Reply 50540 of 53114, by dionb
H3nrik V! wrote on 2023-10-02, 06:49:
Untested, and has been taken from the recycling pile - politics are that everything being dumped at the recycling station will be put up for sale in the shop, unless specifically marked with a can of spray paint next to the drop-site (which nobody knows is there 🙄) I've found laptops up for sale, which I myself had been left for recycling, after removing CPU, memory and harddrives ... At least they do remove hard drives from everything before putting them up for sale ...
Do they also do the RNG pricing in DK?
Here in NL it's the same policy, with things like So775 boards with completely busted-up CPU pins on sale for more than complete working systems (with similar specs). Sometimes you get incredible bargains, sometimes you hear workers grumbling about how nobody ever buys their broken crap for insane prices.
Reply 50541 of 53114, by nfraser01
Kahenraz wrote on 2023-10-01, 19:10:
I refurbished and sold one of these on eBay almost a year ago. I guess you missed it.
May not have been in price range 😀
I have all of the drivers saved as well as a large box of spare parts. Send me a message if you need help getting it setup.
Will do!
Also, you *must* remove or replace the NiMH battery! I have refurbished a number of PCG-505s over the years and they all have leaked, often causing damage. Take photos of the markings on the original battery and clip the leads as close to it as you can, so it can be reused when rebuilding a replacement.
Current one looks fine (checked it when replacing the hard drive) and is holding a charge so I'm guessing is not the orginal. I happen to have a spare from a job lot of random 505 I picked up...
Reply 50542 of 53114, by H3nrik V!
dionb wrote on 2023-10-02, 08:38:
I have no idea about what RNG pricing is?
But more or less complete systems in case are in the ballpark 200-250 DKK, ie €30- something. That's not insane IMO. It is however a gamble if working or not. They do actually have a table with power outlets so stuff can be tested before buying, though ...
Reply 50543 of 53114, by DerBaum
H3nrik V! wrote on 2023-10-02, 12:40:
RNG was originally a short for "Random Number Generator" today it is used to say "random" .
Its when you for example go to ebay and see the same part for 10 and 300 bucks...
FCKGW-RHQQ2
Reply 50544 of 53114, by Turbo ->
Got this Radeon 9100, Adaptec PCI SCSI Card and ESS Maestro-2 Mediaforte PCI sound card.
Reply 50545 of 53114, by dormcat
dormcat wrote on 2023-10-01, 11:56:
Is that price tested or untested? If untested then it's quite a gamble.
Just remembered that I gambled on an untested MSI N560GTX-TI Twin Frozr II from e-waste last year with roughly the same price (NT$250) but it turned out to be somewhat defective with "snowflakes" (sigh). 🙄
Reply 50546 of 53114, by ThinkpadIL
dormcat wrote on 2023-10-02, 17:47:
I wouldn't say it is a gamble. It is obvious that almost all retro stuff we buy are faulty and the difference is to what degree they are faulty, are they reparable or not. Yes, I know, there are those who will say that there are parts and devices that work well. Yes there are, but each one of them has some issue, and for me even a dried plastic case that became brittle is an issue because it makes a device servicing almost impossible.
Reply 50547 of 53114, by H3nrik V!
DerBaum wrote on 2023-10-02, 12:45:
Ah, get it ... 🤣
Reply 50548 of 53114, by Babasha
1) Diamond C400 motherboard i440bx
2) Diamond Monster Fusion 3dfx banshee
3) C-media CMI8330PCI with spdif
4) Soltek SL-02A slot1-s370 adapter
5) Celeron 400MHz
6) Kingston PC-100 CL2 512Mb 2x256
7) Seagate IDE 4,3Gb
    157.52 KiB
    167.61 KiB
    169.61 KiB
    176.11 KiB
    221.3 KiB
Need help? Begin with photo and model of your hardware 😉
Reply 50549 of 53114, by BitWrangler
Are they all gonna get put together? Are you gonna try the celly on 100fsb? Some will some won't.
Reply 50550 of 53114, by PcBytes
Nice, though I suggest replacing the BIOS chip with a 2MBit chip if you wanna update the BIOS for CuMine support.
Reply 50551 of 53114, by Babasha
BitWrangler wrote on 2023-10-02, 20:05:
Yeap! Its already one bundle))) Will do complex test maybe tommorow.
Reply 50552 of 53114, by eesz34
I was looking for a serial MS dove-bar mouse, preferably new. I ran across this thing for far less than what you'd expect to pay. The box has this generic label with some meaningless part number that doesn't exist on Google. But based on what I could see through the bubble-wrap in the photo, it sure looked like a dove-bar mouse. An unbranded MS mouse, except the bottom label. Is that weird or has anyone seen these before?
Reply 50553 of 53114, by BitWrangler
Probably for an OEM system... the format of the part number might give a clue if it's similar to gateway or seanix or somebody's part numbers.
Reply 50554 of 53114, by debs3759
eesz34 wrote on 2023-10-02, 21:40:
It says Microsoft Corporation clearly under the FCC ID, which is a Microsoft ID, so it strikes me that it is a genuine MS mouse 😀
Reply 50555 of 53114, by eesz34
debs3759 wrote on 2023-10-02, 22:44:
Right I know. I said "An unbranded MS mouse, except the bottom label" because it does not have the logo on top, only the bottom sticker has it. Every other photo I've found online has the MS logo imprinted in the plastic on top.
Reply 50556 of 53114, by DerBaum
...Is that weird or has anyone seen these before?
I have some microsoft mice branded for different oem manufacturers (in the picture for MaxData) . But on these models it is a print on the case.
The old 2 button mouse has its microsoft branding as a double shot injection mold. maybe they couldnt print on the glossy mouse / change the injection molded text to a different oem.
1.3 MiB
FCKGW-RHQQ2
Reply 50557 of 53114, by Nexxen
DerBaum wrote on 2023-10-02, 23:35:
I have some microsoft mice branded for different oem manufacturers (in the picture for MaxData) . But on these models it is a pr […]
Nice!
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 50558 of 53114, by BitWrangler
The caution with OEM versions of these and Logitech made peripherals, and for some other types of peripherals and cards, is that they might be cut down feature wise. Where the seemingly identical retail model might be USB/PS/2 or PS/2/serial they might only work on the one interface. Which sorta makes sense as the PC they were supplied with intends to just need one which they already decided on, but a bit of a PITA to use with different PC later on in life. You get it with soundcards etc as well, no internal headers because this Packard Bell or whatever was wired this ONE way from the factory so didn't need aux inputs etc.
Reply 50559 of 53114, by vutt
Mice everywhere 😀
So since I'm back messing around with 486 era HW I was forced to shop around for serial mouse. I don't like much idea of getting used one. I came across this new old stock. Was inside blister pack.
I actually used Genius mice back in days, but never blue coral design - very fancy. It's relatively big boy, feels sturdy in hand
128.62 KiB
I also have floppy disk now ... ...and no FDD drive!
