First post, by rcarkk
Hi guys, i received this board recently and haven´t had any sucess with it with the onboard cache enabled. Tried all sorts of SDRAM modules ranging from single sided and double sided 64MB to 256MB, changing the SRAM options and timmings on bios.
The board seems to freeze when updating ESCD, using any K6-2 or Pentium MMX CPUs. This is with the onboard cache enabled. I can see in the table that 512kb are present like it should, but the co-processor is not installed.
The interesting thing is that if i use a K6-III which has integrated L2 cache, the board doesnt freeze when updating ESCD, the co-processor is present and i can enter MSDOS to do some testing, altough with success in only some programs.
Quake, Doom and some other utilities, give some errors and they simply dont start, returning to dosbench menu. The system manages to run speed sys 4.78 and cachecheck just fine though. Cachecheck says the system has 256kb and 512kb, so it´s indeed using the onboard SRAM and can complete the test with the K6-III. Ultimate boot CD has integrated Memtest 4.10 and when i select it, to start the test, the system reboots automatically.
Any thoughts on this problem? I guess it´s a faulty SRAM chip considering it works fine with it disabled, and i wouldn´t mind having your opinions. Thanks in advance guys.
Baby AT socket7 - Pentium MMX 233MHz + 3Dfx Voodoo
Socket 8 build - Soyo 6FA + Pentium Pro 200MHz + 3Dfx Voodoo 2 12MB
PC Remake - Pentium III 450 + Matrox G400 16MB
The K6-III build
Reply 1 of 6, by Nexxen
Have you checked L2 cache legs for some cracked solder joints?
It's not so uncommon to happen.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 2 of 6, by rcarkk
Nexxen wrote on 2023-08-04, 10:34:
Not yet to be honest. I did only check with a magnifying glass, and legs look fine at naked eye, but i need to check that better...
The K6-III build
Reply 3 of 6, by Sphere478
Some flux and a hot air wand. Re seat it.
But it may be safer to just disable the on motherboard cache if you have a k6-3 the performance difference can be pretty small. Sometimes disabled can actually be faster. Probably not on your motherboard though with 100mhz fsb
Try disabling system bios cachable. See if that does anything..?
Play around with other bios settings as well.
Sphere's PCB projects.
Reply 4 of 6, by rcarkk
Sphere478 wrote on 2023-08-04, 18:12:
Some flux and a hot air wand. Re seat it. […]
It seems from what i read, that the MVP3 likes onboard cache, even with a K6-III/+. Ali V has less performance penalty.
What about BIOS rot? Do you think it´s possible?
The K6-III build
Reply 5 of 6, by Nexxen
rcarkk wrote on 2023-08-05, 13:05:
Absolutely.
I usually reflash the BIOS when trying to troubleshoot.
Is it the cause of your issues? Can't say unless you give it a go. Bios corruption can happen at any level.
Reply 6 of 6, by rcarkk
Nexxen wrote on 2023-08-05, 13:46:
Absolutely. I usually reflash the BIOS when trying to troubleshoot. Is it the cause of your issues? Can't say unless you give it […]
Absolutely.
I guess it´s better to try a bios flash if i see no issues on the SRAM chip legs. First, backup the BIOS and compare it to the same one pulled from the web
The K6-III build
