First post, by whocrazy
Hello there. There's this game I am trying to run, it's called drone, no it does not run from a cd, it is a simple text based game written in q basic.
Anyhow, when I try to run the game, I get this error in the console.
Warning: file d:\drone\CON exists and failed to open in write mode.
Please Remove write-protection.
What gives?
Here are the autoexec.bat lines at the end of dosbox.conf
mount c c:\
mount d d:\
I then cd to drone (cd\d:\drone)
then type drone
I then get this error
path/file access error in line no line number in module drone at address 0f02:0117
Hit any key to return to system.
Ok guys, it's over to you.
Reply 1 of 37, by eL_PuSHeR
Is D a CD drive = non writeable?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 37, by whocrazy
No, d: is not a rewriteable drive, it's a second hard drive.
Reply 3 of 37, by simonecuttlefish
Any chance the folder d:\drone\CON is marked read only? This can happen if you drag folders off a cd onto your hard disk. Right click the \Drone directory in windows and select properties->security and give yourself full control of it and it's sub directories if this is the case.
Also, It could possibly be freaking out if it "thinks" it should be in c:\drone? ... or another location (if it was copied from another installed version and has some local settings pointing to a different location? Does it have a .cfg or .ini file in it you can open with notepad and get some hints from?
Guesses, but worth a fast check.
Reply 4 of 37, by whocrazy
No, that's not it at all. Drone has no cfg file or ini file, it's designed to run from any folder.
The game will run in real dos, but not dosbox.
I could put the game up somewhere for the developers of dosbox to try out themselves, and see if there is anything that can be done to fix it.
The game did not come on a cd.
Reply 5 of 37, by ripsaw8080
Rank DOSBox Author
DOSBox Author
CON is one of the "reserved" names in DOS, in this case for the console device. Like NUL, PRN, LPT1, etc. Since it's a text game written in BASIC, perhaps it is trying to open the console device like a file using its name in an OPEN command. Could be an issue with something like that; and would be easy to see if it IS doing that if you have the BASIC source code.
Reply 6 of 37, by wd
Rank DOSBox Author
DOSBox Author
Think opening devices with a preceding path doesn't work in dosbox,
there are patches on the sf page for that.
Reply 7 of 37, by whocrazy
Hi there.
I'll see if he has the source somewhere, but if he doesn't, bad luck. it's a very old game
.. Anyways, I'm no programming expert, so even if I had the source I wouldn't be able to make sense of it.
Reply 8 of 37, by Qbix
Rank DOSBox Author
DOSBox Author
Well it works to some degree.
if the path is illegal then dosbox will report an error. (so installers can use devices to determine wether a directory exists or not)
However if the path is legal, it appears that I made a small error in the coding as we then compare the full name against the device name instead of only the filename.
Water flows down the stream
Reply 9 of 37, by simonecuttlefish
Put it up somewhere (as you suggested) and put a link to it - sounds like a mini-challenge : )
Reply 10 of 37, by wd
Rank DOSBox Author
DOSBox Author
Report back if you found the issue.
Reply 11 of 37, by whocrazy
the program didn't come with any installer, it was just a .zip file.
Thanks
Reply 12 of 37, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I have QuickBASIC Extended v7.1, and I tested this super simple example:
OPEN "CON" FOR OUTPUT ACCESS WRITE AS #1
PRINT #1, "HI"
Running in the WinXP command shell, this prints "HI" out to the screen, but running inside DOSBox it throws a "File not found" error. No preceding path is specified, but maybe one is being used internally by QBasic...
Reply 13 of 37, by wd
Rank DOSBox Author
DOSBox Author
Do QuickBasic and QBasic behave the same?
Reply 14 of 37, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Yes, QBasic 1.0 (the one included with MSDOS 5.0), behaves the same.
Hehe, I even tried something more archaic using BASICA.EXE from Compaq DOS 3.31 (can't use IBM's BASICA unless you have the ROMs):
10 OPEN "O", 1, "CON"
20 PRINT #1, "HI"
The aboves works OK in the command shell, but gives an "Illegal Function call in 10" in DOSBox.
Reply 17 of 37, by Qbix
Rank DOSBox Author
DOSBox Author
Exactly the problem I was talking about. (checking if it is a device fails when a directory is before it and the directory is valid)
RCS file: /cvsroot/dosbox/dosbox/src/dos/dos_devices.cpp,v
retrieving revision 1.18
diff -u -r1.18 dos_devices.cpp
--- dos/dos_devices.cpp 14 Jun 2007 08:23:46 -0000 1.18
+++ dos/dos_devices.cpp 26 Sep 2007 09:55:32 -0000
@@ -138,13 +138,14 @@
Bit8u drive;char fulldir[DOS_PATHLENGTH];
if (!DOS_MakeName(temp,fulldir,&drive)) return DOS_DEVICES;
if(!Drives[drive]->TestDir(fulldir)) return DOS_DEVICES;
- *leading='\\';
+// *leading='\\';
+ leading++;
+ } else leading = temp;
/* loop through devices */
for(Bit8u index = 0;index < DOS_DEVICES;index++) {
if (Devices[index]) {
- if (WildFileCmp(temp,Devices[index]->name)) return index;
+ if (WildFileCmp(leading,Devices[index]->name)) return index;
return DOS_DEVICES;
Sample code doesn't work though. as they try set device information on it.
Is that qbasic freeware nowadays ?
Reply 18 of 37, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The wikipedia article about QBasic has a direct download link for it on the Microsoft servers.
http://en.wikipedia.org/wiki/QBasic
Maybe only free for personal use, not for distribution.
Reply 19 of 37, by MiniMax
Rank Moderator
Moderator
My best guess is that you are only allowed to download/use it if you already have a valid license to W95.
_________________
