First post, by schnoots148
Hello all, I can't seem to go above 1024x768 in windows 98 on 81.98 nvidia drivers (could not for the life of me get a signal with 45.23 which is best apparently). If I try to set 1280x720 or above I get a no signal or "input not support" error. My monitor is an aoc 1440p 32 inch CQ32G1.
I have installed the inf for the monitor which worked surprisingly, but I am still having the same problems. GPU works fine and isnt toast yet (quadro fx 1000) as when I plug it into a generic 1080p tv I can set the resolution to 1920x1080 just fine, and games run well. GPU is connected with DVI to HDMI cable.
With the use of powerstrip (which I have no idea how to use) all I get is 1920x1200 with a black bar on the side and a really low refresh rate. 1920x1080 through powerstrip as well had this weird issue where the cursor multiplied when hovered over a section of the screen and was super blurry. Powerstrip also reports that my max resolution is 1280x1440 which is far from right.
I've seen videos from philscomputerlab of him using monitors newer than mine with no issues on old pcs and I would really like to complete my setup with decent picture quality. I am aware that 1440p at 144hz is impossible on this card but that isnt a problem as I know its single link dvi only.
If anyone could point me in the right direction with maybe some better drivers or how to get powerstrip working right I'd greatly appreciate it!!
