performance voodoo 5 5500 + tualatin?
First post, by brunofbrsilva
Good afternoon everyone, I have a question regarding some tests that I am carrying out with the Voodoo 5 5500 with two different kits, they are:
SOYO SY-6VBA133
PowerLeap + P3 tualatin 1.4G
256MB of memory
HD 20G
VIA 4in1 4.35 drivers
Voodoo 5 5500
ASUS K7M
AMD Athlon 700Mhz slot A
256MB of memory
HD 20G
voodoo 5 5500
the 3dmark results are:
The attachment WhatsApp Image 2023-09-30 at 09.27.10.jpeg is no longer available
My question is: shouldn't the kit equipped with the pentium 3 tualatin 1.4G give me a higher score on the video card?
Reply 1 of 22, by Meatball
Yes, much higher; your score should be around or above 10,000 marks @800x600x16bpp if this is 3dMark 1999. Did you disable VSYNC? 3DMark 1999 won't disable VSYNC by default like all of the newer versions.
Reply 2 of 22, by brunofbrsilva
I didn't disable it, where can I do that?
Reply 3 of 22, by Meatball
You can use the attached utility from 3dfx. It adds a tab on the 3dfx Tools for Overclocking and disabling VSYNC for Direct X. Make sure you exit 3DMark before making the modification. You do not have to restart your machine for the changes to take effect.
Reply 4 of 22, by brunofbrsilva
I managed to disable vsync, both kits had improvements but the p3 kit still came in second place:
AMD : 5774 3dmarks
P3 tualatin: 5392 3dmarks
Reply 5 of 22, by Meatball
A 600/100MHz Katmai will be around 4600 and an 800/100MHz Coppermine will be around 6400. Can you verify your CPU is actually running at 1.4GHz? Download the CPU-Z Vintage Edition for Windows 9x here: https://www.cpuid.com/softwares/cpu-z_html to validate the CPU and FSB.
Reply 6 of 22, by brunofbrsilva
Here is the cpu-z result:
The attachment IMG_20230930_165012913.jpg is no longer available
Reply 7 of 22, by Meatball
Looking at your CPU marks shows how much faster it was the than the Athlon, but just double-checking.
Using the 3dfx Tools, except for VSYNC, do you have all settings at factory defaults? No AA is enabled, right? What are the results if you run 3DMark with just one of the VSA chips enabled?
Reply 8 of 22, by brunofbrsilva
I did the test with just one of the gpus activated, the result was:
5270 3dmarks
Reply 9 of 22, by Meatball
The card is probably fine. That number is just slightly lower than what you're getting now, which is what I have seen when I have tested. The card is OK in the Athlon, also. The CPUs are fine in both systems.
What OS are you running?
What DirectX version is installed?
What Voodoo5 driver are you running?
Is there a sound card installed?
Try running "Unreal Gold" in Glide mode. You should get a number around 120-130fps (make sure VSYNC is disabled) at 800x600x16bpp running the Castle Flyby demo. @1024x768x16, the Voodoo5 should still achieve over 100fps. This will tell us if DirectX is a problem.
Reply 10 of 22, by brunofbrsilva
Any FPS counter I can use? I tested flaps, but it doesn't work, I used a Glide dll but it ruins the whole game.
Obs: using directx the flaps work and exceed 130 FPS in some cases
The attachment 16961253482291629771611718655810.jpg is no longer available
Reply 11 of 22, by The Serpent Rider
Unreal has own statistics. If you have Unreal Gold you can enable it in the menu or just use console command "stat fps" in any version.
Reply 12 of 22, by brunofbrsilva
I managed to activate the FPS counter on the glide, but what information do I need to consider? frame or polys?
Reply 13 of 22, by Joseph_Joestar
To properly benchmark Unreal, open the console by pressing tilde (~) and type in the following:
timedemo 1
start unreal
After that, close the console window by pressing tilde again. This will make the game run its flyby demo and display the minimum, average and maximum frame rate on the right side of the screen.
Reply 14 of 22, by brunofbrsilva
Wow, now yes, here is the result with Glide:
The attachment 16961682460928298400627835842686.jpg is no longer available
Reply 15 of 22, by Meatball
Looking good. Which version of DirectX is installed? You can run DXDIAG to determine. You should have DirectX 7.0 installed at minimum for this system. If you're running Windows 98 Second Edition DirectX 6.x is preinstalled. If you're running Windows ME, DirectX 7.x is preinstalled.
Reply 16 of 22, by brunofbrsilva
I'm sorry here is the information:
SO : windows 98 SE
DirectX: 7
Last oficial driver of cd voodoo 5
No sound card
Reply 17 of 22, by Meatball
If I read you correctly, you're using the latest official driver or the latest driver from a CD? Your driver should be 1.04.00 and 3dfx Tools version of 2.6.1.110 for best all-around performance and compatibility. You can verify this from the 3dfx Tools Info Tab. If you do have the most recent version, you might want to consider reinstalling the driver before moving on to a DirectX 7 reinstallation.
You can get the drivers here: https://soggi.org/drivers/3dfx-voodoo.htm
Reply 18 of 22, by brunofbrsilva
Good evening everyone, I've just arrived home, here's the information:
The attachment Screenshot_20231001-185730.png is no longer available
Note: I am already reinstalling the driver
Reply 19 of 22, by brunofbrsilva
I reinstalled the drivers and DirectX, performing the test in unreal using DirectX:
The attachment Screenshot_20231001-201904.png is no longer available
