Guide to the DOSBox debugger
Reply 20 of 37, by intbeam
Can this be configured for Visual Studio Code? I have set up a basic environment for building programs (games) for DOS using Open Watcom C++ and Visual Studio Code (https://github.com/intbeam/watcom-vscode) and I would absolutely love it if I could set breakpoints and debug the program running in DOSBox from Visual Studio Code instead of doing printf debugging.. Is this possible? And if so, any pointers to where I could start to learn how to configure this?
Reply 21 of 37, by jal
intbeam wrote on 2021-03-12, 13:11:
Though this would be really swell, this is not possible, for a number of technical reasons.
JAL
Reply 22 of 37, by xcomcmdr
I would love that too ! Even if it seems next to impossible.
I use masm-tasm with VSCode, which uses DOSBox for running and Turbo Debugger inside DOSBox for debugging. Nice, but no debugging.
It would also be perfect for working on FastDoom (I use Open Watcom for building, VSCode for editing, and DOSBox for running)
Reply 23 of 37, by intbeam
jal wrote on 2021-03-12, 13:21:
JAL
That's what I feared.. It smelled like something too good to be true 😜
xcomcmdr wrote on 2021-03-12, 13:22:
That's the exact same scenario as I am in.. Developing a top-down RPG game for DOS from scratch, and I'm doing a lot of printf debugging which is a major timewaster for me
But let's hope for the future 😜 Maybe if I get familiar enough with these things I could contribute to DosBox and maybe have a hand at implementing some sort of workaround
Reply 24 of 37, by fargo
Sorry for this dumb question, but how to start tracing a program's execution? Say for example I want to trace "prog.com", then where to set the breakpoint?
Reply 25 of 37, by ripsaw8080
Rank DOSBox Author
DOSBox Author
In a debug build of DOSBox just use the command "debug prog.com"
Reply 26 of 37, by fargo
ripsaw8080 wrote on 2021-08-13, 01:03:
I was able to trigger the debugger by setting a breakpoint on INT 21 Exec. The command is:
bpint 21 4b
Reply 27 of 37, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Yes, but then you will have to step through some internal code to get to the program's entry point. Using the DEBUG command to launch the program will break at the program's entry point.
Reply 28 of 37, by fargo
For some reason, when I run "debug prog.com", the dos internal debugger kicks in!
Reply 29 of 37, by ripsaw8080
Rank DOSBox Author
DOSBox Author
That's probably because the DOS debug program is in the current directory. If that's the case then "z:\debug prog.com" should ensure you use the launcher on DOSBox's virtual drive.
Reply 30 of 37, by videogamer555
Fizzban wrote on 2004-01-22, 03:31:
[*]Unlike the debug version, heavydebug does not use INT 3 to realize breakpoints. This way, they cannot be removed. So if you want to use breakpoints, heavydebug is the better choice.[/list]
Wait how is that an extra feature? If the heavy debug version takes AWAY the ability to use INT 3 breakpoints, that seems like it has FEWER features.
Reply 31 of 37, by jal
videogamer555 wrote on 2023-02-21, 05:23:
Like I said in that other thread, debuggers use INT 3, not programs themselves. You are confused about INT 3.
JAL
Reply 33 of 37, by Zup
A dumb question... can I put a breakpoint on a port?
I'm trying to know if a game has sound (it doesn't make any noise, but seems to have some sound related functions), so I would like to put breakpoints at the usual suspects (i.e.: output port=0x220, output port=0x388). Maybe I could find if it initializes an Adlib or Sound Blaster card, and which parameters does it use.
Thanks.
I'm selling some stuff!
Reply 35 of 37, by jal
As far as I know, that is not possible. Only changes to a memory location are breakable.
JAL
Reply 36 of 37, by RaVeN-05
I wonder it's possible to search in code segment, or dump code to file, find by external editor, and knowing opposition goto in debugger.
Maybe I can find something that accessed memory by attaching cheat engine.
As I can make cheat tables for dos games that running inside of dosbox, by debugging dosbox itself via cheatengine
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
