Reply 25480 of 27614, by Thermalwrong
dionb wrote on 2023-10-02, 20:14:
Thermalwrong wrote on 2023-10-02, 14:24:
Good point, I'll try soldering it from the top-side instead then, where the hole is still okay and connected to ground. Thanks : […]
Good point, I'll try soldering it from the top-side instead then, where the hole is still okay and connected to ground. Thanks 😀
dionb wrote on 2023-10-02, 08:28:
Great work!
Neither is the retail Award BIOS. I'm still not sure which is least bad.
I stuck my best one (the one that is stable at 133MHz with a Tualatin 1400S on a Slot-T slocket 😜 ) into an original Packard Bell case. Also put on a Zalman CNPS3100 over the CPU and replaced PSU fan with a Noctua Redux 80m fan so it's completely quiet. Runs Unreal Tournament like a dream 😉
I think your posts on the MS6168 upgrades are what kept me interested. I've got a v1 which is happily running a Katmai P3-550 in a low profile micro ATX case but I've always wanted a bit more and I know that the V1 can only handle P-II and Katmai P-III cpus. I can't remember how I know that though.
Having looked at the datasheet for the vcore controller, I wonder if the *only* difference between the V1 and V2 of the MS6168 is the SC1152CSW on the v1 vs the SC1153CSW on the v2? That would fit given the voltage tables for the two parts. Heh, maybe I should try upgrading my MS6168 V1 with this later chip and see if it'll handle later CPUs
edit: now I'm confused, what is the difference in the V1 and V2 except TV-out, that makes coppermine support possible? Maybe I don't need 2 boards after all
Supposedly the big difference between the two is that the V1 has an i440ZX chipset and the V2 the i440BX. Given that it only has two DIMM slots and one CPU slot that shouldn't make a lot of difference - just no ECC support in v1.
Ah, I really wish I took some pictures before I re-attached the northbridge heatsink with thermal tape now. I'm pretty sure it says it's a 440ZX in the BIOS string now that it's running the Award BIOS.
Finally starting to trust this MS-6168 v2 motherboard now that it's up and running, passes memtest at CAS2, installed an OS without issue and it's now got a 32GB SSD through a SATA > PATA adapter and a laptop optical drive. Now all it needs is a cool case.
I did get something really weird though, haven't seen it happen again and I'm not sure if it was just the system going into standby... for testing I was watching the unreal castle flyby bit and had it running for a while, then the whole computer just immediately shut off.
655.53 KiB
The only hotspot left is the MOSFET that powers the Voodoo 3 chip, so that's got a cute little ceramic heatsink on it now which makes around 10c difference
Also started using this little USB-C power delivery hotplate I got, it made moving parts around on that msata adapter far easier than an iron, even if I did burn myself on it a few times
450.14 KiB
Reply 25481 of 27614, by janoosh
I made a small adapter from my motherboard's three pin "GND, 12V, GND" CPU fan header to a normal 2 pin fan header so I don't accidentally plug a modern 3 pin fan to it and send 12V tachometer pulses through ground:
207.53 KiB
Reply 25482 of 27614, by PD2JK
I'm having issues with the sound in Wolfenstein 3D. Two sound blasters are putting out sound effects which are cut in half. Like a sliding door can be heard only a fraction of the complete effect.
The cards are CT1600 and CT3980, in a 286 16MHz with 5MB RAM.
Let's see what happens when I disable the music.
And get a heatsink for that EMU8K, that thing is getting hot...
Reply 25483 of 27614, by Thermalwrong
PD2JK wrote on 2023-10-04, 20:10:
I'm having issues with the sound in Wolfenstein 3D. Two sound blasters are putting out sound effects which are cut in half. Like […]
It might be a fault with DMA if you're getting bad digital audio with 2 cards, especially on something as old as a 286. I had a similar experience with a 386 motherboard that used an 82c206 and it turned out to be the 74F245 bus transcievers seemed to have some conductive dirt under them, removing, cleaning and reinstalling fixed it: Re: What retro activity did you get up to today?
Today, a tragedy occurred:
245.95 KiB
This translucent orange plastic has now broken in so many different ways, it's more superglue than plastic now.
Reply 25484 of 27614, by Kahenraz
Thermalwrong wrote on 2023-10-04, 20:44:
If you can get a 3D printed part as a replacement, you can print it orange to match. It won't be translucent, but it will still be an improvement.
Reply 25487 of 27614, by BetaC
Kahenraz wrote on 2023-10-03, 08:50:
BetaC wrote on 2023-10-03, 07:45:
Welp, after taking out my DOS system to eventually get back in to TIE Fighter I found out my SC-55’s screen has decided to die. I don’t even know where I could start for trying to fix it, or replace it. Music still plays without issue, and none of the caps look bad.
Luckily, you don't need the screen for any of the functionality for games. The only thing you'll want to know is how to do a hard reset between games if it's not resetting itself properly. You would have to do this with a screen regardless anyways.
Extra luckily, the issue seems to have cleared up. I think a capacitor is just slowly dying inside it, as leaving it plugged in for a few days instead of leaving it unplugged for a few months was the answer.
Reply 25488 of 27614, by Rav
kant explain wrote on 2023-10-04, 23:18:
Rav wrote on 2023-10-04, 21:55:
Learning how to use XMS memory with C is what I did today.
Give us the particulars and highlights of your journey.
I made an application to configure the settings as I have an ACER 486 with basically no useful settings in the BIOS.
Doing some memory maneuver are required to change the cache mode from WB to WT as else it crash due to dirty bit not cleared in the tag chip. To make it simple, you want to fill the cache with unimportant data before the config change and after, to be sure the tag chip is consistent.
1 MiB
Edit : Of course I had to make a correction right after posting a screenshot... WS0 instead of 0WS.. 😂
Reply 25489 of 27614, by Cosmic
I installed OpenBSD 5.1 i386 on my 486 DX50 tonight. It has 32MB FPM and a Cirrus Logic VLB card. This is after playing around with a very similar build in 86box for a while, trying to find the newest version of OpenBSD that will boot fine from floppy and detects the CD drive properly and reads the disc properly - 5.1 worked the best in my case. 5.2 still sees the CD drive but can't read the contents, 6.3 boots but the floppy kernel doesn't see the CD drive at all. I've read online that 6.5 should work, and possibly up to 6.7 (19 May 2020) - after which the compiler target for i386 platforms was changed from i486 to i586 to support a newer LLVM version. So no more modern OpenBSD on 486s unfortunately.
I might be able to get a later version running by copying the newer install sets over to the CF card (using CF temporarily for testing), then doing a manual upgrade. Or by using a separate CF IDE adapter on the other IDE channel to host newer install sets.
It's currently still generating RSA keys. :D
Update: Logged into my 486 over SSH and can ping the net. :)
# uname -a
OpenBSD 486DX50.local 5.1 GENERIC#160 i386
# sysctl hw.model
hw.model=Intel 486DX (486-class)
# ping -c 1 google.com
PING google.com (209.85.146.100): 56 data bytes
64 bytes from 209.85.146.100: icmp_seq=0 ttl=52 time=41.017 ms
--- google.com ping statistics ---
1 packets transmitted, 1 packets received, 0.0% packet loss
round-trip min/avg/max/std-dev = 41.017/41.017/41.017/0.000 ms
Reply 25490 of 27614, by DerBaum
693.1 KiB
While saving some old driver cds i came across this instruction.
I tried to put my win98 cd in my floppy drive and aquired detailed knowledge in partitioning because i had to cut the cd in small pieces to get it to fit.
FCKGW-RHQQ2
Reply 25491 of 27614, by appiah4
Umm.. It does not tell you to insert the CD into the floppy drive though?
Reply 25492 of 27614, by DerBaum
appiah4 wrote on 2023-10-05, 13:16:
But its not funny if i just put the floppy marked as "cd" in the floppy drive.
FCKGW-RHQQ2
Reply 25493 of 27614, by dormcat
DerBaum wrote on 2023-10-05, 12:58:
I knew you were joking but that's "Start Disk for Windows 98 CD," neither "disc" nor "of." Furthermore, not every system back then supported CD bootup, and not every optical drive was compatible with the generic driver by Oak Technology bundled in the official Win98 Boot Disk, so a customized startup disk might be required for an OEM system.
Reply 25495 of 27614, by dormcat
DerBaum wrote on 2023-10-05, 13:27:
ok. i get it. my joke was bad. in my language disk and disc are not that far apart.
They are interchangeable but disk is usually reserved for floppy and hard/fixed drives while disc refers to optical ones.
Reply 25496 of 27614, by BitWrangler
Rav wrote on 2023-10-05, 01:16:
I made an application to configure the settings as I have an ACER 486 with basically no useful settings in the BIOS. Doing some […]
Not sure about early 5V chips, but later should flush cache on SMM register change events, so if you send it an SMM state change before, do the thing, then change SMM back after then cache should be consistent.
Reply 25497 of 27614, by Nexxen
Desoldered 3 50V 10 and 4.7µF electrolytics from a 286 m/b. For the time being I replaced them with tantalums.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 25498 of 27614, by Rav
BitWrangler wrote on 2023-10-05, 14:29:
I think that apply only to the L1 cache.
I did use WBINVD instruction as it specifically do exactly that (on all 486). That instruction also send a command to the chipset so it can do the same with the L2 cache but most chipsets including the Ali M1429G I'm working on don't honor that and it's why I resolved to ram filling / moving / reading to hopefully evict all of that. Work fine on all DOS configuration I tested but it work like 1 times out of 10 if I do it from Windows (the thing probably switch tasks and so some windows chunks will still be dirty in the WB L2)
Reply 25499 of 27614, by bjwil1991
Turned on the Epson Stylus Color 440 I got at a thrift store to see if it'll power on and it does. I just need to find my cable and copy the drivers to the CF card or SD card since I don't have a CD drive for the laptops yet.
