First post, by appiah4
I have a 386SX motherboard that POSTs fine to BIOS and boots fine to DOS using a floppy:
The attachment 386SX POST.jpg is no longer available
The attachment 386SX BIOS.jpg is no longer available
The attachment 386SX Floppy Boot Normal Text.jpg is no longer available
But when I attach a CF-IDE to the Primary IDE chain as master I get all kinds of garbled text after POST:
The attachment 386SX CF Boot Garbled Text.jpg is no longer available
What would cause such weird behaviour? I almost feel like something is messing with the framebuffer somehow, but how? These are the default options in BIOS Advanced CMOS Settings..
The attachment 386SX BIOS Defaults.jpg is no longer available
Reply 1 of 14, by jmarsh
Poor quality CF adapter probably connects pin 28 to ground.
Reply 2 of 14, by rain
i need answer , of this too 😀
Reply 3 of 14, by rasz_pl
not poor quality, simply ATA compliant.
Re: "Fixed" 386sx motherboard works but not with 16-bit VGA card Re: IDE/CF adapter causing screen corruption/missing characters
Reply 4 of 14, by jmarsh
There is absolutely no reason for a HDD to short pin 28 to GND (it shouldn't be driven by the drive at all, it's an input signal) and it's definitely not ATA compliant.
Reply 5 of 14, by appiah4
So I am guessing simply snipping pin 28 off the cf ide connector will do the trick?
Reply 6 of 14, by wierd_w
That is often suggested. I have seen it done. JUST VERY CAREFULLY VERIFY THAT IT IS INDEED PIN 28 before you cut.
Reply 7 of 14, by appiah4
Removing Pin 28 from the CF-IDE adapter did not fix the issue..
Reply 8 of 14, by DerBaum
i have a 486 that really doesnt like 80wire ide cables and refuses to identify my cf card with it.
As soon as i use a regular old 40 wire ide cable it intantly sees the cf card.
Have you tried another cable?
FCKGW-RHQQ2
Reply 9 of 14, by appiah4
DerBaum wrote on 2023-09-11, 13:00:
A 40 stripe cable improves the situation somewhat, but there is still mising text.
Reply 10 of 14, by DerBaum
appiah4 wrote on 2023-09-11, 13:41:
Another thing i had problems while using cf cards is the auto detect of the bios.
I cant remember if i had to set the card from LBA to CHS or the other way around to make it work.
I also cant remember if i had missing letters. The main issue was that the system ran a "dir" fine when booted from a floppy but at a regular boot it hang while executing the drivers in autoexec.bat/config.sys .
In the end i configured the card manually in the bios and ran a low level format from the bios. Then Fdisk/format the card from dos 6.22 .
FCKGW-RHQQ2
Reply 11 of 14, by appiah4
DerBaum wrote on 2023-09-11, 14:28:
Another thing i had problems while using cf cards is the auto detect of the bios. I cant remember if i had to set the card from […]
This BIOS has no auto detect, the CHS values are set as Type 47..
Reply 12 of 14, by Jo22
Be careful with low-level format feature in BIOS.
It's dangerous under most circumstances. It's not like a soft format, at all.
The feature is there for 16-Bit MFM/RLL controller boards without an on-board BIOS.
- On 8-Bit systems debug was used to call low-level routines stored in ROM.
On an IDE HDD or a CF card, a low-level format can have unpredictable effects.
It can be that the firmware does weird things with the sectors, rendering the hardware unusable.
I rendered at least one CF unusable that way.
Reply 13 of 14, by Jo22
appiah4 wrote on 2023-09-11, 12:30:
It's just an idea, but if it's not a hardware issue, then maybe it's a software issue?
The ATA-2 specification (Fast ATA, Enhanced IDE) changed a lot of things back then.
It could be that the HDD routines in the BIOS have issues with that.
Edit: https://www.os2museum.com/wp/how-to-please-wdctrl/
It's essentially IBM's AT Fixed Disk Adapter (WD1003 command set) and/or ATA (IDE, AT Bus) all they know.
That's why "HDD Auto Detection" is missing, also, it's a future ATA feature and not available on MFM/RLL controllers yet.
If BIOS is the issue, using XTIDE Universal BIOS could help here.
I had a similar issue in which it did, at least. It was a Schneider Tower AT with an outdated BIOS..
Whenever it was meant to boot DOS, it hung.
Anyway, this is just an idea, of course. 😅
Reply 14 of 14, by rasz_pl
I dont think DOS (therefore bios) touches disk while displaying "enter new date".
Just to make sure, storage still works? Try older CF card.
