The Soundblaster DSP project
Reply 520 of 1053, by Maelgrum
mattw wrote on 2023-10-04, 11:47:
looks good, here is the log: […]
mattw wrote on 2023-10-04, 11:37:
stage3 for V4.16 is coming in minutes...
SB Reset: done
DSP version: 4.16
MPU-401 init: done
MPU-401 loopback check: done
Stage 3, variant 39 ...passed
Success!
Excellent !
Reply 522 of 1053, by georgel
Maelgrum wrote on 2023-10-04, 12:08:
sbcrack stage 4
Active probing for address of command 0xE3. Can take some time.
SB Reset: done
DSP version: 4.16
MPU-401 init: done
Stage 4, addr 1180 ...failed
Stage 4, addr 1181 ...failed
Stage 4, addr 117F ...failed
Stage 4, addr 1182 ...failed
Stage 4, addr 117E ...failed
Stage 4, addr 1183 ...Success!
Reply 523 of 1053, by mattw
same here as @georgel already posted:
SB Reset: done
DSP version: 4.16
MPU-401 init: done
Reply 525 of 1053, by georgel
Maelgrum wrote on 2023-10-04, 12:24:
sb16dump V0.10
experimental support for 4.16
SB Reset: done
DSP version: 4.16
MPU-401 init: done
Internal memory dump: done
ERROR: DSP version not supported
Reply 528 of 1053, by Gmlb256
I now have a MIDI loopback cable at my disposal, so I can continue with firmware dumping of the AWE64 CT4520. Tried the lastest version of SB16DUMP and got the same results as georgel got.
Reply 529 of 1053, by mattw
georgel wrote on 2023-10-04, 12:32:
SB Reset: done DSP version: 4.16 MPU-401 init: done Internal memory dump: done MPU-401 loopback check: done ERROR: Dump failed […]
SB Reset: done
DSP version: 4.16
MPU-401 init: done
ERROR: Dump failed
same here, full logs attached.
    v11_test_logs.zip
    673 Bytes
    26 downloads
Reply 530 of 1053, by Maelgrum
Hmmm, may be not real 0xE3 command found, but some jump to it.
Let look for more: (stage 4)
Reply 531 of 1053, by mattw
Maelgrum wrote on 2023-10-04, 12:41:
now is strange to me (or maybe that is good), because I have 2 power-on/off cycles before with 1183 always a success, now it fails. 1169 is success, full log attached.
Stage 4, addr 1183 ...failed
Stage 4, addr 1169 ...Success!
    LOG.TXT
    1.46 KiB
    26 downloads
Reply 532 of 1053, by Gmlb256
Here is the LOG.TXT file, had to disable NMI to let it continue.
    AWELOG.ZIP
    344 Bytes
    27 downloads
    AWE64 CT4520 log
Reply 535 of 1053, by mattw
Maelgrum wrote on 2023-10-04, 12:50:
Another attempt:
failed again, full logs with the MDUMPs attached. I have no any NMI crashes, as others report.
    new_test.zip
    673 Bytes
    29 downloads
Reply 536 of 1053, by Gmlb256
Another attempt:
Still no avail. 🙁
Edit: LOG.TXT shows the message twice.
    CT4520_TEST.ZIP
    564 Bytes
    28 downloads
Reply 538 of 1053, by Maelgrum
And stage 5, with another search.
This log and previous log (one post up) i hope gives exact address location.
Reply 539 of 1053, by Gmlb256
Maelgrum wrote on 2023-10-04, 13:06:
Logs are dumped on each line
Scanning process not stops on first found
Here is the log from Stage 4. Ignore the last "Success!" message, none of the address did succeed.
    CT4520_TEST2.ZIP
    9.63 KiB
    26 downloads
