My Sound Blaster 16 CT2230 Review
Reply 60 of 65, by mockingbird
cde wrote on 2020-12-06, 19:30:
That's correct, my second CT2290 doesn't have the ASP/CSP chip. It otherwise seems to perform the same 😀
Which games in particular did you test your cards on? I want to corroborate your results. Thanks
(Decommissioned:)
Reply 63 of 65, by ibeticanamuseyou
Hello - would someone please tell me the values of the R52 and caps around the area?
or point to schematics?
Thank you
    1.47 MiB
Reply 65 of 65, by Jackhead
The L5 and L6 on the Stereo out are two 470uf 16v ?
Im asking because i had this two Rubycon Black Gate F that i would love to try on a SB. If they are really good as you read..
132.07 KiB
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - AMD A5x86 X5 ADZ 133MHz @160MHz - 64MB RAM - CT2230 - GUS ACE - MPU-401 AT - ET4000W32P
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI @ 66MHz PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
