Reply 24920 of 27798, by Thermalwrong
Joakim wrote on 2023-08-14, 20:48:Removed a corroded väta battery from an ibm 760cd. Broke both speaker connectors so I had to fix that.. got my hands on some leaded solder and damn, now I can actually solder without much problem at all.
Hopefully it is all working tomorrow.
Don't get disheartened if things aren't 100% when its back together, I did the same for my 760LD a few months back and after the battery removal, one strip of keyboard keys stopped working. It was just my 'cleaning' - had cleaned off what was left of a via and one that was repaired with a jumper wire it was all working again.
I am pretty stoked right now - years ago when disposing of an ATX case I kept the tray and it's been sitting round used occasionally. A few weeks back I decided to make this into a small open testing case with a baby-AT motherboard in there, this one's the tiny PC partner MVP3 board with an AMD K6-2 450. The power, reset buttons and HD LED are hotglued into a slot bracket so it can all be used from just the ATX brackets side.
It's so cramped that the IDE connectors block off some of the PCI ports, but it gives me AGP, PCI and ISA with a decent TFX power supply. Made mostly from scrap metal and scrap 3d prints:
The floppy/CD drive hinges up out of the way of the cards, some design stuff I want to change already is that floppy cable I hard wired onto there is way too short. Gonna make that removable again and improve how the drives are held up, they're sinking down at the back pretty badly. Oh and the USB / parallel need to get out of the way and fit into that ATX shield somehow, gonna keep this metal rather than a 3d print though.
There's been a stack of video cards that I've not tested because my AGP systems are all built and packed away - this new rig makes it easy-ish to test out video cards again 😀 This Voodoo 3 with deep scratches and bashed up memory chips surprised me, it works perfectly with no real repairs. I think it's a Voodoo 3 3000 possibly? The BGA chip looked too clean for a glued on heatsink to have been removed:
The Voodoo 2 card in there is a Miro Hiscore2 3D which I got a while back, it needed some pins repaired on the RAMDAC but I've had no PCI systems to try it in - also I've had such terrible luck with Voodoo 1 cards that I was putting off testing this Voodoo 2 card. It also works first try - now I need to figure out how to connect the VGA passthrough since I've got no cable. Might try SLI though, since this means I finally have 2x Voodoo 2 cards and both work. The other ones a generic design, but using that generic one as the main card and the Miro Hiscore2 as the SLI secondary card might mean I don't need the special passthrough cable?
Oh also, 🤣, mixed up MB and GB when using diskpart and accidentally destroyed the filesystem on my 4TB external USB when I meant to clean a 4GB CF card
