of course.
90 watts is not 30 (like Tualatin), no Japanese capacitors will last 20 years with this power consumption.
PS. I have a Jetway and it has a design flaw in the powering of the HyperTransport.
This is solved by replacing the mosfet, but this is not the way for everyone.
If this is a system problem, then it is in the entire series of motherboards, so I do not advise at all.
Reply 15 of 28, by Joseph_Joestar
I have one of those, and mine did come with the plus version of the southbridge. But as you say, it's best to check beforehand since this might possibly depend on the board revision. The plus version is clearly labeled as such, and should be easy to identify on pictures.
BTW, it should be noted that the K8V-MX does suffer from the AGP performance bug. Thankfully, the issue can be remedied on that board by flashing the oldest available BIOS, which is v0112.
Yeah, it might depend on where one lives. In my neck of the woods, NewCastle is the most common one, while ClawHammer is slightly rarer, though not super hard to come by. On the other hand, the socket 754 versions of Venice and San Diego are almost impossible to find here.
My retro stuff
Reply 16 of 28, by theiceman085
@All Thanks a lot for the tons of information you gave me. It helped a lot 😀.
Before choosing a board, you should choose a platform and then a chipset. […]
- ABIT NF7 one of the last great Abit boards. Clearly a generation older than the rest - no SATA - and sadly a low-end version of the board with MCP southbridge instead of MCP-T. Still a great board, but you need to want Socket A for this.
Yes choosing a platform and chipset first before the board is good advice. I will start my research from there.
Also thanks for rating the individual boards.
Reply 17 of 28, by stef80
shevalier wrote on 2023-08-01, 15:04:
As good as DFI boards were, they had some of the crappiest capacitors on them.
Epox and Abit used SANYO and Rubycons a lot on s754/s939, but not on all of the boards/revisions.
Reply 18 of 28, by theiceman085
stef80 wrote on 2023-08-02, 06:05:
Thanks for the info shevalier and steff80.
Well it really seems that bad caps are recuiring theme in the discusion which means I have 2 options. Either ask a good friend of mine which is good at soldering to help me as soon as I have the mobo or I have to look specifically for recapped boards already which raise the cost a bit but that's not really a big issue.
I do not mind paying extra if means I do not have to worry about bad caps anymore.
Reply 19 of 28, by Joseph_Joestar
theiceman085 wrote on 2023-08-02, 06:41:
From my experience, it helps to know at least basic soldering when you're dealing with retro stuff. I first got into it about 5-6 years ago when I wanted to mod my PAL Sega Mega Drive and make it region-free. But it's very helpful with retro PC hardware as well, since components made during the capacitor plague era have a higher chance to fail.
It does require some financial investment though, especially if you're going for desoldering stations which are extremely helpful for re-capping. A quality multimeter which can measure capacitance also tends to cost a bit more. Also, it takes a bit of practice to get decent at (de)soldering, but there are loads of instructional videos on YouTube. If you're curious about this, I suggest checking out Necroware's channel where he repairs a bunch of retro PC hardware. It's really fun watching him bring broken cards back to life.
My retro stuff
