First post, by FinalJenemba
Found one of these in a lot of stuff I picked up recently. I was able to identify what it is, but other than that I can't find much else on it or what types of use cases it had in 1997. It has a composite output with audio which seems a little unique for a PCI era card. Does anyone have any more info or know much more about it besides whats on here: https://www.vgamuseum.info/index.php/cpu/item … romatic-mpact-2 ?
Reply 1 of 8, by PC Hoarder Patrol
FinalJenemba wrote on 2023-10-09, 19:16:
Looks like their Apollo Media2 card - https://web.archive.org/web/19980630061334fw_ … .com/media2.htm
You can find a driver pack here - https://driversdownload.solvusoft.com/d26492.zip
Reply 3 of 8, by FinalJenemba
Putas wrote on 2023-10-10, 09:55:
PC Hoarder Patrol wrote on 2023-10-09, 23:21:
Interesting frequency in there, 83 MHz seems quite low. Any chance to run some 3d benchmark on her, FinalJenemba?
Im going to have to test it anyway to make sure it works, ill throw it into the Pentium MMX 95 machine most likely. What would be the best benchmark to test it with?
Reply 4 of 8, by Putas
FinalJenemba wrote on 2023-10-10, 15:29:
My game results aren't likely to be comparable with your CPU limitations. Perhaps 3DMark 99 detail results would serve well?
Reply 5 of 8, by FinalJenemba
Putas wrote on 2023-10-10, 18:37:
I have other computers ill be restoring as well this week that are faster, the MMX just seemed the best fit for a PCI card. How much CPU would you need?
Reply 6 of 8, by Putas
Pentium II - 400 should be enough.
Why did you post pictures of the AGP card?
Reply 7 of 8, by FinalJenemba
Putas wrote on 2023-10-11, 03:32:
Well dang it you’re right. I’ve been sorting through so many parts from the pickup the last two days I didn’t immediately see the little agp l shaped latch piece so immediately thought PCI. But you are correct it is AGP. I have a couple builds I’m working on that I can test it fairly easily in.
Reply 8 of 8, by FinalJenemba
Looks like the testing will have to wait. Neither of the working AGP boards I have at the moment will accept a 3.3v card unfortunately. Not sure what to do with it now, wouldn't want to sell it if I cant test it. I did find the manual for it though.
