Reply 20 of 86, by tokenalt
Mamba wrote on 2023-08-09, 19:17:
The Serpent Rider wrote on 2023-08-09, 17:27:
Pentium III workstation/server boards had PCI-X 1.0. End of the story.
And since PCI-X slots are directly connected to the north bridge and have direct path to RAM, it's practically an AGP.
But he is the winner anyway.
I never denied the existence of them I even named one of them in my first comment. I just said your board wasn't one. Please stick to what I said.
Reply 21 of 86, by Mamba
tokenalt wrote on 2023-08-09, 19:22:
My board IS indeed a workstation server board with two pci-x.
But again, think what you want, no problem with that.
No willing to explain the difference between pci and pci-x.
Reply 22 of 86, by Mamba
Here the diagram of the serverworks chipset. The Pci64 slots are directly connected and not linked to regular pci bus.
Reply 23 of 86, by pancakepuppy
Could always run lspci -vvv on your system and look for a "PCI-X Bridge Device" entry in the capabilities list of the host PCI bridge(s). No entry, no PCI-X. Personally, I don't think any Pentium 3 system that isn't a Compaq ProLiant DL760 Generation 1 has them. "PCI-X System Architecture" from MindShare Inc is a good book to learn about the bus if you don't like how dense the PCI-SIG technical documents are.
Reply 24 of 86, by tokenalt
Mamba wrote on 2023-08-09, 20:47:
Yes your board uses CIOB2 IO bridges which are PCI. The next generation boards used CIOB-X for PCI-X v1.0 and the ones after that used CIOB-X2 for PCI-X v2.0.
There's lots of stuff on the web talking about it.
https://www.informit.com/articles/article.asp … 481869&seqNum=7
https://www.sql-server-performance.com/chipsets-pros-cons/3/
http://www.qdpma.com/SystemArchitecture/Syste … ecture_FSB.html
https://docs.broadcom.com/doc/12358174
https://www.anandtech.com/show/715/5
Reply 25 of 86, by Grem Five
Mamba wrote on 2023-08-09, 16:56:
Grem Five wrote on 2023-08-09, 15:33:
What settings did you use for 3dmark01? Stock settings?
Stock settings
I asked because I just ran some test on my P3TDLE (dual 1.4) and my matrox parhelia 256 pci ("pci-x") with stock 3DMark01 to compare to your results:
OS: Win2k SP4 & DX9.0c
  1. 64 bit / 66 Mhz = 6068
  2. 64 bit / 33 Mhz = 5137
  3. 32 bit / 33 Mhz = 4377 ( one of the regular pci slots and not one of the top 2 "pci-x" / pci64 slots)
While this gpu isnt anywhere close to as powerful as the ones you tested I thought you might be interested in the 66Mhz to 33Mhz results and threw in the 32bit result to compare to the 64bit result just because.
Reply 26 of 86, by The Serpent Rider
Grem Five wrote on 2023-08-09, 22:26:
[*]64 bit / 66 Mhz = 6068
[*]64 bit / 33 Mhz = 5137
[*]32 bit / 33 Mhz = 4377 ( one of the regular pci slots and not one of the top 2 "pci-x" / pci64 slots)[/list]
Seems to be on par with AGP Parhelia results.
Reply 27 of 86, by Mamba
I asked because I just ran some test on my P3TDLE (dual 1.4) and my matrox parhelia 256 pci ("pci-x") with stock 3DMark01 to com […]
Stock settings
Thank you,
The results are useful for indeed, actually that board with the 8112 bridge “feels” much more fast than a regular dual socket board with AGP.
Reply 28 of 86, by The Serpent Rider
Dual Pentium 3-S 1400Mhz / ASUS TR-DLS from HP OEM (also known as NetServer TC3100) / 1 Gb RAM PC133 / GeForce 6800GS 256 Mb installed into regular PCI slot with PEX 8112 adapter / Forceware 93.71 / Windows XP SP3
Quake 3 Demo v1.09 / High settings preset (800x600x32) Demo001 - 130.1 fps
Quake 3 Demo v1.09/ High settings preset (800x600x32) Demo002 - 117.7 fps
3DMark 2001 SE (stock settings) - 8388 points
Detailed report:
Game 1 - Car Chase - Low Detail - 115.2 fps
Game 1 - Car Chase - High Detail - 35.5 fps
Game 2 - Dragothic - Low Detail - 137.3 fps
Game 2 - Dragothic - High Detail - 78.1 fps
Game 3 - Lobby - Low Detail - 104.1 fps
Game 3 - Lobby - High Detail - 45.0 fps
Game 4 - Nature -82.5 fps
For some reason I can't get any video card identified on my Windows XP setup past basic SVGA card when using PCI-X slots, they are no even shown in the device manager. But regular PCI actually scales pretty high, all things considered. especially in the Nature test, which is geometry heavy.
Reply 29 of 86, by Mamba
The Serpent Rider wrote on 2023-08-10, 22:01:
Dual Pentium 3-S 1400Mhz / ASUS TR-DLS from HP OEM (also known as NetServer TC 3100) / 1 Gb RAM PC133 / GeForce 6800GS 256 Mb in […]
Dual Pentium 3-S 1400Mhz / ASUS TR-DLS from HP OEM (also known as NetServer TC 3100) / 1 Gb RAM PC133 / GeForce 6800GS 256 Mb installed into regular PCI slot with PEX 8112 adapter / Forceware 93.71 / Windows XP SP3
Quake 3 Demo v1.09 / High settings preset (800x600x32) Demo001 - 128.9 fps
Quake 3 Demo v1.09/ High settings preset (800x600x32) Demo002 - 116.9 fps
3DMark 2001 SE (stock settings) - 8343 points
I experienced the same problem with a STL2.
It depends on compatibility between bridge and chipset on the motherboard.
Reply 30 of 86, by The Serpent Rider
TR-DLS has PCI-X integrated directly to the chipset though.
Reply 31 of 86, by Mamba
The Serpent Rider wrote on 2023-08-10, 22:21:
Yes, also mine.
For “bridge” I mean the pex8112 card.
Oddly enough, other pci bridged cards, like the Matrox p690 or the gt610 pci which do not use the pex chip, do not work on the Supermicro board.
Reply 32 of 86, by The Serpent Rider
Oh well, in that case that motherboard is useless. Good thing I've acquired it as a bonus to Tualatins and bunch of other stuff that came with it.
Reply 33 of 86, by Grem Five
Mamba wrote on 2023-08-10, 22:31:
Yes, also mine. For “bridge” I mean the pex8112 card. Oddly enough, other pci bridged cards, like the Matrox p690 or the gt610 p […]
Yes, also mine.
Can you explain a bit more as in how it didnt work? No picture or ?
Reply 34 of 86, by Mamba
Grem Five wrote on 2023-08-11, 01:00:
Yes, also mine.
This is the topic I opened before I gave up with the STL2.
STL2 dual S370 board + pciexpress/bridge GPUs attempts
The 370DLE had better compatibility.
You can find others with the same problem, sometimes a bridge card won’t work in pci64 slots [when coupled with a video card].
Reply 35 of 86, by The Serpent Rider
I have no issues with the bridge itself, but any video card I install into it is not recognized as Plug&Play device, so I can't install drivers. That being said, AIDA, HWINFO and other similar utilities fully recognize that video card is installed and identify it normally.
Reply 36 of 86, by Grem Five
I had similar sounding problem with my card. I had to turn off MPS 1.4 mode in bios so it would run in 1.1 mode.
MPS 1.4 would seem to assign the resources to the bus and then the bridge chip on the Matrox would not be able to find any free resources for its bridge chip.
Reply 37 of 86, by Mamba
Never solved the issue so I sold the STL2. I am very happy with the 370DLE.
Indeed it seemed to have issues with vga connected to the bridge, also for me, my statement was incorrect.
Reply 38 of 86, by The Serpent Rider
Does 370DLE has ISA DMA btw?
