First post, by Jester
I can’t find the thread but there was one showing two parts I need to add to my existing adapter to get the -5v rail I need for my sound blaster 2.0 . One part is a ceramic resistor .
Can someone show me which parts to order on mouser.com and which pins they connect to ? I’d rather do this than order a voltage blaster and lose an Isa slot. My power supply says it has -5v rail, but I don’t think it’s getting through?? Here is my current adaptor.
141.3 KiB
Reply 1 of 10, by dominusprog
You need an ATX power supply from early 2000s which output -5V. Or you can build a circuit to convert -12 to -5V.
https://www.powersystemsdesign.com/articles/t … oltages/37/9756
Reply 4 of 10, by Horun
rasz_pl wrote on 2023-09-09, 01:02:
all you need is LM7905, thats what Voltage Blaster uses. Re: AT pico psu.
Agree ! and use the -12v to feed it.
Reply 5 of 10, by dominusprog
This one might be the cheapest option.
https://www.youtube.com/watch?v=b2XOo_8uzvw
https://github.com/scrapcomputing/voltage-blaster-mini
Reply 6 of 10, by Jester
Thanks, that should be super easy to build. I went rummaging under the stairs through my old stock, and found two first generation Sparkle (SPI) ATX power supplies. The oldest one actually has the -5v rail. The other is a micro ATX psu with the -5v rail, but when I hook the microatx up to my 486 board using the converter, I get nothing.
I will try the SPI one with -5v now, that should get me up and running with the sound blaster 2.0 !
Reply 7 of 10, by Jester
Looks like I will need to replace the caps on this psu before plugging it into any motherboard.
Reply 8 of 10, by Horun
I have a similar tester and you should hook up a harddrive to one of those molex when testing, some testers do not draw enough current on old PSU's for the rails to be stable....
Reply 9 of 10, by Jester
It’s strange. The matx psu works fine in the matx board, and the internet says it should work the same as an ATX power supply with lower wattage . Yet when I plug it into the psu tester or a 486 board using the converter, I get nothing. Was really hoping to use it since it has the -5v rail (white wire)
1.98 MiB
Reply 10 of 10, by the3dfxdude
The voltages on the sparkle aren't necessarily bad. The +5V and +12V look ok. You should connect a proper load to it. It may very well work to power a motherboard right now. Then you can check the -12V and -5V with a volt meter, and all the other supplies. It wouldn't hurt to inspect the inside of it, if you know how to be safe.
