First post, by Numbuh 128Bit
Hi! Just registered here, so this is my first post. Anyway, I'm thinking about buying a PCI Sound Card with FM synthesis capabilities for my Windows 98SE. I use it mostly as a retro gaming computer. What I'd like to know is:
1: What can the FM synthesis be used for besides games, and will PCI sound cards will be detected in DOS?
2: When playing a MIDI file in a media player through any such sound card, will the MIDI be played using FM synth instead of the standard instrument set that comes with the OS?
3: Are there any programs that can generate FM synthesis?
Any help would be appreciated. I plan to buy either a "Yamaha XG YMF724F-V" or an "Avance Logic ALS 4000".
Here are my Specs:
Motherboard: ECS K7SEM 3.0A
Graphics: Onboard SiS 630/703 VGA
Audio: SiS 7018 Audio Driver with MPU-401 Compatible MIDI Driver
Memory : 386MB SDRAM
CPU: "Authentic AMD" AMD Duron (TM) Processor apparently running at 893MHz.
Thanks in advance.
