ps/2 mouse on a SY-5EH5
First post, by weldum
Hi, i'm having a hard time figuring out what's the pinout on the PS/2 mouse header in the motherboard, it's a Soyo SY-5EH5 v1.3
I had the original mouse bracket with both PS/2 and serial ports, but it seems to be lost in my warehouse
i've been trying to make a custom adapter so I can use my PS/2 mouse, someone can help me? thanks
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 1 of 3, by Horun
And of course Soyo did not include the pinouts of either PS2 or USB in the manual. First I would check is for +5v and then GND. Of the the six pins only two left needed are clock and data which if you mess up will not hurt anything but a visual to see where the traces go will help figure which two they are.
This may help OR not(is for a shuttle but a place to start): https://www.betaarchive.com/forum/viewtopic.p … 3bd5e84#p284837
If you do figure it out please post.
Reply 2 of 3, by weldum
Horun wrote on 2023-08-13, 00:40:
that's the pinout i've used for my adapter, the mouse powers on but windows doesn't report a mouse, so at least 5v and gnd are correct
now i need a way to identify the data and clock signals, sadly i only have a soldering iron, a multimeter and my basic electronic skills
Reply 3 of 3, by weldum
these were the pinouts that worked (in the second image is the right one)
the adapter was wired correctly, the issue was that the data cable was cut, changing it fixed the issue, now the mouse works perfectly
thanks for your help!
