First post, by Orzene
I picked up an old IBM ValuePoint 433DX about a month ago, and have been slowly upgrading it here and there (CF-to-IDE for HDD, Dos 622 and Win3.11, AMD 486DX2-66, etc.)
Sadly, no VESA support on the board, since it's a Model 6384 MoBo. I'd love to replace it someday with a later board and a VLB Riser card installed! 😁
I was looking at video cards for the thing, and I came across a few on eBay. One went on sale, and I picked it up:
A Cirrus Logic VAVGA31-5420-1M ISA card, listed as 2 MB memory (I questioned the memory, too, but I was willing to test it, at least).
Now, I'm thinking of getting a Tseng Labs ET4000ax to replace it because I'm not sure if this one is a dud, a scam, someone's experiment, or just a weird artifact that time forgot. I've got the VOGONS-listed 542x 1.43 drivers installed, but IDCHIP.EXE doesn't seem to recognize it (or the ISA slot isn't properly reading it - old hardware and all that). I'm using the mainboard's VGA output because the card SVGA port doesn't seem to want to work, or I don't know exactly what to do to get it to work. I'm not even sure the MoBo is registering that it's there, or not, from what poking around I've done.
And yeah, switching to the CL540x display drivers hasn't worked either (even the 16-bit color ones) for either VGA/SVGA port.
Or, maybe I'm just overthinking the situation. Best case scenario, 🤣!
eBay listed condition as: “Video Card Only. Manual and Drivers NOT included. OEM surplus. Fully Tested.”
The user I bought it from had a 99.6% positive from 2272 reviews, and has sold around 9.2k items.
If anyone has come across one of these, and has gotten it to run, I'd appreciate some more information and maybe even a little advice as to what to expect with it.
Reply 1 of 18, by dominusprog
For one thing, this card and many others from this generation have tantalum caps which can be gone bad by now. And as for "fully tested" maybe the seller just put the card on a working computer and it displays the boot screen. Done, it’s working.
Creative AWE64 Value ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 18, by Orzene
dominusprog wrote on 2023-09-23, 17:26:
Would there be any good way to test it directly? To see if what you said about the caps is true for this board? If not, then I suppose just going after a new video card would be the next best option.
Reply 3 of 18, by dominusprog
You should replace electrolytic and tantalum caps all together. Keep in mind that any of the five (memory and the processor) chips can also be the cause.
Last month, I purchased a Trident 9680 and one of the tantalum caps short the +5V to the ground immediately after I turned on the power supply.
Reply 4 of 18, by Orzene
dominusprog wrote on 2023-09-23, 20:20:
Soldering is a bit out of my range of experience, so I may still have to invest in a different card. Don't have the proper kit to do this sort of work, either. At least not at the moment.
The card will have to go into dry storage, I think, for now. I may repair it at a later date when I feel more comfortable doing that sort of thing. Thank you for the quick responses!
Reply 5 of 18, by TheMobRules
Usually boards from this era require you to disable the onboard graphics (by changing a jumper or DIP switch) before using a separate card. Otherwise it will always try to initialize the onboard video BIOS first.
Are you sure the onboard graphics isn't local bus? If that's the case, it should be much faster than any ISA card you may add. Post pictures of the motherboard if you're unsure.
Right now don't worry about tantalums (if one was shorted, it would have either exploded or prevented your machine from turning on) or Windows drivers (get it working under DOS first).
Reply 6 of 18, by Orzene
TheMobRules wrote on 2023-09-23, 20:58:
Here's the 6384 board I mentioned in the first post (see attached).
Also, I am unaware of jumper settings. Documentation is "thin" for this board, sadly.
Reply 8 of 18, by dominusprog
jakethompson1 wrote on 2023-09-23, 21:11:
It is (very briefly) documented on page 2 here: https://psref.lenovo.com/syspool/Sys/PDF/with … book/vpbook.pdf
The onboard is ISA, but it's an ET4000 w/ 1MB already. Are you sure you need to upgrade it?
Right? It's a very good chip. I don't know about Cirrus Logic but it performs better than Trident 8900.
Reply 9 of 18, by jakethompson1
dominusprog wrote on 2023-09-23, 21:46:
Yeah, and in fact, the data book shows that the contemporaneous 386 model came with an onboard CL-GD5422, so the CL-GD5420 would have been a "downgrade" anyway.
Reply 10 of 18, by clb
Have you tried running any other discrete ISA graphics card on the system? If not, my first suspect would be some kind of incompatibility between motherboard integrated graphics and the ISA discrete graphics. Would be good to be able to double cross-test, i.e. test that graphics card on another mobo, and test another graphics card on that mobo.
Reply 11 of 18, by Orzene
I missed the ET4000 1MB on-board video chip, which is certainly my bad. If that's the case, might just remove it anyway.
I looked through that document before, but for the proper CPU upgrades supported for the board, but didn't think to look through it again for on-board video specs. Was hoping, at the time, that it would support a DX4. No such luck, heh.
Reply 12 of 18, by jakethompson1
Orzene wrote on 2023-09-23, 22:04:
Speaking from experience (and others here share this), you're likely to end up building a separate "late era" 486 system anyway eventually, so you might save your DX4/5x86 and higher-end SVGA ambitions until then.
Even if you upgraded this system to a DX4 or 5x86 CPU, it would require voltage conversion rather than being able to use the bare CPU, and the chipset would fail to take full advantage of the CPU due to lack of support for write-back internal cache, and you will remain hampered by the ISA bus (and thus bench poorly on anything video related compared to typical DX4 systems) no matter what.
If I were messing with this system, beyond the 486DX2-66 CPU, maybe upgrade the RAM to 16MB if it's still 4MB, perhaps put in a sound card and CD-ROM drive, and perhaps an ethernet card, and call it a day.
Reply 13 of 18, by jakethompson1
Also, as a consolation prize, the CL-GD5420 could go into your future 386 build as I suspect nothing is wrong with it other than the conflict between onboard and ISA VGA card 😁
Reply 14 of 18, by Orzene
jakethompson1 wrote on 2023-09-23, 22:17:
I mean, as long as the money wasn't wasted (regardless of bargain prices paid to acquire it), it's all good!
If I can find a decent board with VLB support, I may go that route for the higher-end specs (like the suggested CPUs) - As for a 386, I can't see myself justifying that right now, since I'm not certain what exactly I'd build one for, but that could change down the road! 😀 I'd wanna plan around a form-factor and CPU limitation when/if that happens.
For now, I'm glad I have this IBM machine, and a Win98 machine. My next vintage rig might actually be a Win95 era PC (so mid-range between the two I have). We'll see.
Again, thanks for all the responses! Appreciate it greatly as a newcomer! 😁
Reply 15 of 18, by Orzene
jakethompson1 wrote on 2023-09-23, 22:14:
Speaking from experience (and others here share this), you're likely to end up building a separate "late era" 486 system anyway […]
I'm getting some Goldmark sticks in to put it at 16mb, from the 8mb I'm currently working with (just under certain game requirements). Hopefully things get a bit speedier!
Reply 16 of 18, by rasz_pl
This! Cant have two ISA VGA cards in same system, so you didnt test anything yet.
Reply 17 of 18, by Orzene
Update Note: I did test the card, and while it works, it doesn't work "well", for whatever reason -- Any time I use the Cirrus Logic Drivers (VOGONs library), it gives me a corrupted screen when loading into Win 3.1, so I'm wondering if the card is, in fact, corrupted in some way.
Again, I'll be keeping it in storage for now, since there's no reason to use it. The ET4000AX chip works good enough for my purposes, so I'm not gonna worry about it.
Reply 18 of 18, by dionb
Orzene wrote on 2024-03-13, 02:07:
ET4000AX is one of the better ISA chipsets, so you're not losing anything.
As for the CL card, I would recommend testing thoroughly before putting it into storage. Windows 3.1 can be a bit tricky with drivers, so I'd suggest just doing it in DOS with a tool like X-VESA.COM, that should be good enough for a 1MB card like this, at least assuming it has decent VESA support.
