First post, by lilkuz2005
Hey guys, I have a Pentium 4 setup running windows 98se. The specs of the build are Intel Pentium 4 3.00E GHz, 1M Cache, 800 MHz FSB, 2x 256mb pc3200, Intel D865glc motherboard. The motherboard supports dual channel memory configurations. The bios shows that the memory is installed and configured as dual channel, but I noticed that tools like CPU-Z or HWINFO in windows 98se are reporting that the memory is in single channel mode. Does windows 98 support dual channel memory? Is it possible the intel chipset drivers are limiting the memory controller to single channel mode? Is there a registry entry that can be modified to allow dual channel?
asus p3b-f, intel pIII 1000/133/256 thermaltake golden orb, 2x crucial 256mb pc133, nvidia geforce 3, aureal vortex 2, IDE to SD adapter samsung 128gb evo
asus p3v4x, intel pIII 650/100/256, 256mb pc133, 3dfx voodoo 3 3ooo, awe64 value!, 80gb hdd
Reply 1 of 8, by dominusprog
I believe operating systems in general don't care about such things. Also try A1/B1 slots.
Anyway, do some benchmarking to see if it makes any difference.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 8, by lilkuz2005
dominusprog wrote on 2023-09-09, 11:19:
I tried switching the memory around a couple days ago, I looked at the motherboard manual to make sure the memory was installed correctly. I think it may be a bug with windows 98se either not using dual channel memory or possibly the chipset drivers not using it. As for benchmarks I guess I could try to swap out the 2x 256mb sticks for a single 512mb stick and see if there is a performance difference.
Reply 3 of 8, by Trashbytes
I dont believe Win98 even understands the concept of dual channel memory much like it doesn't understand what dual core CPUs are, so long as the BIOS is reporting it as working I wouldn't worry too much about what Win98 is reporting.
The other point worth considering is that Win98 wouldn't see any benefit from dual channel memory, it also doesn't get any benefit from dual core CPUs the OS itself simply doesn't have the capability of supporting these features.
I also doubt very much that you will see any performance increase from dual channel over single under Win98, though it would be fun to see if there is any.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 4 of 8, by lilkuz2005
Trashbytes wrote on 2023-09-09, 14:07:
I'm looking through my parts to see if I have a 512mb stick of pc3200 ddr, I'm not sure if I do, but if I can find a stick I will do some benchmarks, any test you think I should try?
Reply 5 of 8, by VivienM
Maybe I'm completely wrong here, but I would have thought dual-channel memory is a memory controller/BIOS thing, not an OS thing. If, with the same BIOS settings, same memory, same everything, you boot a more modern OS, what does it say about your dual channel memory?
I would wonder whether the tools you are using to report on the memory controller status are actually able to report that under Win98.
Reply 6 of 8, by lilkuz2005
Okay so, I tested PCMark2002 on the pc, I ran the test 3 times for both 2x 256mb and 1x 512mb. I'm not sure if this synthetic benchmark is accurate but it does show a performance difference between single and dual channel memory configurations. So according to this benchmark it is beneficial to run dual channel memory even if windows 98se doesn't show it utilizing it.
PCMARK2002 2x 256mb pc3200
Test 1:
CPU Score 6290
Memory Score 9075
HDD Score 308
Test 2:
CPU Score 6291
Memory Score 9062
HDD Score 3660
Test 3:
CPU Score 6292
Memory Score 9063
HDD Score 3644
PCMARK2002 1x 512mb pc3200
Test 1:
CPU Score 6277
Memory Score 7015
HDD Score 326
Test 2:
CPU Score 6273
Memory Score 7052
HDD Score 2803
Test 3:
CPU Score 6261
Memory Score 7075
HDD Score 2797
Reply 7 of 8, by Maryoo
I have never noticed any performance increase in Win9x with Dual Channel. Some of my motherboards even performed better in Single Channel.
Reply 8 of 8, by rasz_pl
VivienM wrote on 2023-09-09, 16:13:
yes
again very much yes, this is a bug/not implemented fully in CPU-Z Vintage Edition Need help to improve the support of 486/586/686 class CPUs in CPU-Z
