Reply 25540 of 27722, by Rav
Horun wrote on 2023-10-11, 01:35:Rav wrote on 2023-10-10, 18:43:I managed to blow up my c:\ fat :joy: 5 - I managed to recover ALL my source code... It was literally all over the place, I woul […]
I managed to blow up my c:\ fat 😂
5 - I managed to recover ALL my source code... It was literally all over the place, I would have thought that if you save, the identical part of the file would stay in the same location but I think it does save all the file over again at a different location, in many many many many chunks.I should probably backup more often than the ~weekly "Ghost" to the network...
Now I think I will have to save my config.sys and autoexec.bat then restore the partition from the latest ghost image, I don't think it can be trusted anymore 🤣Nope even DOS can and does fragment files, is why they included Defrag.exe. If you Del a small file, that cluster can be written too by a Save or other app, if the file written is large it can be spread across many clusters scattered all over.
Probably got something wrong in pure description but that is what happens....
Yeah, fragmentation that I know, but I did not expect the same stuff all over the place at various stage of advancement.
I was thinking that DOS would reuse clusters when saving the same file instead of resaving the whole thing somewhere else. I assume it save from the beginning of the first free space hole and split the files when there is not enough space to save it. But the file is already there, is seam to just not reuse the file clusters.
It's just hilarious, I have like some wayback machines (until theses old fragments actually get overwritten).
