First post, by mrgreen
Hello,
does the controller embedded on wearnes-pb3905 (https://theretroweb.com/motherboards/s/wearnes-pb3905) motherboard support CD burners (no need of burning features but only reading CD-ROM, CD-R and CD-RW)?
I would like to add a CDROM drive to this 386 motherboard but (after installing OAK Driver) the device is not found. I connected on the same IDE cable of the hard drive (which is jumperless, about 80 MB size).
I tried to put either slave jumper or no jumper on CD burner drive as well but nothing...
Do I need an external IDE controller that supports ATAPI (or whatever standard that makes the CD burner works)?
My first PC had Windows 98 os.
Reply 1 of 8, by zami555
I'm sceptical about this HDD being jumperless. I think this could be the culprit. Could you please share photos of that drive to help to identify model?
Reply 2 of 8, by VivienM
How old is this motherboard? ATAPI first started to be a thing in late 1994ish, I think - before then, the most common way of connecting a CD-ROM (e.g. the way all those 'multimedia kits' did it) was using a proprietary interface on your sound card...
Reply 3 of 8, by rasz_pl
I dont think there is such a thing as jumperless HDD unless you mean cable select, and afaik that one will need compatible IDE cable.
master/slave was problematic for more than obvious reason https://www.os2museum.com/wp/the-dual-drive-ide-hell/
VivienM wrote on 2023-09-02, 12:22:
ATAPI wouldnt matter, its layer above. IDE CD drive IDE implementation tho would and Its possible early drives didnt know how to work as secondary on same cable.
Reply 4 of 8, by mrgreen
I found the jumper on the bottom of the hard drive.
The C/D pins are already jumpered (shorted) and this means "SINGLE DRIVE" or "PRIMARY DRIVE". So the CD burner should be the slave (secondary drive). But this setting I already tried unsuccessfully.
Ref: https://www.computerhope.com/hdd/hdd0047.htm
I also noticed that my disk has no CAM pins but only E1 and C/D.
Reply 6 of 8, by Horun
Yes am thinking that it (HD) cannot master that new of a cdrom if any ide cdrom. Have seen similar issues before (and probably one of the reasons nearly all sound cards of same era <1993 based on chipset dates> have a cdrom interface of some type)
Added: not mention that newer IDE cdroms are ATAPI spec, that spec came out late 94 or 1995, so a HD from around 1992-93 would not be built to properly communicate with it as a master/slave...as VivienM mentioned and afaik
Reply 7 of 8, by mrgreen
I tried to invert: I put CD burner as master and the drive as slave but the situation is worst, no boot is possible from hard drive.
I'm going to try putting a compact flash adapter instead of the HD.
Reply 8 of 8, by jmarsh
A compact flash adapter is even less likely to work, most of the time they're wired to be the only drive on the cable / don't have the required signal connected (PDIAG) for proper master/slave operation.
