Reply 60 of 104, by an64
I tried with code from gtx520, and it works!!
vesatest shows correct image and page 1/2 indicator
but...
duke3d runs, but it seems that it using vsync , and i get lower fps , compared to mskvbef7
need your feedback
Reply 61 of 104, by an64
LSS10999 wrote on 2023-09-01, 13:38:
Tried your second PSAVE on my system. Looks like it's producing something useful. I'm getting a 395-byte PMTABLE.BIN file with more contents.
Yes, that is
Thanks!
It slightly different from that i get from gtx520 , will look at it later
Can you test dike3d on your card with mskvbef7(from 1st message in this thread) and without?
Compare fps pls (type 'dnrate' while in game to show)
Reply 62 of 104, by Falcosoft
an64 wrote on 2023-09-01, 16:07:
I tried with code from gtx520, and it works!! […]
but...
need your feedback
Yes, it is using vsynch when page flipping is active but I think it is normal. Both the real-mode and the protected mode interface provide explicit vsynched HW page flipping mode (Function 07: BL = 80h Set Display Start during Vertical Retrace).
Build engine games and Quake most likely use this mode to prevent tearing.
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 63 of 104, by LSS10999
an64 wrote on 2023-09-01, 16:09:
It seems MSKVBEF7 can significantly improve performance even on my Quadro 2000, and fixes (not frequent) flicker issue when playing DUKE3D on 800x600. Player movement is also much smoother after using MSKVBEF7.
Averages without MSKVBEF7:
Starting point: 139
Opening menu: 70
Entering the room with mirror: 24
With MSKVBEF7:
Starting point: 170
Opening menu: 137
Entering the room with mirror: 187
As for the higher-than-usual frame rates (partly off-topic)
I'm connecting my monitor through a DP-to-HDMI connection with a hacked EDID dongle configured to output at 1680x1050 144Hz. This allowed pretty much all DOS and VESA/VBE outputs of all standard resolutions (namely 4:3 ones) less than this to work at 144Hz instead of 60Hz on my monitor, hence the expected FPS would be around 144 instead of 60. However, the hack is very delicate and does not work with every dongle and every monitor port, and it seems only nVidia cards can be forced this way to output at a user-defined timing even in DOS and VESA/VBE modes (for other cards and monitors, such hack do not work and will only end up severely limiting available video modes in other OSes such as Windows and Linux).
For this video card (only DP1.1) and my monitor, 1680x1050 144Hz is the best I could set to enable 144Hz output while avoiding creating a black border on the monitor. It seems the monitor has a special interest in resolutions like 1920x1080, that forcing such resolutions would create a black border around the screen and make everything look smaller.
Reply 64 of 104, by an64
Is anybody know dos utility to set mtrr's on intel ivy bridge cpu?
Reply 65 of 104, by an64
New version , now you can disable and force vsync
Fps in duke with novsync mode anyways lower then with mskvbef7 and i see some flickering
Anyway , it interesting to test and compare
Reply 66 of 104, by RayeR
an64 wrote on 2023-09-02, 08:27:
My mtrrlfbe should work.
Reply 69 of 104, by an64
Falcosoft wrote on 2023-09-01, 21:12:
Ok , now we have 2 alternate ways
1: MSKVBEF7 , shows 300+ fps here 😀 I not shure thats right, but impressing
2: My NVUVAFIX . Shows 60/30 (mostly 60) , but with vsync
Can you test it with NVUVAFIX.COM /5 /9 on your 960?
And especially interesting on 1060
Reply 70 of 104, by RayeR
[/quote]
For vga it doing some strange things , not working at all
[/quote]
Maybe, I never used it for VGA as the VGA FB is only 64kB and it doesn't have much sense to use it in such modes like 320x200 as they are fast enough anyway...
Reply 71 of 104, by Falcosoft
RayeR wrote on 2023-09-04, 16:41:
The 64KB VGA FB is used also by all high resolution VESA 1.2 modes (i.e. all modes that do not use LFB but banked mode).
E.g. if you use NOLFB then you will always use VGA FB even for high resolution modes. Also real mode games that use VESA modes and utils written with Turbo Pascal/C that use SVGA BGI drivers use VGA FB for high res graphics.
In the above cases speed could be somewhat relevant.
Reply 72 of 104, by RayeR
Yes but window switching bios calls would probably make it much slower regardless setting WC...
Reply 73 of 104, by Falcosoft
RayeR wrote on 2023-09-04, 19:55:
According to my tests when WC flag is working for VGA FB it can speed up rendering by 2-15%.
Re: MTRRLFBE and AGP/PCIe cards in DOS
On Athlon64/Phenom CPUs you have to fine tune MTRR's since System Management Mode related settings interfere with banked VGA write combining by default. Maybe there is a similar problem with newer Intels also.
Reply 74 of 104, by RayeR
Falcosoft wrote on 2023-09-04, 20:07:
That's not much worth (I guess that bottleneck is calling vbios and PM/RM switching)...
on LFB the speed up may be 50x on modern systems with PCI-E...
Reply 75 of 104, by Falcosoft
RayeR wrote on 2023-09-04, 20:17:
50x speed up sounds to be a rather theoretical result. With real world programs the speed up is expected to be at least 1 magnitude less.
With the same testing methods LFB+WC resulted in 25%-250% speed up on the same tested systems (interestingly the system with dedicated PCI-E card produced the worse speed up in both VGA+WC and LFB+WC cases).
Reply 76 of 104, by an64
Now my NVUVAFIX have a /5 switch for using protected mode code taken from gtx520
I compared vbetest perfomance in 1280x1024x32 banked mode - my code ,calling rm int10 for func 05 and pm code:
9 vs 25 fps and in 1 test i can see the diffence by eye
never think, that pm-rm transitions takes so much time even on fast cpu...
Ps /5 tested only on maxwell 980ti, please someone test it on newer nvidia
Universal NVIDIA vbe function 0A fix for gtx 9xx and newer
Reply 77 of 104, by RayeR
Thanks for info, it's really noticable speed up. I will test on my GTX970, I expect it's affected the same as 980.
Reply 79 of 104, by RayeR
BEEN_Nath_58 wrote on 2023-12-11, 02:00:
I recall there was a notice for removal of VBE from AMD cards, here's a third party link:
https://www.scribd.com/document/578511765/Rem … -8-bbb-graphics
This is near 10 year old, what's the current status on AMD cards? Nvidia even broke VGA compatability at IO regs level on RTX, does at least VGA modes still works on current AMD cards? And VBE?
